Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 94 votes, 4.98 average.
Old 01-09-2013, 02:38 PM   #1921
rflail
My Ride: 2006 330 CiC ZHP
I've ordered a bluetooth adaptor and a usb hub and will let you know how it works when I recieve it.
rflail is offline   Reply With Quote
Old 01-09-2013, 06:45 PM   #1922
E46-Munster
My Ride: E46 318Ci M-Sport
Excellent. Just got a promotion at work and it seems as though the Android 4.04 units are working well. Might be time to pull the trigger. Thanks for the feedback Painbreak.
One question; will I be rendering my Multi Function Steering Wheel stereo controls as useless?
Also, to confirm...out of the box there is no issue with tethering your Enco units to your phones WiFi? I have a Galaxy S3 with unlimited data and the main reason I want an Enco unit is to stream internet radio.
Finally, does the unit have bluetooth? I got an OBDII Bluetooth dongle lately and I'm using it with Torque Pro to get real time stats on my car, it would be great to have this integrated into the dash.
Thanks from Ireland!
E46-Munster is offline   Reply With Quote
Old 01-09-2013, 07:18 PM   #1923
rflail
-The steering wheel controls work; however I am having some issues where they can be unresponsive at times. It may just be an installation issue. I'm going to check this next time i have the dash pulled apart.
-The only issue I had is that the Enco initially could not see my iphone wifi hotspot because the ssid had an " ' " in it. I changed the name and it's been working great since.
-There is no bluetooth on the Android side of the unit. Apparently you can use a usb hub (because there is only 1 port which is used by the wifi adapter) and a micro bluetooth adaptor and it should work. I've ordered both and will report back once I install them. There is bluetooth on the radio side and it works fine for bluetooth audio streaming and phone calls.
Old 01-09-2013, 09:47 PM   #1924
PainBreak
My Ride: 2004 325i
There's a good chance that the bluetooth adapter won't work right off the bat, because I doubt they've built bluetooth drivers into the kernel.
That said, once we find a way to root this thing, the tcc8925 kernel source is available for custom compilation:
http://www.cnx-software.com/2012/07/...0-tizzbird-n1/
PainBreak is offline   Reply With Quote
Old 01-10-2013, 12:37 AM   #1925
rflail
Did you every receive any responses to Mr. Charles regarding the GPS mph or help rooting?
Old 01-10-2013, 01:22 AM   #1926
CTRob
My Ride: Alpine white e39
Hi there can you confirm if the steering wheel controls work on both the radio side and the Android side?
CTRob is offline   Reply With Quote
Old 01-10-2013, 03:33 AM   #1927
jchuillier
My Ride: 330CD
So let's summarize a bit for the new version
1) BT is OK on the radio side (for phone handsfree for example) but unconfirmed on android side (for live OBD for example), if someone has a working BT dongle for android can we know which brand model and chipset ?
2) Wifi is OK on the android side with the provided dongle
3) GPS is locked in mph on the android side, we need enco to either reload the new file that painbreak has sent them or better, give us root so that we can play.
4) About the root, can we go the hard way and force flash the proper files ? Maybe even with an eprom burner or whatever....
If there's more info I'll edit the post and add details.
jchuillier is offline   Reply With Quote
Old 01-10-2013, 07:48 AM   #1928
E46-Munster
Thumbs Up
Cheers guys. Great to hear feedback on the new unit.
In terms of installation guides and relocating elements of the dash, do you have any step by step links?
Thanks.
Old 01-10-2013, 09:15 AM   #1929
Ionkontrol
My Ride: 318CI SE Coupe
Thanks.
Ionkontrol is offline   Reply With Quote
Old 01-10-2013, 09:23 AM   #1930
rflail
Yes, they work on both sides.
Old 01-10-2013, 09:29 AM   #1931
CTRob
Can you confirm as to what level of functionality the steering controls on the Android side allow?
Can you for instance control the next previous track on a given media player like PowerAmp?
Would one of you guys be able to put together a video or review with pics of the unit?
I'd love to see how both the radio side looks as well as how the Android O/S looks and performs, i'd also like to see how google maps/Nav looks on the unit.
I will be comparing directly against a Dynavin D99+ unit.
Thanks!
Old 01-10-2013, 04:11 PM   #1932
PainBreak
My Ride: 2004 325i
Thanks!
The steering wheel controls don't control anything on the Android side, but since Android's audio is routed through the audio input for the "Main Amp / Radio" side, you can adjust the volume from the steering wheel controls. In fact, that's the only place you should be adjusting the volume. Android's volume should be set at somewhere between 3/4 and max, and never touched again.
But no, the steering wheel controls only map to the "Main" side of the unit.
If you can picture in your head how it is all connected, it really helps to understand the limitations of, and the benefits of the setup. Let's compare the B046 to a home theater system.
The TV is the Touch Screen Display
The Tuner/Amp is the "Radio" side.
The Blu-Ray/DVD player is the "Android" side.
Blu-Ray/DVD-->Tuner/Amp-->TV
Android-->Radio-->Touch Screen
You can't change the channel on your TV from the front of your Tuner/Amp. But you can change the radio station.
Sorry that I haven't had a chance to check on the iGo stuff yet, rflail. I fell victim to a window regulator failure yesterday.
Old 01-10-2013, 05:42 PM   #1933
CTRob
Ok so it sounds like it works the same as my Dynavin D99 so no biggie there.
What I'm interested to know:
  • Does the audio cut out when reverse gear is engaged or does the audio just become lower?
  • What is the Bluetooth call quality like?
  • What does the 'radio' side looks like in terms of menu's etc?
  • Can the unit be set to boot from the Android side or does the user have to manually press a key when the unit has loaded (like the Dynavin units).
  • How long does it take the unit to boot up and how long does the Android side take to boot?
  • Is there a restart, reset or reboot option for the Android side?
  • How much storage space does the Android side have?
  • Does the Android side support USB host mode I.E. can we use usb ODB adaptors with Torque etc?
  • How stable does the Android 4 O/S seem?
Sorry for all the questions but these are the kind of things that may sway me over from the Dynavin units
Would absolutely love a video review, even if it was just the video of how it looks etc
Thanks folks!
Old 01-10-2013, 11:40 PM   #1934
PainBreak
My Ride: 2004 325i
    Not sure. I haven't installed my reverse camera yet.
    Every so often there might be a pop, but my wife says it sounds the same while driving down the road as it does just talking on a normal cell phone, so I'd rate the quality pretty well. No issues so far.
    Nope. The Android side works in the exact same fashion as does the Dynavin units.
    5 seconds for the Radio side, 30-45s for the Android side.
    Not yet. Need to be root to issue a restart command.
    4GB internal, and a microSD slot. Not sure the limit but mine came with a 4GB card.
    At this point, it *only* supports USB host mode, but you'll be limited to devices which have a driver built into the kernel. They built in the wifi driver for the particular dongle that they ship with it. USB mouse works fine, since it's a standard HID device. Some custom OBD dongle? Probably not going to work, until we can build a new kernel for this system. But it might... Don't know until you plug it in.
    No issues at all with stability.
Thanks folks!
I answered some of your questions above.
Old 01-11-2013, 11:14 AM   #1935
rflail
I concur with PainBreak regarding the boot times and android stability.
One thing I've noticed is that the EQ settings on the radio side have no effect on the audio outputted from the android side. When listening to audio on the android side it only comes out of the front right and left speakers. Am I missing some setting on the android side to control this?
Old 01-11-2013, 11:49 AM   #1936
jchuillier
My Ride: 330CD
Ok, installed mine today but didn't have time for tests.
1) No sound whatsoever, I just used the long cable to connect to the back of the car, so the BM54 module is unplugged and unused. Am I missing something there ? I have the connector with all the RCA plugs connected but nothing plugged to the RCA wires.
2) I can't get DTV to scan for channels
3) GPS works perfectly, Igo runs smoothly, it does not remember the settings though.
4) I can't get the radio BT to go into search mode to connect to my phone.
I'll play with it more tomorrow and report back
Old 01-11-2013, 11:50 AM   #1937
bjornh
My Ride: 320iAT
Does the android side send the output to the front RCA outs as well as the amplified speaker outs?
bjornh is offline   Reply With Quote
Old 01-11-2013, 11:51 AM   #1938
CTRob
Thanks lads, PainBreak in relation to the sound cutting out when reverse is selected, if it is like the Dynavin it will do this whether a reverse camera is installed or not.
Unless a user is using the latest Dynavin D99+, when reverse gear is selected the Dynavin units cut the sound which I found really annoying.
Wondering does the Enco do the same?
Could you check this on both the Radio and Android side by any chance please?
Old 01-11-2013, 12:22 PM   #1939
CTRob
I can't answer a lot of these obviously as I don't own one but just on points 3and 4:
3) GPS works perfectly, Igo runs smoothly, it does not remember the settings though. How come some of the other guys are having issues with the GPS incorrectly reporting in knotts? I wonder does this mean there might be different versions of the software stack out??
From my experience with Dynavin units to pair the bluetooth I would have to get the phone to search for the Dynavin unit and pair from there. Perhaps the Enco is the same??
Rob
Old 01-11-2013, 12:36 PM   #1940
jchuillier
My Ride: 330CD
Thanks for the tip on the BT, I'll try that tomorrow.
I'll also play more with the GPS, it was ok in my city going to school to pick my son but I didn't go very fast so perhaps the correction between kts and kph would have been unnoticed...
More to come tomorrow.
Rate This Thread
