info on the DISA valve, READ!!!! - Page 4 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 30 votes, 5.00 average. Display Modes
Old 03-10-2012, 01:55 PM   #61
jfoj
My Ride: 330CiC, M5, X5, E93
Sent from my DROID4 using Bimmer App
Old 03-10-2012, 01:56 PM   #62
jfoj
323/328 should be 1/8", 325/330 should be 3/32". Read the misfire thread below in my signature for more inf.
Old 03-12-2012, 06:05 PM   #63
Kris.R
My Ride: 2012 Dodge Charger
Has anyone confirmed that the 3/32" fits the 325/330?
- Kris -
"America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves."
-Abraham Lincoln-
Kris.R is offline   Reply With Quote
Old 03-13-2012, 05:40 AM   #64
jfoj
See my post directly above yours, 3/32" is for the 325/330.
If you need an O-ring, for $1 see this post if they are still available -
http://forum.e46fanatics.com/showpos...&postcount=192
Old 03-19-2012, 11:01 PM   #65
tanik
My Ride: 02 e46 bmw 325i
Send a message via AIM to tanik Send a message via MSN to tanik
Dam miss out on the o rings
Sent from my best phone on earth using Bimmer
tanik is offline   Reply With Quote
Old 05-24-2012, 12:49 PM   #66
Tex323GripIsKey
My Ride: 2000 323i Green
Hey guys, I have sourced an O-ring through BMA out of Cali. Although, I am in Texas. I am looking to pick up a temporary o-ring so I can do my lower intake boot replacement. What PN and brand would I be looking for for the 1/8th inch O-Ring?? For my 323i. I want to pick one up from say Autozone or Pepboys or Advance. Thanks for all of the help. Semi-Urgent. Was going to replace this evening so I need to pick up the ring before then. BMA is awesome though, getting the ring to me ASAP from Cali even on MDWeekend.
Originally Posted by Sweetness View Post
I used to drive fast and cowboy around, but then I realized that I can't even afford bumping into someone, so now it's slow and classy, with occasional spurts of speed. Fanatics might pick on each other from time to time, but we are all one great big family that looks out for each other in the end.
I pull up to meets, lean to one side, shakin my finger at all da playahaterz. Then I get back into my car and flash mah beamz.
323i brakes & rotors
Tex323GripIsKey is offline   Reply With Quote
Old 05-26-2012, 08:39 PM   #67
SPL15
My Ride: 01 325i Auto :/
Works great in a bind! The Fel-Pro gasket cost $6 from Autozone, it is slightly too big, but it does wedge in & eventually sunk in 100% flush after about 10 minutes of just sitting there tightened down. I'm guessing with a little heat & time, it should take a nice set/shrink & be able to be removed without loosing seal which will be nice when I replace the full CCV system in the fall. I lubed the o-ring groove, oring, & intake lip with motor oil. Also thoroughly cleaned off the intake lip with throttle body cleaner before re-assembly.
Idle when 'cold' is now nice & perfectly smooth like it is when the engine is warm. I'm guessing the DISA, ICV, & CCV were replaced in my car fairly recently as they were all relatively clean & functioning perfectly fine. I've been chasing down vacuum leaks since I bought the car in April; each & everyone of them has been hoses/lines, gaskets, or vacuum tap caps which is perfectly fine with me . This DISA gasket fix is the last thing on my checklist for vacuum leak repairs & now my car purrs during idle like it's brand new off the lot. Went through all the same & MUCH more with my used & abused E36 M3 a few years ago, this E46 is 90% the same overall design which is nice. Luckily this E46 was pampered like a 1st child so it's only minor things & 75% of the needed repairs have already been done.
Thanks for the info on this, I was to the point where I was about to gob a bunch of permatex liquid gasket on it.
SPL15 is offline   Reply With Quote
Old 05-31-2012, 05:27 PM   #68
TitanSl33pr
My Ride: 330ci
This is great to find/hear about. Have had all of the symptoms n then some. Heading to Advanced or Auto Zone when I get off duty. Full weekend with replacement of all major cooling system components. Wooosah!!!
Sent from my SPH-M820-BST using Bimmer App
TitanSl33pr is offline   Reply With Quote
Old 07-01-2012, 11:33 AM   #69
Dedney
My Ride: 325i
Gonna try this tomorrow!
2001 325i
Dedney is offline   Reply With Quote
Old 07-01-2012, 12:50 PM   #70
bernie21614
My Ride: 01 330i
subbed for part gasket part number, Great Find!
bernie21614 is offline   Reply With Quote
Old 07-01-2012, 02:43 PM   #71
jfoj
Be careful about O-ring sizes.
Suggest you read the first link in my signature below.
Old 07-20-2012, 01:36 PM   #72
da Vinci
My Ride: 2003 BMW 330i ZHP
I have a '03 330i and the FelPro 35489 was definitely too thick, it measures .137" (3.5mm). I could tighten the DISA valve all the way and the plastic was flexing so I could still see the O-Ring. The valve was not sitting flat. I am surprised no one has cracked the tabs off their DISA valve. There is an O-ring/seal store right by my shop so I picked up a 55mm x 3mm silicone O-ring for less than $2 and I would not put anything thicker. You can fit anything from 50 to 55mm. I also picked up a #136 Silicone O-ring (136 to 138 are all good) and that seems to seal it fine. That measures .102" (2.6mm) but I wanted to see what the thickest o-ring I could fit without breaking anything.
Click here for my Build Thread
"Make everything as simple as possible, but not simpler." Albert Einstein
da Vinci is offline   Reply With Quote
Old 12-09-2012, 12:03 PM   #73
kulitone
My Ride: 2004 325i
Successful disa repair
I would like to thank the E46 community for their help in diagnosing and providing guidance on replacing the DISA unit on my vehicle. All went very well and car is running much more smoothly now.
A couple of items for the cherries out there (my fellow cherries). I removed and changed out the air filter and the removed and cleaned the MAF during my process. I also removed the next intake piece behind the MAF though this was likely not necessary. If you do remove it, take a look down into the throttle to see if it is clean. Additionally, if you do remove this piece, put a clean rag or plastic over the hole leading to the throttle. You don't want anything getting down in there while you are working on the DISA.
I took the intake piece out before the DISA, which was a major PITA. So another reason to avoid doing that. But if you do take it out for some reason, replace it before you put the new DISA back in. It is a lot lot easier to put that back on and tighten the clams without the DISA being there.
Back to the story. My DISA was fried. I had initially thought about rebuilding it, but after I got a look at it I opted for the replacement. The plastic piece at the base of the flap was completely eaten away and disconnected from the flap. I read in the threads about whether the DISA could disintegrate and fly into the engine. Looking at mine, I believe it could happen.
Some other tidbits. The lower screw of the DISA is in line with another screw of exactly same size. So, me, of course, took out the lower screw, that I believe is a connector for the ICV. So if you have taken out two screws that look exactly alike and are getting resistance from the DISA in trying to take it out, make sure you have taken out the right lower screw. I have read here about a guy complaining about having a hard time taking his DISA out and I suspect this might have been part of the issue--though he may not want to admit it.
When you go to put the DISA back in, I found it helpful to have the back end (the end closest to the cabin) touch the manifold first and then angle it in from there--from back to front.
Only other issue is that it still throws 2973/2974 codes at me, though I guess from reading the forum that is not unusual. Anyone have any ideas on how to get rid of those once and for all? Car runs fine, so I think it is more of a problem with the SES programming then an actual problem with the engine.
Thanks again, between Youtube and this forum this is a repair that anyone can make.
kulitone is offline   Reply With Quote
Old 07-18-2013, 07:31 PM   #74
invader59
My Ride: 2001 325ci
thanks OP - the FelPro O-ring fits perfectly!
invader59 is offline   Reply With Quote
Old 07-18-2013, 08:37 PM   #75
220k330
My Ride: 2001 330ci ZSP
guys -- I had no idea my post would help so many people out, So glad I was able to help!!!!!
220k330 is offline   Reply With Quote
Old 10-21-2013, 10:04 PM   #76
jpark74
My Ride: 330XI
I can vouch that the DISA valve affect your MPG.
When I purchased my e46 last year, the DISA valve was leaking and I was getting about 17-18mpg. Once I replaced the DISA, I'm around 21-22mpg.
jpark74 is offline   Reply With Quote
Old 10-22-2013, 02:53 PM   #77
3sge
My Ride: 06 325i, 04 325ci
wait so after browsing through this thread, I'm confused to whether or not the O-ring will fit in my model. Will the 35489 ring fit on my 2004 325i convertible? thanks for the help
edit: nvm seems like it works. going to autozone to pick one up now. hope this will get rid of my p171,174
3sge is offline   Reply With Quote
Old 02-11-2014, 03:03 PM   #78
Boondockz
My Ride: 1999 323i
I see from some pictures, that the DISA valve has a orange o-ring. I pulled mine today and it had a green o ring like the bav auto disa...and absolutely no play, im at 180 thousand, and just bought the car.
I'm under the impression that the stock is a orange o ring... Maybe I lucked out and have the bav auto disa...it looked pretty clean too.
Boondockz is offline   Reply With Quote
Old 02-11-2014, 06:25 PM   #79
Shesgota323
My Ride: 99 BMW 323i
I was just noticing that when inspecting my lower boot for cracks, thanks for the tip on what to buy to fix the issue!
Suzanna
Shesgota323 is offline   Reply With Quote
Old 02-11-2014, 06:42 PM   #80
220k330
I just really like how we are all helping each other out -- have to keep our beloved e46's running up to par!
Sent from my XT907 using BimmerApp mobile app
