Thread Tools Search this Thread Rating: Thread Rating: 1857 votes, 4.98 average.
Old 01-31-2012, 01:23 PM   #21
CrazyOneToo
My Ride: 1999 328i 4dr
So tis the season for the usual car runs rough on start up, misfires, CEL/MIL, stalling.
Hi guys. I have a 1999 328i sedan with a M52TU engine. My car idles up and down in cold weather then usually dies after a minute or two. It then starts fine and will run normal after the stall. I have replaced the intake elbow pieces and still does this. Changed the air and cabin filter and the plugs. I have checked into the VANOS answer but my mechanic thinks that isnt it. Stupid question goes here >>>> Does my car have this DISA valve?? <<<< I am not mechanically inclined but will try and can handle the minor stuff. Thanks for any help.
Oooops forgot to say I am not getting any codes on the dash....except the airbag light.
1999 328i E46 with a M52TU - 2002 X5 E53 3.0i with a M54
ECSTuning.com/ - AutohausAZ.com/ - XOutPost.com/
CrazyOneToo is offline   Reply With Quote
Old 01-31-2012, 01:39 PM   #22
jfoj
My Ride: 330CiC, M5, X5, E93
Look over my thread completely, there are pictures and diagrams of the DISA and other items.
Yes your car should have a DISA valve.
Given the age of your car, I would think that every item in my list you need to address. It appears you have already changed the intake elbow, so that leaves, the DISA/DISA O-ring, CCV lower oil drain hose and the SAP check valve vacuum hose.
Old 01-31-2012, 02:31 PM   #23
raptorman5174
My Ride: 330i ZHP
I replaced the DISA gasket yesterday but the car still has the same issues. I don't think my old gasket was bad as it had some resistance when I pulled it out. the gasket was only about $4 so I replaced it anyway.
i still have to do the blow test through the SAP valve to see if my vacuum leak is there and report back. I am also looking into seeing if the MAF may be a culprit here.
18 VMR CSL's
Koni
Eibach Sport Spring's
UUC Power Pullies
Sprint Booster
CCV Delete
3:38 rear diff
raptorman5174 is offline   Reply With Quote
Old 01-31-2012, 04:31 PM   #24
jfoj
Skip the MAF, check your lower intake boot and I guarantee that you need to replace the CCV lower oil return hose if it is original.
The SAP vacuum lines can be checked fairly easily as well.
Follow my instructions and rule out the first 4 things before you replace any expensive parts.
Old 01-31-2012, 04:51 PM   #25
zwei e46
My Ride: '99 323i & '05 325xi
Thanks for the o-ring tip op. Just ordered one from ebay for $7.99!
On my '99 323i, you can order just the o-ring and I changed it out. When we picked up my wifes '05 325xi, I planned on doing the same thing but was told you have to order the whole DISA unit.
Thanks again for the heads-up
zwei e46 is offline   Reply With Quote
Old 02-01-2012, 02:17 PM   #26
the_edsta
My Ride: 03 330i
subscribed (getting p0313 & misfires)
the_edsta is offline   Reply With Quote
Old 02-01-2012, 02:50 PM   #27
CrazyOneToo
Thanks I'll do the DISA O-ring first. Found one a ECSTuning for $2.35.
http://www.ecstuning.com/BMW-E46-328.../Disa/ES25713/
Old 02-01-2012, 08:43 PM   #28
Kirk330i
My Ride: '01 330i
I have an '01 330i with similar problems. A little different though as it idles normally, runs fine but a shudder around 2000 rpm. I have replaced the entire CCV setup (all hoses and CCV) and the intake ducts. All were failed/failing. Also sealed the DISA. GREAT tip in blowing into the SAP vacuum line!! My is flowing freely (bad). So, my question is how to you access the solenoid valve under the intake manifold? The leak is happening in that area. Thanks for the great info in this thread!
-Kirk330i
Love my 330, until it breaks!
Kirk330i is offline   Reply With Quote
Old 02-01-2012, 08:57 PM   #29
Kirk330i
My Ride: '01 330i
Forgot to mention, NO codes at all. Everything seems as though it should be running fine! I definitely think its a vacuum leak though....thanks again!
-Kirk330i
Old 02-02-2012, 02:31 AM   #30
Kirk330i
My Ride: '01 330i
Update:
I traced the vacuum line from the SAP vacuum valve to a spot under the intake manifold (couldn't see it, what a PITA to get at!). Replaced the flex tubing at both ends and still get free flowing air under the manifold. I thought the line deadheads at the solenoid valve under the intake? Unless the solenoid valve itself is broken....in which case I don't see any way to get at it??? Still got the "shudder" at about 1500-2000 rpm. One thing I haven't mentioned is that I put in a UUC SSK a few weeks back....don't see how this could cause a shudder with the clutch disengaged....Totally frustrated!!
-Kirk330i
Old 02-02-2012, 03:52 AM   #31
MJLavelle
My Ride: 2001 BMW 330ci
In addition to the SAP vacuum contol lines, Parts #3 and 4, that you listed, you need to check the vacuum control solenoid, part #5, especially if the plastic pipe, part #4 has broken down. Mine was not working, because it had sucked in debris from the pipe breaking down. I replaced the lines, but was still only getting minimal vacuum. I was not able to clean it out well enough to be comfortable with it, so I replaced it. I posted some warnings about these lines a few months ago. It is good to see someone else mention them. The biggest problem is that they will not show up in a smoke test, unless the engine is dead cold when you start, and that is almost never the case. I searched for mentions of them back when I found my problem, and found nothing. I am glad you made a formal post pointing these hoses out as a problem area. It saves me the trouble of creating one! I was kicking myself for not taking pics when I found mine was in pieces, so I could create a post about it. My solution was to use a single piece of Teflon vacuum line, that was covered in braided stainless steel, so it could withstand the heat. The single piece seemed to make more sense than a multi piece setup, since the connectors on both ends of the solid pipe were broken, as well as other chunks missing from the entire length of the pipe. So far, the braided stainless steel over Teflon line has held up well. But, I have only driven about 300 miles since I replaced it last November.
Old 02-02-2012, 08:04 AM   #32
jfoj
MJL,
Thanks for the tips and input on the clogged solenoid. I will add this detail to the thread so others can hopefully be aware of this as a possible sticky point.
I have not had to deal with trying to access this solenoid, but I can see it can be no fun to reach.
Old 02-03-2012, 04:06 AM   #33
Schnake
My Ride: 325ci
Do NOT buy the O-Ring from the clown on ebay (JDM-AUTO) http://www.ebay.com.au/itm/260693007...#ht_530wt_1185
You will only be disappointed with no communication or product! Useless as **** on a bull!
Schnake is offline   Reply With Quote
Old 02-03-2012, 10:19 AM   #34
raptorman5174
My Ride: 330i ZHP
i have already replaced the CCV and all related hose the go to that part. Both upper and lower intake boots are also brand new, both had tears in them. Just replaced the DISA O-Ring a couple of days ago. This morning the car ran fairly well I was surprised I'm going to clear all my codes and see which ones come back. Still have to do the SAP check I'll report back on my findings.
18 VMR CSL's
Koni
UUC Power Pullies
Sprint Booster
CCV Delete
3:38 rear diff
Old 02-03-2012, 01:17 PM   #35
CrazyOneToo
Checked out the larger SAP hose today on a cold start up. It was gushing air out of the side. I have one on order and will replace the old one when the new one comes in. I'm hoping this fixes my cold start stall issue. The vacuum line is another story. When and if I can figure out how I'm going to get to the other end of it, I will replace it whether its bad or not.
You guys ROCK!!!!
Old 02-04-2012, 06:53 PM   #36
Kirk330i
My Ride: '01 330i
That's a great pic of the underside of the manifold! It really helps to see what I was groping at under there. Is removing the manifold the only way to get at the solenoid (part #5 in the RealOem diagram) that controls vacuum to the other valve (#1 in the diagram)? If anyone has any idea how to get at it, please let me know! Anyone ever removed it for service? I can blow through the vacuum line and it flows freely somewhere around the solenoid. I get a feeling the valve is stuck open, allowing me to blow past it into the intake manifold. Thanks for the great thread!
-Kirk330i
Old 02-05-2012, 01:54 AM   #37
Nickvjr
My Ride: 2004 330Ci Conv.
Send a message via AIM to Nickvjr Send a message via Yahoo to Nickvjr
Great thread! Glad one of my photos is being put to good use!
Sticky!!!
-Nickvjr
2004 BMW 330Ci Convertible
Nickvjr is offline   Reply With Quote
Old 02-05-2012, 02:27 AM   #38
Kwaz
My Ride: 323I
I've had cold weather misfires for a bit and Finally found out the culprit! Figured I'd share my experience to help someone else. Turns out the -2 degrees outside actually cracked a cell in my battery, therefor, it wouldn't hold its charge. It was at 10.4 volts and it was causing low circuit misfires on all cylinders. I searched for hours finding nothing that fixed it. I got a new battery and its been misfire and cel free for 10 days.
Soy el pecador y voy a hacer un desmadre
y al que no le guste que chingue su madre
Kwaz is offline   Reply With Quote
Old 02-05-2012, 03:44 AM   #39
Kirk330i
My Ride: '01 330i
So does anyone know the real operation of the vacuum circuit for the SAP system? I'm trying figure out why I'm have no resistance in the line from the vacuum actuated valve at the SAP and the electric solenoid valve under the intake runners. Let me see if I get this straight, and anyone with the knowledge please correct me, here's how I see it working;
- On a cold startup, the SAP turns on to flood the exhaust manifold with air (oxygen) helping to reduce emissions and help heat the CAT.
- Simultaneously, the DME sends an "open" signal to the solenoid valve under the intake runners. When this opens, it vacuum actuates the vacuum valve by the SAP to open, allowing air into the manifold.
- After approx. 90-120 sec., the SAP turns off (via DME command), and I'm assuming, the DME closes the intake solenoid valve thereby shutting off vacuum to the valve at the exhaust manifold and air into the manifold.
- Car warms up, all systems go.
Simple, right? So I'm trying to figure my best odds here before I start throwing $$ at it. If it's just a vacuum line gone bad, no problem (yeah right, if you're Houdini and can reach under there!). If the solenoid valve is shot, then I would like to buy it before ripping into the teardown (still haven't figured out the best way to get at the valve) and they aren't cheap! Sorry to all if I'm rambling, I just think that if I find out what's up with my shudder issue then it might help someone else with lean running issues. Thanks again for the thread!
-Kirk330i
Old 02-05-2012, 06:06 AM   #40
MJLavelle
You guys ROCK!!!!
You need someone with small arms! I made my wife reach back there, and connect my new line. It was hard for her to reach too. I ended up removing the entire cabin filter housing. She was able to get her arm back there and reach the connection. She was not at all happy about it, and now she tells people how she fixed my car for me....
Rate This Thread
