Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 94 votes, 4.98 average.
Old 10-13-2013, 08:33 AM   #2201
hamblett
My Ride: 330ci
Originally Posted by bjornh View Post
B046 has no WinCE side afaik. The difference between 046 and 146 is that the navi platform runs android INSTEAD of WinCE.
I think main menu is running over WinCE 6.0, I'm wrong?
hamblett is offline   Reply With Quote
Old 11-09-2013, 01:47 PM   #2202
fuzioneer
My Ride: BMW 330ci
owned an enco b046 for over a year now, just wandered if there was any updates available for the core os, i.e. on Radio side i go into settings and can see the following version info:-
MCU: HY11.28
DVD: v04.21
HMI: v12.26
are there updates available anywhere ?
fuzioneer is offline   Reply With Quote
Old 11-09-2013, 01:47 PM   #2203
fuzioneer
My Ride: BMW 330ci
MCU: HY11.28
DVD: v04.21
HMI: v12.26
Old 11-10-2013, 03:00 PM   #2204
kaciker
My Ride: E90 320d
Bluethoot
Hi กกก
These guys can work with bluethoot in Android side
http://forum.bmw5.co.uk/topic/88964-...d/#entry937168
kaciker is offline   Reply With Quote
Old 12-05-2013, 01:56 PM   #2205
E46iT
My Ride: 2004 325i Touring
GPS No Signal
i started to get No Signal message when i press the NAVI unit.
i have reset the unit from front bazel. i have checked the gps antenna connection, i have had this unit install over a year now and never had an issue with it with GPS all of the sudden GPS wont function.
could it be my GPS Antenna is bad? has anyone experienced the same issue? if GPS antenna is back shouldn't allow me to get into gps software and menu at least?
E46iT is offline   Reply With Quote
Old 12-05-2013, 04:01 PM   #2206
haurelio
My Ride: 2001 bmw 325i
try disconnecting the battery first. also when on navi, press the satellite icon and wait.. change the position of the antenna
Contact me if you need to unlock your phone.
Also can code your car
Old 12-06-2013, 08:16 AM   #2207
E46iT
when i press navi i get no signal only, none of the other icons are visible.
Old 12-08-2013, 09:25 PM   #2208
haurelio
did you disconnect the battery as suggested?
Old 01-21-2014, 04:54 PM   #2209
E46-Munster
My Ride: E46 318Ci M-Sport
Bluetooth dropping in and out & Homescreen change?
Hi all. I believe I have a B046, I bought the unit second hand and installed without issue. It has been working find for nearly a year but now the bluetooth (I use it for streaming Spotify from my phone) is dropping in and out intermittently. I have tested with other phones and the issue remains. The song won't stop playing, it will simply appear to be muted. All other functions working fine. Any ideas?
Also, I haven't seen a layout for the non-android side that's the same as mine on any other units. Does anyone else have the same layout? Is it possible to change the initial boot image from a flower to a simple BMW logo?
I've also copied the "About Phone" section below, from reading this thread it appears that it's not possible to update this version, is this correct?
Thanks for reading!
Boot Image
About Phone
Main Menu
E46-Munster is offline   Reply With Quote
Old 02-18-2014, 08:25 PM   #2210
M127
My Ride: 2002 M3 Coupe/CB/6MT
Anyone willing to upload/provide the original navigation files? My files only came with like 3 USA states, so basically useless. Thank much!
M127 is offline   Reply With Quote
Old 05-06-2014, 05:04 AM   #2211
BM330
My Ride: BMW 330Ci
Maybe some one has figured out how to fix bootloop in B046 Android side ?
BM330 is offline   Reply With Quote
Old 05-06-2014, 12:17 PM   #2212
jchuillier
My Ride: 330CD
The bootloop is caused when you shtudown the android side "normally" (ie not cutting off the power), on my unit the ONLY way to get it back was to have the system perform an update with the procedure used to change the framework.jar....
Everytime I tried to use a program to shut down the android side to make it boot faster again I got stuck in the "no signal" bootloop and 2-3 weeks later one day it would just start an update and be back on its feet....
Go figure.....
jchuillier is offline   Reply With Quote
Old 05-06-2014, 04:37 PM   #2213
BM330
My Ride: BMW 330Ci
How can I make this update,because on Android side I only see black screen with Android logo in the middle !?
Old 05-18-2014, 12:46 PM   #2214
PainBreak
My Ride: 2004 325i
Wheeeeeeeeeeeee. Tried to perform an ill-advised update, and now mine is stuck in a recovery mode boot loop. It immediately boots into recovery mode, the progress bar goes across the bottom (I assume it's applying the contents of the update.zip from the micro-sd card), then it reboots, and starts the process over again. If I remove the micro-sd card, it gives me this guy:
I've tried throwing the original update.zip from Charles on there, thinking that would put everything back to factory defaults. However, it's the same boot loop.
I'm not really sure what to do next. I don't think that shorting out pin 13 to force an update is going to help, since it's already trying to perform the update. Hopefully mintimperial will get back with me, as I know he has some experience with resurrecting these beasts.
Is your car a Stu Stu Stammering Stan at 2800 RPMS? FLASH THE DME! http://forum.e46fanatics.com/showthread.php?t=966614
Enco B046 Android 4.04 Root/FAQ/Help: http://forum.e46fanatics.com/showthread.php?t=967737
PainBreak is offline   Reply With Quote
Old 05-18-2014, 12:46 PM   #2215
PainBreak
My Ride: 2004 325i
Placeholder for when I set it on fire.
Old 07-28-2014, 01:57 AM   #2216
korsar
My Ride: e46
Hi guys. Please repost screen 13 pin reset function.
korsar is offline   Reply With Quote
Old 07-28-2014, 01:59 AM   #2217
korsar
My Ride: e46
Hi guys! Please repost screen for 13 pin reset function
Old 08-04-2014, 01:23 AM   #2218
korsar
My Ride: e46
Up
Old 09-21-2014, 05:45 AM   #2219
korsar
My Ride: e46
Up
Old 11-22-2014, 05:06 PM   #2220
korsar
My Ride: e46
Up
Rate This Thread
