Sponsored by The Tire Rack
Old 01-19-2012, 03:34 PM   #1
Zin
My Ride: 2005 330XI
Will a 235 50R18 fit an E46?
I have a 2005 330xi with 225 40R18s. I am tired of dinging my rims and would like to go to a larger sidewall. Will a 235 50R18 fit? I have the standard suspension. If these won't fit, what is the largest tire I can get on 18x8 rims? I want the same tire all the way around. Any help would be greatly appreciated.
Zin is offline   Reply With Quote
Old 01-19-2012, 03:41 PM   #2
SweTurbo
Big Pimpin'
My Ride: 323i -98
90mm sidewall vs 117,5mm.
Just learn to drive in a way to protect your rims, or get 17" rims..
Old 01-19-2012, 03:51 PM   #3
lcoleman
My Ride: '79 Massey Ferguson
Going to a higher aspect ratio would be foolish. You will hurt performance and fuel economy, render your speedometer and odometer inaccurate, and also introduce the possiblity of rubbing.
If you don't want to ding your rims, don't drive so close to curbs.
Old 01-19-2012, 03:54 PM   #4
invictus
My Ride: M3 (F80 & E46), S3R
i don't feel like this will help you as much as you think it will
CCW. Dunlop. Ground Control. StopTech. Hawk. Vorschlag. Rogue Engineering. Recaro. TCDesign. RaceTech. VAC. Motul. Vorsteiner.
Find me on track: 10/19-21 Sonoma Speedway // 11/10-11 Thunderhill
The story so far...
Fund my track car:
PM me about my: stock diffuser, stock trunk, e46 m3 part out
invictus is offline   Reply With Quote
Old 01-19-2012, 03:58 PM   #5
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
do you mean bending your wheels? or curb rash?
if you mean bending either you need to buy nicer wheels or stop driving over boulders.
if you mean curb rash don't drive so close to curbs.
like he said^ a bigger side wall isn't going to help you as much as you think it will.
Old 01-19-2012, 04:10 PM   #6
Zin
My Ride: 2005 330XI
I do mean bending wheels. Curb rash is not a problem. I am in Eastern TN and there are plenty of "surprise" potholes and hazards. I figured a higher sidewall would give me more protection. I appreciate the comments but does anyone know how big a tire will fit?
Old 01-19-2012, 04:11 PM   #7
dreyo27
My Ride: 2001 325ci
bigger sidewall would make your performance better...
plus fatter tire = better ride..... Such a perfect moment for a yo mama joke here
anyway just watch this... if you have time, if not skip to about 6:30
dreyo27 is offline   Reply With Quote
Old 01-19-2012, 04:20 PM   #8
HardPark'd TT
My Ride: is parked hard.
Send a message via AIM to HardPark'd TT
Why not get 17's instead? 50 sidewall is going to look ridiculous on an 18.
Bagged e85 Z4 | www.ogretrograde.com
Bagged TT 225Q SOLD - e46 M3 SOLD - W202 SOLD - e46 325i SOLD
HardPark'd TT is offline   Reply With Quote
Old 01-19-2012, 05:12 PM   #9
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
225/40 or 235/40
Old 01-19-2012, 05:26 PM   #10
lcoleman
(I didn't watch the whole video, but I didn't have to--I know you're wrong)
Hey Zin! Check out my location. I admit the roads have gotten a lot worse after last winter, but c'mon. Are your wheels stock? I could imagine you maybe bending some really cheap ones, but not decent ones or even the stockers. Dodging the big potholes isn't that difficult.
Old 01-19-2012, 06:17 PM   #11
BMWespresso
My Ride: 2005 325CI
go with 255-35-18 approx same diameter, an inch and a bit wider
BMWespresso is offline   Reply With Quote
Old 01-19-2012, 07:58 PM   #12
dreyo27
My Ride: 2001 325ci
i meant to an extent... u dont see formula 1 doing 30 percent... or grand am, even the hicks in nascar know better then you!!!!
Old 01-19-2012, 09:49 PM   #13
Zin
My Ride: 2005 330XI
I have good rims on the car. They are bbs lm reps by Miro. I miss most of the pot holes but it only takes one to screw things up. I appreciate everyone encouraging me to miss the potholes but I wish someone would just answer my original question and tell me if the 235 50R18 will fit.
Old 01-19-2012, 10:03 PM   #14
boltan
Banned User
My Ride: 2004 330ci
they're going to leave you with the even bigger problem of an inaccurate speedometer
boltan is offline   Reply With Quote
Old 01-20-2012, 09:12 AM   #15
lcoleman
http://www.yokohamatire.com/tires_10.../aspect_ratio/
A tire with a lower aspect ratio responds to lateral force more effectively than a tire with a higher aspect ratio. The aspect ratio affects steering stability. Generally, the shorter the sidewall, or the lower the aspect ratio, the less time it takes to transmit the steering input from the wheel to the tread. The result is quicker steering response. Aspect ratio also affects the tread contact patch. As a rule, a low profile tire produces a wider tread contact patch. This wider tread contact patch creates a stiffer footprint that reduces distortion and provides improved cornering traction. Aspect ratio also impacts ride. A low profile tire usually has a stiffer ride than the standard aspect ratio of 75 or more.
Nice try, though. And yeah, it's probably more important to get a nicely-contructed tire with a stiff sidewall versus a cheaply-made low-profile tire.
To answer your question, OP, h3ll no they won't fit, for all the reasons I listed in my first response. If you're bending wheels on the potholes around here, you are not paying enough attention while driving, or your wheels are crap. Sorry.
This thread is a perfect example of why this forum used to be way cooler. Monster truck tires on an e46, lulz.
Old 01-20-2012, 05:40 PM   #16
invictus
"reps"
The story so far...
Fund my track car:
Old 03-20-2014, 04:33 PM   #17
dankjono
My Ride: 330 xi
What size tire did you go with?
I have 225/40/18 and I wanna get a bigger sidewall to reduce road noise. Will 235/50/18 fit?
dankjono is offline   Reply With Quote
Old 03-20-2014, 04:45 PM   #18
lszlszx
My Ride: 1.8T, XC70
Have you read the whole thread? Taller sidewall is a bad idea.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 03-21-2014, 08:09 AM   #19
Rudy@Tirerack
Moderator
Rudy@Tirerack's Avatar
My Ride: 1-800-428-8355 X4664
No, a 235/50R18 will not fit. Even if it did, a taller sidewall in itself would not reduce road noise.
Refer to 'Rudy/E46Fanatics' as your previous contact when you order online. Credit E46Fanatics.com by clicking here.
Rudy@Tirerack is offline   Reply With Quote
Old 03-21-2014, 01:34 PM   #20
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
No. Do not run a 235/50/18.
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
rims 18, tire fit, tire sizes, tires
