///M3 Forum
Old 01-13-2012, 04:19 PM   #1
MSpired
My Ride: HPF Stage 2.5 e46 M3
Send a message via AIM to MSpired Send a message via MSN to MSpired Send a message via Yahoo to MSpired
Broken Exhaust Hangers
I've gone through at least 4-5 sets of exhaust hangers. You would think with an exhaust that is half the weight of the OEM one, they would be able to handle it, but I guess not.
Has anyone found a solution for this? Sick of breaking them, seeing my exhaust hang and having to replace them over and over again.
MSpired is offline   Reply With Quote
Old 01-13-2012, 04:23 PM   #2
phudlow12
My Ride: 2006 Carbon Black M3
I have not had this problem, but maybe your exhaust is the problem. Perhaps bad fitment stretching it out? I have only recently installed my aftermarket exhaust so I have not experienced anything yet.
2006/CarbonBLK/SMG/Agency Power Muffler/35% tint/K&N intake
phudlow12 is offline   Reply With Quote
Old 01-13-2012, 04:58 PM   #3
MSpired
Possibly, but I don't think so. I've had this issue with stock section 1 and 2's, aftermarkets, and now with the HPF downpipe/section 1. Also have had 2 different aftermarket exhausts.
Old 01-14-2012, 01:58 AM   #4
Hellafunctional
My Ride: none
what exhaust are you running?
are you using oem mounts? the one with the metal reinforcements? or the one with just the rubber?
Hellafunctional is offline   Reply With Quote
Old 01-14-2012, 04:32 AM   #5
Suseer
My Ride: Cayman S
Metal reinforcement ones? I'm in the market for 2 new mounts and have only seen the rubber ones (P/N from realoem).
Suseer is offline   Reply With Quote
Old 01-14-2012, 05:04 AM   #6
MSpired
Currently running SS race and yes, using the metal reinforcements.
Old 01-14-2012, 01:03 PM   #7
zac5
My Ride: Turbo M3
have you tried silicone seal? i recently went through the same trouble. instead of getting new ones, i used silicone seal to fill the empty spaces. 200 miles so far, not seeing any problem yet.
p.s. also running ss race here
zac5 is offline   Reply With Quote
Old 01-16-2012, 05:34 PM   #8
MSpired
That is one method I was thinking of. but wanted to hear others opinion and things they have tried. I thought this was a common issue, but I guess not...
Old 01-19-2012, 05:22 PM   #9
Alex323Ci
My Ride: M3 & 323Ci (sold)
Had mine filled in with silicone and no issues so far.
Old 01-19-2012, 05:31 PM   #10
MSpired
That is what I am going to try this time.
Old 01-19-2012, 08:29 PM   #11
Suseer
My Ride: Cayman S
When you guys say filling with silicone, do you mean filling the entire empty gaps?
One of mine broken, horizontally across the inside rubber piece. Should I just silicone that part back together, or lay it down flat and silicone the entire inside?
Old 01-21-2012, 02:52 AM   #12
Hellafunctional
My Ride: none
see that's the rubber one I'm talking about
OP which are you using?
1.
or
2.
you must also get the metal thing off the old one and onto the new one
so it'll look like this
Old 07-17-2013, 10:18 PM   #13
LEXON
My Ride: 2004 BMW 325xi
Does anyone have the answer to this?
Thanks in advance!!!
LEXON is offline   Reply With Quote
Old 07-21-2013, 04:59 PM   #14
Alex323Ci
you have a 325xi so you have different exhaust hangers than the ones discussed in this M3 thread
Old 07-22-2013, 02:20 AM   #15
Moosecakes
My Ride: 02' SMG M3
Wow didn't realize you guys were talking about the rubber mount part! that's insane. I just broke my hanger off my exhaust at the weld, but that was an easy fix.. I should have checked my mounts too. And the silicone idea is great! I'll have to pick some up and fill mine.
Moosecakes is offline   Reply With Quote
Old 07-23-2013, 12:17 AM   #16
Tchleung
My Ride: 02 M3
I reinforced my rear muffler hangers by filling ALL the void areas within the mount with 3M Window weld urethane. Cures in a few days but once set it is as sturdy and strong as the dense rubber.
Follow me on Instagram @tommtomm84
03 Carbon Black X5 4.4 - Parts Hauler/Daily
02 Carbon Black M3 6MT - Fun Car
456whp/312wtq @ 8psi, No #'s yet at 9psi
4.10 / Headers / ESS VT2-550+
Tchleung is offline   Reply With Quote
Old 07-23-2013, 08:12 AM   #17
ILLuSioNz X
My Ride: 03 TiAg E46 M3 Coupe
Use the silicone, it works well.
-Chauncey
2003 E46 M3 COUPE
Check out my for sale threads: Misc. OEM E46 M3 Steering Wheel Parts | (2) H&R 2.5" 650lb/in coilover springs - $85
ILLuSioNz X is offline   Reply With Quote
