Thread Tools Search this Thread Rating: Thread Rating: 55 votes, 4.98 average. Display Modes
Old 10-05-2008, 11:16 PM   #1
peanut_man
My Ride: 2008 335i Sport Pkg
My attempt to clean the evaporator coil today (pics)
Hello,
So my gf's sensitive nose has been starting to complain about some odor in the car more and more lately. I, too, have notice some smell coming from the vents especially when I start the car after it was last driven w/ A/C turned on. Reading the Bentley's manual, there's a mention about cleaning evaporator to elimiate odor issues. So i set out and googled some evap cleaner sprays. Now, I'm pretty sure there's better way of doing it, but this is my first attempt, so you can tell me what I'm doing wrong if anything.
Also, I know many have said to use some disinfectant or odor control spray and spray the air inlet while running the fan. But I think that probably only temporary and still doesn't really 'clean' out the junk that has been building up in the evaporator coil... But that's just me.
To start with:
I ordered two brands, not knowing what's the difference. The middle can is a carb cleaner. Itself is of no use for this project, however the adjustible 'straw' is definitely needed to aim the cleaner in the tiny opening of the final stage resistor opening.
I honestly didn't read the manual throughly, so I thought this would be 1 hr job. Ended up w/ 3 hr. I *think* I could have skipped a buncha steps too, but too late when I realized it because everything is out already.
Overview:
  1. Remove glove compartment
  2. Remove center storage compartment*
  3. Remove shifter knob + trims*
  4. Remove center trim with ash tray*
  5. Remove IHKA control module*
  6. Remove right foot well duct*
  7. Remove final stage resistor
  8. Spray cleaner, wait 5 min or so to drain, turn on A/C to dry.
* = MAYBE I could have skipped. Not sure....
Glove compartment is easy enuf. I removed both the glove compartment + housing. Later I realized I probably can remove the housing w/ the glove compartment still attached. There are a buncha screws you need to remove.
Right foot well pannel.
There's a catch on the left side, you need to slide the pannel toward the front to get it out. A bit of twisitng / bending to get it out. Also see the right footwell duct here.
Next I push up on the center storage compartment and pull it backward, it pops right out. Didn't know it was this easy!
Remove the shift knob, shift boot, two screws and disconnect the switches and the shifter trim piece came out. I also removed the foam underneath. Four more screws and the ashtray carrier can be removed
Push from the back of the IHAK control pannel, it will simply pops out. Disconnect it.
I couldn't get a usable pic, but you do all these *just* to get to release a locking clip of the right foot well air duct. Honestly it's a lot of work to get this stupid thing out. Not knowing how ti connects, it took me 30 min or so just to figured out how to get it out. I have to pull open a bit the right pannel of the center console. Here's the stupid duct:
2 torx screws and the air distribution motor comes out. (dont' forget to unhook the top linkage):
Finally! The final stage resistor. Interestingly mine is held in place with only a plastic clip.
Using flash light and some ungodly body position, you can peek to see the evaporator coil.
Doing the BEST I could, using the spray with the "straw", I tried to cover as much of the evaporator coil as possible w/ the foaming solution. I'm pretty sure I can't get to the entire thing. There maybe some professional equipment or some smart person on the forum here that can create soemthing to do this. Let me know. This is a REAL PAIN to get to. Here's a pic of the foaming agent draining out:
If there's any doubt on amount of yucky stuff that has accumulated over the years, look at the liquid that drained out of the A/C drain hole under the car:
I used up pretty much one entire can and part of another. Just to make sure as it took me so long to get to it, I want to clean as much as I could. I foam it and let it drain I think 3-4 times.
And the famous words: "Install is reverse of removal".
Tonight, the drive was definitely odor-free. There's a hint of lemon scent right now that's from the evap cleaner. It probably will go away in a few days. So far it seems pretty affective. My gf's ultra sensitive nose can't seem to detect any smell now.
Hope this info can help some of you if you are looking to do this also. I'm sure there's better / easier way to do so. Also, maybe some one can confirm, could I have skipped all the middle steps and leave the right footwell duct intact to gain access to the final stage resistor?
peanut_man is offline   Reply With Quote
Old 10-06-2008, 07:00 AM   #2
TioTitin'sBlau3
My Ride: 03 TopazBlau3
Send a message via Yahoo to TioTitin'sBlau3
This is pretty helpful will keep for futher reference. Nice Job Man!!
Tio Blu, in hiding.
///M South on Facebook
TioTitin'sBlau3 is offline   Reply With Quote
Old 10-06-2008, 12:02 PM   #3
derek0606
My Ride: 01 330CI Orient
I'm Replacing my FSR this weekend and I will def. try this. GJ
derek0606 is offline   Reply With Quote
Old 10-08-2008, 12:56 PM   #4
|sland|2oots
My Ride: ///M3
thats awesome!! thanks for taking photos and making this diy.
|sland|2oots is offline   Reply With Quote
Old 10-09-2008, 12:21 PM   #5
ledfut
ledfut's Avatar
My Ride: '99 328i
Awesome. I gotta do this to mine for sure.
ledfut is offline   Reply With Quote
Old 10-10-2008, 01:06 AM   #6
vminev
My Ride: 325ci
NICE DIY I will definitely try it before the winter...
vminev is offline   Reply With Quote
Old 07-07-2009, 01:10 AM   #7
JB707
My Ride: 2001 DINAN 330 CI
i wonder, if you can put something like an air freshner in there to have smell good coming out all the time....just a thought....def worth a CTRL-D
DINAN:COLD AIR INTAKE, THROTTLE BODY, STAGE 3 CHIP, FREE FLOW EXHAUST
BB PERF HEADERS // RESONATOR DELETE // EE LED TAILS // M3 LIP SPOILER // DICE IPOD INTEGRATION // DIY FRONT REFLECTORS // UMNITZA ORION V2 ANGEL EYES // KONI YELLOW SPORT // H&R RACE SPRINGS // ROGUE RSM's // POWERFLEX FCAB // CLEAR FRONT SIGNALS // CLEAR SIDEMARKERS // LED FRONT SIGNAL BULBS // LED SIDEMARKERS
JB707 is offline   Reply With Quote
Old 07-08-2009, 07:45 PM   #8
dirsh
Hawaii 3.0
dirsh's Avatar
My Ride: sanbyaku sanjuu
subbing
Hello dirsh it appears that you have not posted on our forums in several weeks, why not take a few moments to ask a question, help provide a solution or just engage in a conversation with another member in any one of our forums?
dirsh is offline   Reply With Quote
Old 07-08-2009, 07:51 PM   #9
4 door 330
My Ride: 2001 330i
Just FYI we do the final stage resistor update alot at the shop, and you only need to remove the glove box to remove the final stage resistor.
It is definitely an upside down wild hand postion to maneuver in there.
I need to do this soon, I did a full cleaning of the vents and intake with the fan running, but the mildew-like smell is still there from the evap core.
2001 330i 4dr - In the garage.
1986 335is - Sold.
1975 2002 - Sold.
1989 E30 M3 - Sold.
4 door 330 is offline   Reply With Quote
Old 08-27-2009, 05:52 PM   #10
2000_328CI
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
Wow, very nice thread I will likely do this soon
| 435 HP 328Ci | RRT Racing | Designer Wraps | Active Autowerke | Vorsteiner | STATUS Racing |
Timeless Motor Group
Old 08-27-2009, 09:54 PM   #11
delmarco
My Ride: 335xi Deep Sea Blue
Send a message via ICQ to delmarco Send a message via Yahoo to delmarco
good DIY! excellent pictures, proper written English, and clear step-by-step directions.
All DIYers should follow suit and take example!
delmarco is offline   Reply With Quote
Old 08-31-2009, 08:04 PM   #12
antonmn
My Ride: 02 325Ci
Would removing the blower motor be a better way to get at the evaporator? It almost seems like less work.
antonmn is offline   Reply With Quote
Old 09-01-2009, 02:11 AM   #13
dirsh
Hawaii 3.0
dirsh's Avatar
woops I've been meaning to do this
is the smell still gone?
Old 09-07-2009, 02:08 AM   #14
wrbusa
My Ride: 2000 328i
I hope you had better luck than I did... I used this method (it's in the Bently, too) and sprayed the hell out of the evaporator, but after the cleaning smell went away, the original smell came back. I think it must be on the heater coils then? somehow the compartments are separated when the AC is on.
wrbusa is offline   Reply With Quote
Old 09-07-2009, 04:09 AM   #15
mujjuman
My Ride: not an E46
nice job!!
mujjuman
2003 325xi 5MT
Jet Black, ZSP, ZPP, ZCW, OEM Xenon ^^RIP
sig by Solidjake
mujjuman is offline   Reply With Quote
Old 02-07-2010, 01:21 PM   #16
dktuning
My Ride: 318i 2002
I read and tried my hands on removing those parts and stuff to reach the resistor but can't find any. Got lots of bruises on my hand, but I then realised, I might be working on the wrong side of the car. Created a BIG mess too!!!
My ride is e46 2002, valvetronic 1998cc 143hp version, Right Hand Drive, asI am from Malaysia. I can't seem to see anything that fit your photo when I have removed the parts.
Today I tried working on the driver side (but its your glovebox side since your cars are LHD), but again, I can't find anything that look similar to what you have posted. Here is a pic, can someone tell me if there is any similarity and which I should start pull out?
Thanks.
Name:	DSCF4633 (Small).JPG
dktuning is offline   Reply With Quote
Old 08-06-2010, 11:09 AM   #17
miyata
My Ride: 2005 330 XI
except get rid of the smell, I'm not sure what's the necessary to clean it.
miyata is offline   Reply With Quote
Old 08-06-2010, 11:12 AM   #18
Tremorz
My Ride: 01 325ci
very nice explanation
now pics of gf pls
Tremorz is offline   Reply With Quote
Old 08-06-2010, 11:57 AM   #19
m3collins
My Ride: 2002 Carbon Black M3
What is this final stage resistor that I read about here? Apply to M3's?
I need to clean mine out.....bad funk when you first turn on the A/C.
m3collins is offline   Reply With Quote
Old 08-07-2010, 01:11 PM   #20
FFWD
My Ride: 99 323i, 01 M3 Cab
Has anyone tried cleaning the evaporator by removing the blower fan assembly? According to some, it can be done in 20 minutes, and exposes the entire evaporator. Here is a DIY on the fan removal (start at post 50 for the updated steps with detailed pics):
http://forum.e46fanatics.com/showthread.php?t=418987
FFWD is offline   Reply With Quote
