Old 01-16-2012, 07:16 PM   #1
TreyE46M3
My Ride: 2001 M3
Engine rattle and only half of exhaust working
So this morning I noticed my engine making a noise like a rock was inside of it and when doing a walk around of my car I noticed only the right two exhaust tips were actually putting out exhaust. The left two weren't doing anything. Before I go to a shop and pay a rediculous amount does anyone have any idea what it could be? It is a 2001 M3 that otherwise is in great shape.
TreyE46M3 is offline   Reply With Quote
Old 01-18-2012, 08:06 AM   #2
TreyE46M3
My Ride: 2001 M3
So, on my way to work my battery light cane on, so I think the rattling may have been the alternator.
However, the radiator light also came on and as I was parking the temp sky rocketed and my power steering went out (I am guessing due to the temp). So now I am waiting for the store to own to buy some coolant and hope that is all that is wrong. But I am at the notorious coolant system failure mileage so it could very possibly be more than just low coolant.
Old 01-18-2012, 08:28 AM   #3
Drewfus2101
My Ride: N/A
That doesn't sound good. I'd get it towed.
Drewfus2101 is offline   Reply With Quote
Old 01-18-2012, 08:34 AM   #4
TreyE46M3
My Ride: 2001 M3
Already called for a truck, I will get it home and work on it from there.
Sent from my PC36100 using Bimmer
Old 01-18-2012, 08:36 AM   #5
jardecki
My Ride: 03 m3 vert
Sounds like the warter pump, fan, or the belt
jardecki is offline   Reply With Quote
Old 01-18-2012, 08:46 AM   #6
TreyE46M3
My Ride: 2001 M3
Any way to figure out which other than trial and error?
Old 01-19-2012, 07:14 AM   #7
TreyE46M3
My Ride: 2001 M3
Update: found the problem, my idler pulley was stripped, no plastic, no bearings, just the metal at the core. I replaced that and it fixed everything. Except for the crack in the coolant reservoir that is. Plan to pull that out today and see if I can fix it. If not, anyone know the going price for one? I am guessing it is an OEM item only.
Old 01-19-2012, 08:43 AM   #8
Drewfus2101
My Ride: N/A
Go to RealOem to find the part number, then ECStuning for a price. Then go to your local BMW dealer and when they tell you it's a jillion dollars, tell them how much ECStuning has it, and they will probably match it. They will either have it in stock or have it the next day. It will be OEM or an OEM replacement and you won't pay shipping.
Old 01-19-2012, 08:44 AM   #9
TreyE46M3
My Ride: 2001 M3
Awesome, thank you.
Old 01-21-2012, 03:51 PM   #10
eweis
My Ride: 1999 328i
Do the entire cooling system. Don't bother just going piecemeal since you'll have to do it all soon anyways.
Sent from my EVO
eweis is offline   Reply With Quote
Old 01-21-2012, 10:29 PM   #11
turbo_f22_pilot
My Ride: 2 pedals - 2 paddles
if you're not going to have the work performed at a dealership, get the M3 cooling kit from "GetBMWParts.Com". It has everything you need for the complete replacement of the cooling system.
In order to finish FIRST, you MUST first FINISH !
Joy is future proof
Get your "M" on . . .
Reading is FundaM3ntal
CAR:
2003 TIAG Coupe / Blk Interior / SMG / HK Premium
MODS:
EU-CSL Coded / Macht Schnell intake / OEM CSL Wheels / OEM CSL Diffuser / Dinan Exhaust
Full LED Conversion / HID fog / Aurora AE / RE RTAB FCAB
BMWCCA NCC
turbo_f22_pilot is offline   Reply With Quote
