Old 02-03-2012, 04:11 PM   #21
mkodama
mkodama's Avatar
Originally Posted by murph1379 View Post
100 cell race cats will help, without hurting power much, and without too much weight.
100 cell race cats are absurdly expensive to use just for reducing sound. Not to mention illegal for road use in many areas.
Old 02-03-2012, 04:22 PM   #22
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Who makes the quietest, low-restriction mufflers, with top notch quality in universal sizes? What's your preference and why?
First, I will say that I've had no experience with any of these mufflers; so I will not cast any supposition on how well they might work for you. They do look promising though.
Dynomax Valve Technology (VT), Play video
http://www.dynomax.com/mufflers.php?muffler=vt
Dynomax Super Turbo, Quietest
http://www.dynomax.com/mufflers.php?muffler=superturbo
Dynomax Muffler Sound Clips, you need good speakers to appreciate.
http://www.dynomax.com/soundsofdynomax.php
Good luck.
SUMMIT POINT WV 1:24:229 SCCA
Old 02-03-2012, 04:37 PM   #23
RHLP3
My Ride: An office chair
I have a Vibrant stealth with both resonators on my 325. Not loud at all weighs at least 20lbs less than stock and its made of 100% T304 Stainless Steel. And frankly if something does happen to it a couple years down the road I'll pony up the 80 bucks to replace it.
If we leave by midnight...
RHLP3 is offline   Reply With Quote
Old 02-03-2012, 04:56 PM   #24
HyeWarrior
My Ride: '03 325i --> '13 GTI
Where'd you pick that up?
Perfect sound imo
Wow
So Amaze
Much Torque Steer
Such FWDoge
HyeWarrior is offline   Reply With Quote
Old 02-03-2012, 05:14 PM   #25
mkodama
mkodama's Avatar
Good luck.
The Super Turbo looks interesting. Similar design to stock E46 rear mufflers.
Old 02-04-2012, 09:23 AM   #26
Jim Murphy
My Ride: 2006 E46 330Ci ZHP
Magnaflow are pretty ugly in terms of finish and the straight-through glasspack design isn't particularly great for quiet.
If you read my post you will see that I used a straight-thru as a resonator and the offset as the muffler to reduce the noice. Beauty is in the eye of the beholder especially when they are very low priced and most of the time no one can see them. Low priced sound reduction (sp?) is my goal.
Jim
Jim Murphy is offline   Reply With Quote
