Gun Talk
Are you a gun fanatic as well? If so, you'll want to talk to other owners about what you own in this forum. |
#21 |
Thanks again for the advice, I will try and keep it simple this time around....
Spikes stripped lower, $120 Local Spikes LPK, $65 @ http://dsgarms.com/ProductInfo/SPKSLPK101.aspx Magpul MOE Stock kit, $70 @ http://dsgarms.com/ProductInfo/MGMOESTOCKKITBLK.aspx Del-Ton 16' Mid lenght upper w/ 1:7, chromed, and YHM 4 rail @ $560 Total = $815 + shipping I will also need to find some mags and a rear sight...... What do you guys think?
Some things just don't feel right, and that is one of them. "That's what she said!" :) |
#22 |
For mags, the best ones I've used have been the Magpul PMAG, Troy BattleMag, TangoDown ARC Mag, and Magpul enhanced/upgraded USGI mags. Standard USGI mags are relatively reliable, but getting the Magpul anti-tilt follower will make them a lot more reliable. It's up to you to get what you want, but of those listed, there is no wrong answer.
For the rear sight, it really depends on if you are going to run an optic. Are you? Or are you just going to run irons? If you run irons only, I'd recommend a fixed rear sight like a Daniel Defense 1.5 Sight or the Troy Fixed Rear sight. If you want folding sights, Troy folding, PRI folding or Samson. If you are going to run an optic, then run a folding rear like those listed above, or run the Magpul MBUS Gen2. I don't recommend Magpul MBUS for full-time use.
AR15/AR10 Armorer/Advanced Armorer
Glock Armorer Gunfighter Training YouTube Channel FS: Dunlop Graspic DS-2 185/65R15 winter tires/wheels off Honda Civic - $250/OBO |
#23 |
I want to run Iron sights first and become proficient with the basics, then upgrade to a dot sight. Is there any accuracy sacrificed with flip front and rear?
#24 |
Not really. Accuracy really relates to the type of sight. Most are using A2/M4 apertures, which are all basically the same size (or a few .001" off). There are specific sights for long range accuracy that use smaller diameter apertures, but you don't need those and should steer clear.
Typical BUIS can serve as very capable full-time iron sights. I just don't recommend using Magpul MBUS full-time for extended periods, because they do not have the rigidity of most metallic BUIS. Case in point- the Troy BUIS locking mechanism has been tested to withstand up to 1000lbs of pressure before failing. That can translate well into durability during an unintentional drop or impact of the rifle onto something very hard. I believe that other sights like the PRI and Diamondhead are similar in strength. When the sights are folded, they are protected. When they are deployed, they are vulnerable. I would certainly say that learning how to use iron sights is important, but with modern optical technology being what it is, the premise that you need iron sights to be accurate or to learn marksmanship is no longer valid. This is, of course, providing that you are using a quality optic. If you can't afford an optic right now, that's cool. Just don't forgo the optic in favor of iron sights because you think they will make you a better shooter. Iron sights work on a 2-plane sighting system where you need to precisely align them for optimal effect. In all reality, there is a lot more room for error with iron sights. With optics, you simply zero the optic, and then you just place the aiming point or reticle where you want the bullet to go, and let 'er rip. Can't really screw that up as easily. Just a couple thoughts from both sides of the fence.
#25 |
Update:
I purchased the spikes lower, spikes lower parts kit and a magpul moe stock kit. Total so far is $260. Once I get the lower built I will order the upper, this is what im looking at.... Spike's Tactical 16" Midlength MOE LE Upper (5.56)-STU5035-MOE ~ $509 http://www.joeboboutfitters.com/Spik...tu5035-moe.htm or Spike's Tactical 16" Midlength Upper LE w/12" BAR Rail-STU5035-R2S ~ $670 http://www.joeboboutfitters.com/Spik...tu5035-r2s.htm
#26 |
Master of his domain.
I own the second one that you listed. I like it very much, and I have never had a problem with it.
FYI - If you join AR15Chatterbox.com, Joseph will give you a 5% discount on any order from him with the coupon code. You will also get a free hoody. ![]()
#27 |
Joebob is good people! They sponsor a lot of gunforums i take it. They have a coupon for 5% off(Code is MD) on MDShooters too. They give out free Ts with every order.
#28 | ||
#29 |
Free hoody is for any purchase over $250.
Unless you live in MD, that forum code won't work. It checks your mailing address.
#30 |
Finally got the lower parts kit shipped w/ the MOE stock kit. I am very pleased with the Spike LPK, Trigger and hammer have polished flanges at contact point. All in all the lower took one hour to assemble, very straight forward. Now i just need to order the upper and some optics!
#31 |
Found the complete upper local, I went with a Spikess 16" M4 W/ MOE hand gard and vertical grip! Now I just need optics! Cant wait to fire this bad boy!
Some things just don't feel right, and that is one of them. "That's what she said!" :)Last edited by OkStateMET; 02-13-2012 at 07:29 PM. |
#32 |
optics, you need some kinda iron sight also
![]() Check out the matech buis, they can be had surplus for cheap IIRC I paid $25 for mine. I found a rifle similar to yours to give you a idea of what they look like on the gun. They will cowitness with aimpoints/eotechs and tuck under a acog/elcan. ![]() |
#33 |
Any idea on what you want for optics?
#34 |
Im trying to decide between,
Vortex http://www.joeboboutfitters.com/Stri...-sfrd-ar15.htm or Primary arms https://www.primaryarms.com/Primary_...g.htm?CartID=3 Any better recommendations for a max of $200? I would like something with a small amount of zoom and largest possible field of view.
#35 |
Vortex has a lifetime warranty. Primary Arms has either a 1 or 2 year warranty IIRC (or something close to that). Both are low-end Chinese optics, and not meant for durability; they're considered hobby or range optics. They don't have the durability that you would get from an Aimpoint. As such, it helps to ensure that you have a good warranty. Just my $0.02.
#36 |
junk...
Those will stay on the rifle for 6 months tops before they get tossed in the spare parts box. IMHO the best starter sights are aimpoint comp m2's and eotechs, buy used and your not talking about much more cash. |
#37 |
Aimpoint FTW
#38 |
Yes. Yes. I know Aimpoint and EoTech are great, but Im not really looking to go that rout at the moment. Although hopefully I will be able to soon.
I found a YHM Flip rear sight local, im hoping to pick up tomorrow.
#39 |
I have one of those Primary Arms Micro Clones. It's a good little sight for a range gun. Would I count on it if my life depended on it? No. Would I count on it for taking a gun out of a bag, shooting some paper, and putting it back in the bag? Sure!
#40 |
Went with a YHM flip rear sight. It has two sight receptacles (small and larger hole) that you can flip between. Seems to be well built. I also picked up a ergo grip that is top notch and very comfortable. Hopefully I can make time to shoot it tomorrow!
