Old 01-08-2012, 04:24 PM   #1
McSpeed
My Ride: 2005 ZHP TT Stg 1
this is just the belt, right?
This is just the belt, right? I noticed this noise happening at idle after a 20 mile trip in 37 degrees F. The only non-stock part of the belt/pulley setup is the ATI superdamper. The belt probably has like 35K on it.
Thanks guys!
Technique Tuning Stage 1 Turbo w/ Greddy Profec B Spec II | 3.07 Quaife
ATI Super Damper | Vaio Oil Pump | VAC Pan Baffle | SRE Organic Clutch
Turner Reinforcements | SPC Camber Arms | Powerflex FCABs & SFBs
Turbo Driveability Video
Horsepower vs. Torque - updated
McSpeed is offline   Reply With Quote
Old 01-08-2012, 04:48 PM   #2
ZeroSum
My Ride: 05 325
Sounds like the belt to me - to test I would put some water on the belt to see if it disappears.
ZeroSum is offline   Reply With Quote
Old 01-08-2012, 05:21 PM   #3
TrippinBimmer
My Ride: ZHP Custom Stage 3.5
I just replace the top idler pulley (the Main one showing in the Video). Made similar noise...
Old 01-08-2012, 05:26 PM   #4
xixixi
Banned User
My Ride: 01 330x-xi
ditto on the idler, mine is bad too. cold weather kills the bastids!
