Old 01-13-2012, 09:32 AM   #1
stankins
My Ride: 330i
Bad powersteering pump noise not the power steering pump
Hi, I purchased a 03 330 on the cheap, it had a bad whine like a power steering pump was empty so after flushing it to no avail I replaced it and the noise didn't go away!!! Is it possible that it is my alternator??? Has anyone heard a bad alternator sound like a bad powersteering pump? Please help.
Sent from my Desire HD using Bimmer
stankins is offline   Reply With Quote
Old 01-13-2012, 10:35 AM   #2
TxZHP04
My Ride: ESS TS2+ ZHP
What makes you think that it's not still the power steering pump? If the pump is bad, a flush isn't going to fix it.
Old 01-13-2012, 10:51 AM   #3
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
Could be the belt tensioner or idler pulley.
BMWCaptain is online now   Reply With Quote
Old 01-13-2012, 12:12 PM   #4
stankins
My Ride: 330i
Ahhh forgot to mention that I replaced The pump the noise is obnoxious and resembles a dry resivoir. The alternator or tensioner pulley are Tue only things close to the sound....
Old 01-13-2012, 12:47 PM   #5
darksideracer69
My Ride: 01 325ci
Ive heard and alternator make a high pitched squeal, damn it was annoying. Get a good piece of hose and try to pinpoint where the sound is coming from.
IMAG02051
Old 01-13-2012, 12:52 PM   #6
BMWCaptain
Check your coolant level. Mine was low and the wp made a weird noise, but you could not tell where it was coming from.
Old 01-13-2012, 12:55 PM   #7
BigDRick323
My Ride: 2000 323i
Mine was smelling like burning oil, tried to go get it fixed, I will try again tonight and if I can't get it done will be taking it to Jim's Car Care tomorrow. I have to get an ampbezel put in in Garland anyways. I drove it maybe 5 miles and it smelled awful. Thoughts? I'm pretty sure I did not reattach hose tight enough.
Old 01-14-2012, 11:41 AM   #8
jacobs323i
My Ride: blown 323i
Same thing happened to me, BMW tech said it was a bad resivoir
jacobs323i is offline   Reply With Quote
Old 01-14-2012, 12:09 PM   #9
LivesNearCostco
My Ride: 2003 ZHP 6MT
The P/S fluid reservoir has a built-in filter which can get clogged in high-mileage cars. But I don't know if it filters fluid going to the pump or fluid coming back from the cooling coil.
Lowering my car's resale value one track day at a time...
LivesNearCostco is offline   Reply With Quote
Old 01-15-2012, 09:25 PM   #10
BMWtech122
My Ride: 330xi
Stankins, I think I can help you out. It is possible but less likely the P/S pump is causing your noise. Often the idler and tensioner pulleys start to go and make a whine that even to an experienced tech can sound like a P/S pump. What you should do is get a long screwdriver and start your engine (remove the intake duct that blocks the view of the belts if necessary). CAREFULLY put the tip of the screwdriver close to where each pulley bolts to the motor, and on the alternator itself. If you put your ear up to the screwdriver handle it will act as a stethoscope of sorts. You will easily be able to pinpoint the location of the noise. You can also remove the belts and spin each pulley individually while listening to pinpoint it further. I hope this helps you find your noise, any questions feel free to PM.
BMWtech122 is offline   Reply With Quote
