Old 01-16-2012, 08:58 PM   #1
MrPedals
My Ride: E46 M3, Mystic Blau
Bimmerworld e46 engine mounts
Just got the bimmerworld engine mounts put in and I am very pleased. The car is a bit "buzzy" at idle and it gets worse if it drops below 900 rpm or so. Much too my surprise the best part is when you hit power @ 4k and above. It's a subtle sensation but if I could describe it, it would be "clearer". I dunno, the car feels much more crisp and responsive. Much more "///M"... Lol
Sent from my SCH-I500 using Bimmer
MrPedals is offline   Reply With Quote
Old 06-19-2012, 07:44 PM   #2
Grande D
My Ride: E36 M3
Thank you for the post, further reinforcement that these mounts are indeed one of the best choices!
It will change your life!
Old 07-12-2012, 08:28 PM   #3
Steven747
My Ride: 05 330ci
interesting i deffinety want these in the near future .. can you link us please ?
Old 07-14-2012, 12:12 PM   #4
acpstunts
My Ride: E46 330ci / E53 X5
Definitely a mod for my near future also!
acpstunts is offline   Reply With Quote
Old 07-15-2012, 12:15 AM   #5
serdar255
My Ride: '01 325ci / '90 325i
Hopefully soon!
For coding, custom shift knobs, and vinyl stickers: PM me
serdar255 is offline   Reply With Quote
Old 07-24-2012, 11:33 PM   #6
330Cole
My Ride: 01' 330Ci
sooooooo what exactly do these do? stiffen the mounting point, yes, but what do they improve?
330Cole is offline   Reply With Quote
Old 07-25-2012, 10:46 AM   #7
MrPedals
There's not much to them. Basically they increase NVH. Improve the "feel" of the car and probably allow a fraction of a percent more power to go to the rear wheels by reducing drivetrain loss. In a track or motorsport situation, they reduce the amount of movement the engine does when you angrily sling it around the track. If you do these mounts coupled with the stiffer transmission mounts you will notice crisper more direct shifts, and are less likely to do a "money-shift" from 5th to 2nd instead of 5th to 4th. It's pretty much all nonsense on the street but on the track you will appreciate it more. If you have ever driven a E46 330i and an E46 M3 back to back you notice a lot of little differences other than the obvious engine/power thing. This is like having a M3+, if that makes sense.
Old 07-25-2012, 10:49 AM   #8
MrPedals
For those of you too afraid to click on the sponsors' link at the top of the page, here is a driect link: http://store.bimmerworld.com/bimmerw...unts-p930.aspx
Old 08-12-2012, 07:21 PM   #9
JohnBlaze
My Ride: Black Sunshine
I had these in for a short time, and it was too much in stop and go traffic with the AC on, crazy vibrations. However, if I could have set my rpm idle to 1,000 it would be fine. I'm back on OEM M3 mounts now, much better for DD IMO
05 ZHP w/Epic tuned s54, Euro headers&Sect.1, Dinan 3.91 and a lot of other things built by Road Race Technologies
JohnBlaze is offline   Reply With Quote
Old 08-12-2012, 10:26 PM   #10
Steven747
My Ride: 05 330ci
wow! really it was that bad ? how did it feel performance wise?
Old 08-13-2012, 01:11 PM   #11
MrPedals
I can see what you mean, however, I usually don't get stuck in stop in go traffic very much. I f@cking hate this car in stop and go...just miserable. Heavy clutch, brakes that are overly sensitive, notchy shifting, vibrations galore, etc...
My car just HATES going less than 25mph, really, really hates it.
The engine mounts, for me, are much less annoying than many other things that came stock on this car, so I just shrugged it off.
Old 08-13-2012, 02:30 PM   #12
Steven747
My Ride: 05 330ci
Exactly what I wanna hear.. I wanna pair these mounts up with rouge tranny mounts
Old 08-14-2012, 10:51 PM   #13
TxZHP04
My Ride: ESS TS2+ ZHP
The vibration associated with the BW mounts does get better as the mounts seem to "break in" over the first month or two. Of course, I also run a 900 rpm idle speed and stock dual mass flywheel. For the brief period of time that I ran poly motor mounts, I thought the vibrations were horrible even though I had experienced the exact same mounts in an e36 M3 and found them tolerable. I later found out that my stock harmonic damper was shot....
Old 08-15-2012, 01:15 AM   #14
Steven747
My Ride: 05 330ci
interesting i will deff be going for the BW mounts and with the ati damper things shouldent be that bad.
Old 08-15-2012, 10:58 AM   #15
JohnBlaze
performance wise they're awesome. Not sure how much power they actually help put down, but the added vibration and noise transfer to the chassis at speed definitely brings on excitement.
Sounds and feels really good when you go right foot down
Old 08-15-2012, 10:30 PM   #16
TxZHP04
Yep, sounds similar to a mild exhaust upgrade.
Old 08-16-2012, 09:06 AM   #17
Steven747
My Ride: 05 330ci
$hit with cams and headers and i dont know if i want more loud it already wakes the dead
Old 08-16-2012, 09:40 AM   #18
JohnBlaze
if you currently run OEM non-M MM you can upgrade to the OEM M3 MM. probably a little more like OEM non-M than BW, and definitely an upgrade
Old 08-16-2012, 08:31 PM   #19
Steven747
My Ride: 05 330ci
no way i want the bw mm and i dont mind it being a little on the uncomfortable side if i can actually feel the difference
Old 08-16-2012, 11:14 PM   #20
330Cole
My Ride: 01' 330Ci
the vibrations in the car, or it is an audible difference?
this makes sense, but in concern for my own build... what wakes the dead? what exhaust is after your headers?
  • KW V1
  • Meyle HD Diff & Subframe Bushings
  • Meyle RTAB & TMS RTAB Limiter kit
  • Lemforder ZHP HD Control Arms
  • Meyle HD FCAB
  • TMS Subframe Reinforcement kit
  • TMS Swaybars F/R & Adjustable Endlinks
  • 3.38 Open Diff
  • BMW Performance SSK
  • BB Gen 3 Headers
  • Eisenmann Race Exhaust
  • 3.5" Longtube CAI
  • 3.5" Conforti Eurosport Filter
  • Shark Injector
  • Stoptech Slotted Rotors
  • TMS SS Brakelines
  • ST Sport Pads
