Old 01-18-2012, 11:44 AM   #1
billythefish
My Ride: 328i saloon 1998
Electric motor burnout
I suspect the motor on my sunroof may have burned out. When I attempt to close the sunroof with BMW's special tool, no amount of force will turn it in either direction. I have removed the motor and examined it and nothing appears jammed anywhere. The same with the sunroof I have removed that and checked for blockages or the usual sunroof problems. Due to the fact that I am unable to open and close the sunroof manually I suspect the motor itself may have seized. To reiterate if the motor has burnt out will it seize up?
All help appreciated
billythefish is offline   Reply With Quote
Old 01-19-2012, 02:41 PM   #2
billythefish
still not working,any ideas?anyone?
Old 01-21-2012, 02:22 AM   #3
BMW BEATS THE REST
My Ride: m3 STEEL GRAY
usually when the motor goes it can still be manually closed via the sunroof motor like your doing, does the motor have power supply? If no check your fuses, if yes see if the motor moves if you remove it completely from the sunroof track. If the motor moves after you remove it from the sunroof, chances are your sunroof is shot and binding, rebuilding or replacement may be needed.
BMW BEATS THE REST is offline   Reply With Quote
Old 09-11-2012, 05:57 PM   #4
awesomechinz
My Ride: 1999 BMW 323i sedan
One thing I noticed with mine is that sometimes it works and sometimes it doesn't turn the car off then on and try again
awesomechinz is offline   Reply With Quote
Old 10-04-2012, 04:37 PM   #5
aahmed2016
My Ride: 2003 330i ZSP/CP/PP
Lol after reading electric motor burnout, I thought of a Prius doing a burnout.
aahmed2016 is offline   Reply With Quote
