Old 01-12-2012, 12:31 PM   #1
Jim Murphy
My Ride: 2006 E46 330Ci ZHP
OS Giken LSD Owners: Diff Lube?
I was getting ready to order some OS Giken lube and someone said that they have been using Redline MTL in their OS Giken LSD with no trouble whatsoever because it is a lot cheaper. What do ya'll think?
Any particular lube the best value?
Jim
Jim Murphy is offline   Reply With Quote
Old 01-12-2012, 01:43 PM   #2
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Jim,
This is direct from Turner Motorsport:
"MOTUL 75W-140 GEAR FF Competion LSD Differential Fluid - 1 liter
Part #: MOGRCMP-75W140
This MOTUL SAE 75W140 gearbox and differential fluid is specifically designed for limited slip differential (LSD) applications and some 6 speed gear boxes. We use this fluid in the diff of our championship winning TMS BMW race cars, great for racing use on both the BMW Motorsport LSD and OS GIKEN limited slip units.
Price: $29.95 (USD"
Good luck.
SUMMIT POINT WV 1:24:229 SCCA
Old 01-12-2012, 08:43 PM   #3
ZeroSum
My Ride: 05 325
After using a reccomended Castrol oil in my OS Giken I will be re-filling with the proper stuff.
(feels like it is not working as well as it did on the original oil)
ZeroSum is offline   Reply With Quote
Old 01-26-2012, 02:11 PM   #4
Jim Murphy
Any other recommendations?
BTW, how much is needed?
TIA,
Jim
Old 04-10-2014, 07:10 PM   #5
wertyu78
My Ride: '04 ZHP
TIA,
Jim
OSG says to use 1.5 liters in the non-m carrier with their LSD. I've run nothing but OS-250r in mine.
wertyu78 is offline   Reply With Quote
Old 04-10-2014, 07:28 PM   #6
secono330ci
My Ride: 04' 330ci/15' A3 TDI
Same here. It's expensive oil, but I feel more comfortable using it.
Oh...and the "$300 here, $600 there" scenario will turn into "$3000 here, $6000 there". I've had an enourmous amount of labor put into my car. (Luckily the majority of it was done by myself) Also, I've spent over $5k on my tool set since I started my project. You've been warned...
secono330ci is offline   Reply With Quote
Old 04-10-2014, 07:38 PM   #7
wertyu78
My Ride: '04 ZHP
Ditto. My pinion bearing is going bad so I need to go through the diff again. I only have 1.2 liters of the OSG fluid left, so the additional .3 liters will be Amsoil 250 gear fluid.
Old 04-10-2014, 07:43 PM   #8
secono330ci
Just curious what does it sound like when it goes bad?
Old 04-10-2014, 07:49 PM   #9
wertyu78
My Ride: '04 ZHP
In my case it sounds as if the backlash is set incorrectly. Whining on decel, and light throttle (highway driving). I'm also starting to develop a clunking sound from inside the carrier when it becomes loaded.
Old 04-12-2014, 08:54 PM   #10
secono330ci
I'm getting that same whining noise on decel and highway too. I figured it was because my subframe bushings are poly and that usually makes the diff louder. Lutz Performance did the install last year and the tech seemed to know what he was doing.
The clunking might be because you don't have enough fluid in the diff. I had that same clunking when making turns (at slow speed). I put more fluid in (it was a little low) and the clunking is completely gone now.
Old 04-12-2014, 09:02 PM   #11
wertyu78
My Ride: '04 ZHP
I have all poly subframe bushings, it's not the source of the whining noise. Your backlash is incorrect. This is what your R&P likely look like now.
ID:	553753Click image for larger version
As far as the clunking goes, it was def the pinion bearing. The binding sound you described went away after 3 miles of driving my car with the LSD. I changed the fluid after 400 miles. Always 1.5 liters
Old 04-12-2014, 09:36 PM   #12
secono330ci
Damn. Lutz closed their doors recently too, so it's not like I can go back.
This sucks, idk who in Florida can fix it now.
Old 04-13-2014, 06:55 AM   #13
wanganstyle
My Ride: e36 M3 / E30 GTS1
Jim
I only run OSG oil 80-250; always have a couple on my shelf if everyone else is out
have you considered running the TCD? it runs cooler than standard superlok
Attachment 553753Attachment 553754
Chewy. Thats no-good for setting;
there is no Fix - its time to source another core to fit the OSG into - that pair of gears is ruined.
Billet Original CNC LSD for 188K
http://www.wanganstyle.com/
S54B32 E36 M3 DTA S100 Sedan Street car full swap:
http://forums.bimmerforums.com/forum....php?t=1437471
E30 M20 2,7L Alpina + Euro E46 320D ZF 6 speed install
http://www.e30tech.com/forum/showthread.php?t=110010
wanganstyle is offline   Reply With Quote
Old 04-13-2014, 12:29 PM   #14
secono330ci
Ugh. I'm going to open the diff up today and see what the gears look like. It's almost impossible to find another 3.64 diff...I wonder if anyone sells the ring and pinion gears separately?
Old 04-13-2014, 12:58 PM   #15
wanganstyle
One can buy anything if willing to pay the cost?
Old 04-13-2014, 04:30 PM   #16
secono330ci
Opened it up, looks a little scored. I'll post pictures soon.
Old 04-14-2014, 01:30 AM   #17
wanganstyle
the 373 ring and pinion from a e92 non turbo will also fit if you cannot find a 3.64. Gears only are 188k and compatible
any z4 or x3 gearset should also be fair game for your case.
