Old 01-19-2012, 02:56 PM   #1
TheRiddle
Sofa-king-what
My Ride: M52TUB28-Vert
Different DME (oem)
a question that i have in mind since i swap the engine:
i passed form a 323 (2.5) to a 328 (2.8) engine, but i keep the original 323 DME.
does anyone knows if there are differences between the 2?
once i tried to upload a 328 map on my DME @ dealership, but with no success (gt1 didn't allow me to continue for unrecognized DME,i guess because he knows that mine is a 323 and not a 328), ut they said me that there are no difference...
i trust in you all, not in them
TheRiddle is offline   Reply With Quote
Old 01-19-2012, 03:11 PM   #2
midnighttuning
My Ride: 330ci
100% there is a difference, but the car will still run
BarrieM/// BMW Tuner
midnighttuning is offline   Reply With Quote
Old 01-20-2012, 06:50 AM   #3
TheRiddle
Sofa-king-what
need more opinions.....
and eventually a "visual explanation"
Old 01-20-2012, 08:40 AM   #4
NickG
My Ride: 2011 BMW 550i M-Spor
The DME itself is the same. This difference is in the program/calibration. The 328 program can be flashed onto the 323. The person doing the work just needs to know how to do it (based on the tools they're using).
Nick
For Sale: 2005 BMW 330i ZHP with Technique Tuning Stage1 Turbo Kit
NickG is offline   Reply With Quote
Old 01-20-2012, 09:57 AM   #5
TheRiddle
Sofa-king-what
Wait, e46 uses 2 different dme, MS42 & MS43, one on earlier version the other on latest
luckily mine is the same of 328 so no prob for this..
I know that anyone (who's able to use gt1/DIS) will do any sort of read/write operation on DME, but the problem is not this one, is the fact that there's a sort of EWS code that blocked the upload because the DME was of 323 and not of a 328 so the process has been aborted by the sys.
i bought an interface for obd2 dme coding, but i've beeen always scared of doing me, plus i couldn't find an OEM 328 map..
if you know the correct procedure to upload an oem 328 map using bmw tools,without recieve any interference by the check sys let me know, i'll try by myself next time i'll visit them..
Old 01-20-2012, 10:53 AM   #6
NickG
In Europe that's true, but here in the states we even had a 3rd DME used in the E46 (MS45)
On a GT1 or Autologic, you need to manually enter the program and calibration numbers for a 328 and force the tool to flash that software into the ECU.
Nick
