E46 Xi Forum
Old 01-12-2012, 09:07 AM   #1
jasonbimmer
My Ride: 2001 BMW 330xi
The common xi vibration in D cause
I have been noticing when weather gets freezing cold like in the 20's the ECU would advance the idle up to 700-800 rpm in D even when fully warmed up. thats when I feel a lot of vibration.
on good days when its above freezing, idle would drop to 600 rpm, the vibration lowers significantly.
2009 Mazda RX-8 R3
2013 Toyota FJ Cruiser
2008 YAMAHA YZF-R6
Old 01-12-2012, 11:16 AM   #2
SamDoe1
My Ride: 4cyl of fury
MT swap, problem solved.
JK, check your motor and tranny mounts.
Old 01-12-2012, 11:52 AM   #3
tcek
My Ride: BWM 325Xi - 2004
Exactly what happens to me. Runs "ok" in garage on cold days and gets worse when I go into the cold. All gears shift with auto great and no codes. After much searching I think i will clean ICV and replace engine/motor mounts (start low budget first).
tcek is offline   Reply With Quote
Old 01-12-2012, 01:44 PM   #4
mvitale27
My Ride: '02 330xi
I have a similar issue, but mine is only affected when the heat is on. No matter what the temp outside is my car idles at 600 rpm. But, if my heat is on the idle usually jumps to 800-900 rpm. Not sure why the heat being on and off would affect the idle, but when i do my driver side cv axle and OFHG within the next week i'm going to clean the ICV to see if that helps at all.
mvitale27 is offline   Reply With Quote
Old 01-12-2012, 09:03 PM   #5
jasonbimmer
I tried it today and turned heater off idle went down, turned the heater back on, idle went up.
2009 Mazda RX-8 R3
2008 YAMAHA YZF-R6
Old 01-12-2012, 10:27 PM   #6
mvitale27
My Ride: '02 330xi
anyone know the connection between the heater and idle?
Old 01-12-2012, 11:12 PM   #7
jasonbimmer
if its at max, it will raise idle to increase coolant flow.
2009 Mazda RX-8 R3
2008 YAMAHA YZF-R6
Old 01-13-2012, 10:40 AM   #8
mvitale27
My Ride: '02 330xi
Mine occurs even when the fan speed of the heater is on the lowest setting. But with the heater off, the idle is completely normal.
Old 01-13-2012, 11:32 AM   #9
dlopan
My Ride: 2005 325XI
Mine is doing the same thing. When it's below 32, the idle advances to 800 or so.
Over that temp and the idle drops back to 600 or so. It's probably to keep the alternator running enough to generate electricity for the blower. I don't think it's the motor mounts.
dlopan is offline   Reply With Quote
Old 01-16-2012, 03:58 PM   #10
miyata
My Ride: 2005 330 XI
common winter phenomena, NOT an issue.
miyata is offline   Reply With Quote
Old 01-17-2012, 01:20 PM   #11
helveticaXi
My Ride: 325xi & imola ZHP
From the reading I've done on the subject, I've become fairly certain that it's the transmission mount. There's supposedly only one, and when it goes you get the vibration. I've heard it's not too difficult to replace, but I'm going to wait until it warms up a bit to do it...
helveticaXi is offline   Reply With Quote
Old 01-17-2012, 09:52 PM   #12
Foxtrot_Uniform
My Ride: 325Xi
+1... Me too!
Foxtrot_Uniform is offline   Reply With Quote
Old 01-18-2012, 09:31 AM   #13
tcek
Seems like alot of work and expense just to change out the tranny mount (ha ha, lol)
Old 01-20-2012, 08:13 AM   #14
EDWAGON
My Ride: 2004 325xiT
Have same issue my Indy mech says it's my transmission mount is worn and needs to be replaced.
EDWAGON is offline   Reply With Quote
Old 02-10-2012, 10:05 PM   #15
EDWAGON
Tranny mount changed slight improvement. Engine mounts next week hope that will get it solved.
Old 02-13-2012, 09:54 AM   #16
tcek
I road in the passenger seat this weekend and noticed two things: 1.) the vibration was much worse on the passenger side (perhaps cause is on passenger side?) and 2.) when the driver stepped on it, I could feel the vibration in my left foot. I'm thinking the culprit is in that area. I need to check this area out but I think the tranny mount is closer than the engine mount is to that area just below the passenger left floor panel.
Old 02-13-2012, 10:27 AM   #17
SamDoe1
The Xi tranny mount is probably right where the left foot on a passenger would be. It's attached to the transfer case, there's no tranny mount so to speak. One end is supported by the TC and the other by the engine. The tranny is suspended between the two.
Old 02-13-2012, 12:12 PM   #18
E46er75
My Ride: 323i Vert, 330xi
Same here. I was sitting in the bank drive thru and noticed mine doing the exact same thing. I put the car in neutral and it stop. As I was trying to figure out what was going on I felt a hard slam like it the tranny drop into gear, come to find out the the d-bag behind me in line drove into the back of my car
Anyways, looks like a common cold weather issue and I guess I'm not alone.... Now off to the body shop to get my bumper repainted
E46er75 is offline   Reply With Quote
Old 02-16-2012, 07:07 PM   #19
EDWAGON
Just had engine mounts changed used oems from pelican. Great improvement. Indy charged 260 labor. And had tranny mount done 2 weeks ago. I think it solved it . Are there any other parts I should change seems like vibration ever so slight thru steering wheel but thats me being picky.
Old 02-16-2012, 07:09 PM   #20
EDWAGON
Indy explained why worn mounts cause more vibrations in cold due to mounts rubber being stiffer in freezing temps as opposed to summer. He's been at for over 25 years I guess it makes sense.
