Old 01-17-2012, 08:06 PM   #1
xixixi
Banned User
My Ride: 01 330x-xi
Ultimate Breather Tank
Here is what in my eyes is one of the best catch cans I've seen for e46s. HPF also makes a very nice can. (500) This can will cost you about. (200) I took this idea from PEI. This set up requires a long tube intake. I realized after I made the mounting bracket. I had put a heater under my intake... I'm having some 94% reflective material shipped this week to combat that issue. Enjoy!
ID:	432823   Click image for larger version
ID:	432824   Click image for larger version
ID:	432825   Click image for larger version
Old 01-17-2012, 08:45 PM   #2
Tchleung
My Ride: 02 M3
Instead of having it as a breather tank, why not route it back to the intake? So long as the catch can has adequate baffles and filters, minimal oil vapors will re-enter the intake track. Vacuum promotes better ring seal as well. Looks good though. Did you make a bracket for it to mount to or use an existing hole there? I ran an open crankcase breather system on my old turbo car so I do know it's effectiveness!
I'm using IMO one of the best bang for your buck cans. Made by 42 Draft Designs.
It costs $115 + shipping for the basic can and goes up from there. But this is the basic one:
And to show you the internal baffle/filter to catch oil at the top of the can.
Installed:
02 Carbon Black M3 6MT
456whp/312wtq @ 8psi, No #'s yet at 9.5psi
4.10 / Headers / ESS VT2-550+ / Tuned by Evolve
Tchleung is offline   Reply With Quote
Old 01-17-2012, 08:51 PM   #3
xixixi
Banned User
My Ride: 01 330x-xi
Looks very nice! M3's VC design allow for a lot more options, while still maintaining a clean engine bay. That is a very nice set up! I still hate the idea of having that hot air in my intake! The an fittings/hoses really drive up the price of a can. Thanks for sharing!
Old 01-17-2012, 09:19 PM   #4
xixixi
Banned User
My Ride: 01 330x-xi
I did make a bracket to mount it. This bracket will cost about 4 dollars from home depot. You need to modify it slightly for it to work. I'm more than willing to go into great detail, about how I did it. Ask away! EDIT: BTW you have some very nice pieces in that bay!
Old 01-18-2012, 01:01 AM   #5
paraklas
paraklas's Avatar
My Ride: ESS TS2 320ci
At the rate my catch can is filling, I am thinking of using MrPaddleShift's solution that utilizes a BMW motorsport oil separator with a check valve, to drain back to dipstick
http://www.argyrides.eu/makeyourownsig.jpg
paraklas is online now   Reply With Quote
Old 01-18-2012, 04:02 AM   #6
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
Ultimate oil breather = Dry sump system
Old 01-18-2012, 07:33 AM   #7
Drewfus2101
My Ride: '03 330i
Mine is filling up pretty fast. It actually doesn't fill up before the vapors start to blow out the other side though. I just need some baffling in there. I'm now using quart sized containers. But I'm venting out to the atmosphere.
Also, it is impossible to clean out the gunk. I would NEVER use something that I could take completely apart and clean. My lines are even clogging up with gunk.
Drewfus2101 is offline   Reply With Quote
Old 01-18-2012, 08:46 AM   #8
xixixi
Banned User
My Ride: 01 330x-xi
My comes out with 1 wing nut and a turn of a hose. I used a big hose and mine doesn't seem to get clogged. But, I do have that nasty mayo looking stuff in mine. Pics/price of paddleshift's set up?
Old 01-26-2012, 01:19 PM   #9
Jim Murphy
My Ride: 2006 E46 330Ci ZHP
I was told by my BMW guru that if not setup correctly the catch can will create a vacuum strong enough to suck out ALL the oil in the pan. I am curious about the BMW check valve in a later post here please provide a link to the kit.
TIA,
Jim
Jim Murphy is offline   Reply With Quote
Old 01-26-2012, 03:55 PM   #10
paraklas
paraklas's Avatar
TIA,
Jim
That's why a one way valve is utilized as well
Here's my catch can install and the alternative drain-to-dipstick method here
Old 01-26-2012, 06:37 PM   #11
quick108
My Ride: ---
http://store.radiumauto.com/index.ph...id=28&parent=5
quick108 is offline   Reply With Quote
Old 01-26-2012, 07:47 PM   #12
xixixi
Banned User
My Ride: 01 330x-xi
Wow, I really like the can you linked. Thank you
Old 01-26-2012, 07:54 PM   #13
TrippinBimmer
My Ride: ZHP Custom Stage 3.5
Anyone else did this install? Looking for ideals. Like to be super clean and not noticeable...
Old 01-26-2012, 07:57 PM   #14
xixixi
Banned User
My Ride: 01 330x-xi
I'm sure I can help make a bracket or something/find a place for that thing. Hell, someone buy mine. I'll order this one and make a mount/location for it.
