Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 94 votes, 4.98 average.
Old 09-08-2012, 03:23 AM   #1701
sunny
Hi Guys,
I just installed the B046. I have a couple of questions:
1. Is there any place I can download an update for iGo8 maps?
2. Is there an option to make it speak street names instead of it saying "make next right"?
Any help is appreciated.
Thanks.
sunny is offline   Reply With Quote
Old 09-08-2012, 08:53 AM   #1702
M127
My Ride: 2002 M3 Coupe/CB/6MT
Originally Posted by MoMurderah View Post
Have you tried rooting / installing another rom?
Sent from my myTouch_4G_Slide using Bimmer App
Have users successfully root this unit? Or other roms available?
Link on how to?
Thx man.
M127 is offline   Reply With Quote
Old 09-11-2012, 05:39 PM   #1703
parrot
My Ride: E46 318iA touring
Link on how to?
Thx man.
Not yet... I tried to get any information about the unit but I gave up.
Did anyone opened the unit? Maybe it is possible to use the display input to hook on a unit like this with mini HDMI???
parrot is offline   Reply With Quote
Old 09-18-2012, 01:29 AM   #1704
sunny
Hi,
I have the android unit (B046) and after a couple of days of the install, the sound on the gps comes and goes. The iGo resets itself to the setup wizard (it has done it 3 times in the last 3 days). You have to go thru the setup to get to the gps function.
I hear really bad static (and sometimes "brrpp" noise) on the speakers and the voice alternates between speakers. Same sound issue with BT phone.
Anyone else have similar problems? I have HK sound.
Any input is appreciated
Old 09-19-2012, 10:46 AM   #1705
JasonSmithed
My Ride: 00 323i
Oredered today b048
JasonSmithed is offline   Reply With Quote
Old 09-19-2012, 10:46 AM   #1706
JasonSmithed
My Ride: 00 323i
Oredered today b046
Old 09-20-2012, 06:22 PM   #1707
Chilton88
My Ride: 325ci, 325xi
Sirius SCC1 MJS Connector
Hi, I have a project which would likely require product MJS SCC1 USB connector. As I understand it, the product allows control of the Sirius SCC1 through a Windows based OS (PC Carputer), and running a Software like RideRunner. The USB drivers allow this to happen, meaning that the OS which has RideRunner, communicates through the USB drivers to the MJS device and therefore allows the MJS device to control the SCC1 receiver.
Would it possible to allow the Android operating system to do this? Because I want to use the B046 Enco to have Satellite Radio Sirius.
What do you think?
Thank you
Chilton88 is offline   Reply With Quote
Old 09-20-2012, 09:52 PM   #1708
rmilleta
My Ride: 2005 325 IC
I was using my gps and when it arrived at the destination it showed the turn off button. I pressed it and now the gps will not come up at all. It shows "No signal". How do I turn it back on?
rmilleta is offline   Reply With Quote
Old 09-20-2012, 11:14 PM   #1709
haurelio
My Ride: 2001 bmw 325i
lol. That happened to me once already. Unplug the battery and just set all the settings again.
Old 09-21-2012, 10:41 AM   #1710
M127
Successfully loaded apps finally. Anyone know if you use an app such as poweramp, where your music files need to be? App doesn't seem to find music on left SD card. Files need to be on the 'map' card ?
Any apps that are known of that users are successfully using to navigate there mp3 s would be great.
Thanks!
Sent from my cm_tenderloin using Bimmer App
Old 09-22-2012, 05:45 AM   #1711
BM330
My Ride: BMW 330Ci
Thanks!
Music files need to be on right side(map side)
BM330 is offline   Reply With Quote
Old 09-22-2012, 05:47 AM   #1712
BM330
My Ride: BMW 330Ci
Help ! My Android side is not working. IT stops on boot screen and nothing happens. I tried reset button,but nothing changes !
Old 09-23-2012, 08:51 PM   #1713
monty13
My Ride: 1999 e46 323i
I'm having the same issue, it just started after I installed the Wayz maps program.
For the life of me I can't get the Android side to boot up, it just cycles through both the android boot up screens and flashes "No Signal" every few minutes.
I've tried the reset button, but it only seems to affect the left side (non-Android) side of the unit.
I'm going to unplug everything, and re-install the unit to see if that resets it.
monty13 is offline   Reply With Quote
Old 09-23-2012, 09:49 PM   #1714
monty13
Alright, I just unplugged the unit and re-installed it -- still doesn't boot up on the Android side. I'm going to delete my SD card and reload the original Enco files on here and see if I can get it to work.
If there was some kind of button combination to get into the bootloader and delete the system cache or something, I think that would fix it...
Old 09-25-2012, 09:16 AM   #1715
Laithhanna
My Ride: E46 2003 330ci conv.
hi wickedly,
do you solve your problem because it happened with me and no response from Jolly.
if you can help me i will really appreciate you
Laith
Laithhanna is offline   Reply With Quote
Old 09-25-2012, 09:20 AM   #1716
Laithhanna
Originally Posted by Wickedly View Post
Hello,
So i was able to make the sd card work but for the people who has igo 2.0 when you running it and on the bottom left side there is the power button I believe. What happens when you press the power button and turn the navigation off. So I press mine off and now my navigation says no signal everytime I go back to it. I tried to take the sd card off and turn it on and it says the same thing. It wont take me to the menu where it lets me go to configation, navigation and music or whatever. so is very annoying. I also tried to reset pressing the little reset button and nothing. Tried to take the battery off and nothing. It only resets the first menu but won't reset the navigation menu. Anyone else having this type of issue? Please advise on how to solve it. My last option will be to remove the unit and disconnect from behind but wouldnt that be the same thing as disconencting the battey?
i have same problem.
can you tell me what you did to solve the problem,because Jolly did/t answer my calls or any Emails.
hope you can help me
many thanks
Laith
Old 09-25-2012, 10:20 AM   #1717
Wickedly
My Ride: 2016 BSM ///M2
Originally Posted by Laithhanna View Post
hi wickedly,
Laith
Disconnect the battery for an exact of 15minutes. This will reset not only the part of the unit with the radio and Etc but also the navigation part .
Wickedly is offline   Reply With Quote
Old 09-25-2012, 10:24 AM   #1718
Laithhanna
thank you for your quick response .
i will try it today and let you know
Old 09-25-2012, 12:38 PM   #1719
socalmotoren
My Ride: E46 SMGII
Just installed my Dynavin Clone but it wont power up, any thoughts?
socalmotoren is offline   Reply With Quote
Old 09-25-2012, 02:25 PM   #1720
E46iT
My Ride: 2004 325i Touring
on the steering wheel kbus connector red box, tap the red and yellow wire together and see if the unit comes on, you might have a faulty steering wheel kbus module.
E46iT is offline   Reply With Quote
Rate This Thread
