Old 01-08-2012, 03:52 PM   #1
refill
My Ride: 2000 323 Ci
E46 Random chirping noise on cold starts
I have this random chirping noise that occurs during cold starts. It doesn't really have a pattern to it and I have already replaced the belts and idler pulley and tensioner pulley. It still makes the same noise as if before anything was replaced. You can heard a couple clear chirps around 0:16-0:17.
refill is offline   Reply With Quote
Old 01-08-2012, 03:53 PM   #2
jasonbimmer
My Ride: 2001 BMW 330xi
sounds like your disa is rattling pretty bad.
2009 Mazda RX-8 R3
2013 Toyota FJ Cruiser
2008 YAMAHA YZF-R6
Old 01-08-2012, 03:57 PM   #3
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
+1 OP, see that black box on the side of the intake manifold? Turn off the car, disconnect the plug to it and see if it goes away. If it does you need this part 11611440049
use my vid to change it
Old 01-08-2012, 05:49 PM   #4
refill
Thanks for the replies. I will try this when I get the chance. Is there any risk of damage to the engine running without the DISA cable connected? I forgot to note this previously, but the sound goes away completely once the engine is warmed up. Does that help in confirming/eliminating a faulty DISA? I don't have any CEL light or codes being thrown either.
Old 01-08-2012, 06:16 PM   #5
Solidjake
Zero. Leaks.
Solidjake's Avatar
No, nothing will happen. Just try doing what I said first. How is your oil level?
Old 01-08-2012, 11:22 PM   #6
refill
Oil level is fine.
Old 01-09-2012, 11:31 PM   #7
refill
Started the car up this morning and it didn't exhibit the sound. If it is a faulty DISA, wouldn't disconnecting the cable not get rid of the sound? I saw other posts where a worn DISA valve will have a loose flap, therefore will continue to rattle without power connected to it. Since the noise does go away after warming up, isn't it unlikley it is the DISA? If it was faulty, shouldn't I be hearing the sound all the time and not just during cold starts?
Old 03-05-2012, 08:17 AM   #8
boostedisbetter
boostedisbetter's Avatar
My Ride: NiNe tHoUsAnD!!!
I have this same issue I think... OP, does the chirp increase with rpm? Mine goes away after warm, but I live in Florida so this rarely happens if the weather gets below 50.
** Political sig removed **
boostedisbetter is offline   Reply With Quote
Old 03-05-2012, 10:09 AM   #9
dieu66
My Ride: 2003 320i
I have the same problem and not the disa valve!completely disappears after engine warm..help!
dieu66 is offline   Reply With Quote
Old 03-07-2012, 04:54 PM   #10
boostedisbetter
I think it might just be idler or tensioner pulleys.
Old 03-07-2012, 05:01 PM   #11
jfoj
My Ride: 330CiC, M5, X5, E93
OP, you might have multiple issues?
Even it your DISA is not making the noise, given the age of your car, it most likely needs a DISA anyway.
Easy enough to check and change.
See the first link below in my signature, there are pictures of the DISA out of the engine, some with the flap missing.
Old 03-07-2012, 06:12 PM   #12
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
I was thinking pulleys also...but use a hose to isolate the sound...first.
When the belt is off, check the other things that spin too...wp, alt, ps pump...while you're there anyway.
Check belts for cracks also...and doublecheck your oil...I never believe fanatics the first time they say something!
Also, what oil are you using if you don't mind a personal question! What's your oci?
See me in June!
dmax on Facebook
Mangofy your E46!
Old 03-08-2012, 08:46 AM   #13
dieu66
My Ride: 2003 320i
I don`t know for you guys but for me the noise is intermittent before I engage a gear and get`s like a real clak clak clak when I put it in D
Old 03-08-2012, 10:54 AM   #14
boostedisbetter
Most of us in here have MT i believe sooo.. IDK what to tell you there.
DMAX what weight do you use? I'm fully SYN 5w-30 lol
Old 01-27-2013, 12:37 AM   #15
zsmith
My Ride: 2003 325xi
Did you ever figure this out? I've brought my pampered 2003 325xi (74k mi) to the BMW dealer 15 times over 8 years tying to figure this one out. Everything has been replaced on the front of the engine (ps, tensioners, all pulleys, alternator, belts). I hadn't heard of the DISA valve. Was that it? The chattering in my car is identical. Please respond if you figured it out. Thanks!
zsmith is offline   Reply With Quote
Old 03-23-2013, 08:10 PM   #16
zsmith
My Ride: 2003 325xi
I FINALLY determined the cause of this chirping/chattering. The dealer replaced the following parts (many under warranty, but some were not):
Hydraulic tensioner, tensioner pulley, alternator, power steering pump, alternator/idler pulley and water pump (it was leaking). The alternator, tensioners and pulleys were replaced twice. Do yourself a huge favor and start with replacing the belt first. Be sure to have them clean the crank shaft pulley of any residue. It's much more profitable for them to start with the hardware. But after checking my records, I realized that it was the belt that was replaced each time the chattering stopped for a year or two.
