Thread Tools Search this Thread Rating: Thread Rating: 51 votes, 4.90 average. Display Modes
Old 02-17-2012, 11:57 AM   #201
DougL3NC
My Ride: 2000 323Ci
Originally Posted by forzam View Post
For you guys that use catestefy software, is your INPA in English?
Yes, completely
DougL3NC is offline   Reply With Quote
Old 02-17-2012, 12:00 PM   #202
DougL3NC
My Ride: 2000 323Ci
Originally Posted by TerraPhantm View Post
Adapter is fine. You can also apparently jump a few pins in the 20-pin connector so that you can just use the OBDII port
Adapter came today...will post info when I get the chance to go play!
Old 02-17-2012, 04:19 PM   #203
DougL3NC
My Ride: 2000 323Ci
OK, got to play in Progman for a bit. Connected, read the Key/Car Memory and I started to code. I coded Lights flash on Lock, ReLock after 2min, and auto-lock after 8km/h. It says it sucessfully coded, but the Flash and ReLock don't work. I did the coding with the car running cause several people said they were able to do the individualization with the car running.
What gives?
Also, Progman doesn't let you do the corner marker delete...which program does?
***needless to say, the adapter to use the 20-pin got me a HELL of a lot further this time!***
Old 02-17-2012, 04:21 PM   #204
stevenluczynski
My Ride: Is Steel Blue
What gives?
NCS expert, But its wayyy more in-depth than Pa soft
stevenluczynski is offline   Reply With Quote
Old 02-18-2012, 01:52 PM   #205
KP46
My Ride: 318i Touring
Just recevied this and got all software installed. Can anyone tell me if my car should be switched on and running while doing the diags or using INPA?
Or just set key to position II?
cheers
KP46 is offline   Reply With Quote
Old 02-18-2012, 05:07 PM   #206
jeagolf
My Ride: 04 330Ci Vert
cheers
Depends dme testing won't let you in the on position so position 2 is required. I do most my diagnostic stuff with the engine running.
jeagolf is offline   Reply With Quote
Old 02-18-2012, 05:09 PM   #207
jeagolf
I wish I could freaking program with this stuff. Total HD format new windows new everything and here is the crap I get with progman. Ideas??
Old 02-18-2012, 06:19 PM   #208
KP46
I havent tried this progman yet. but are you sure you got USB cable in correct port? VMWare network settings all configured correctly for that virtual machine? and ini files saved in right places? including system32 folder?
Old 02-18-2012, 06:22 PM   #209
TerraPhantm
My Ride: M3 & ZHP
Guessing you have an aftermarket head unit? Progman won't work unless you have factory radio or nav.
Old 02-18-2012, 06:38 PM   #210
Guest021715
Account closed.
The weird thing that happened to me was that only one side of the laptop's USB ports worked with these programs.
Like I said, consider the USB slots in the back of your Desktop's motherboard having priority over the "slave" ones in the front of the PC.
Old 02-18-2012, 07:08 PM   #211
jeagolf
Here is my latest winkfp issues. And yes I have an aftermarket head. I still have the old one I guess I can pop it back in to program.
ID:	437699   Click image for larger version
Old 02-18-2012, 08:05 PM   #212
Drewfus2101
My Ride: N/A
So it looks like there is SOME bits and pieces of good info in this thread, but unless you know how to pick it out, it's not very helpful.
For the people who are trying to figure out how to use ANY of the SW programs listed, you should really be over at Bimmerforums in the Diagnostic section, reading every thread that you can find. I've spent months figuring out how to get INPA, WinKFP, NCSexpert, Progman, and SSS/GT1 to work. It only took that long because I would get frustrated and give up.
There is much more info and detailed instructions over there. It's all over there, it will just take time.
Drewfus2101 is offline   Reply With Quote
Old 02-18-2012, 08:22 PM   #213
jeagolf
I got further trying the update section. I actually saw a screen I've never got to befor but then nope!
Old 02-18-2012, 11:11 PM   #214
TerraPhantm
My Ride: M3 & ZHP
What process are you using to import the data?
Old 02-19-2012, 10:58 AM   #215
jeagolf
i have tried it 3 different ways.
1. using the import function.
2. Copying and pasting into the folders themselves.
3. both 1 and 2.
I think my DME and some of the other modules have some issues and can not be determined or identified.
sometimes using DIS it will say that my DME is not communicating. But sometimes it does.
yesterday I tried a clean whipe on the my win 7 machine. I will try again today whiping my xp machine and trying it that way.
Old 02-19-2012, 11:09 AM   #216
TerraPhantm
My Ride: M3 & ZHP
No your dme is at the latest software.
This is how the import process should be done:
In winkfp use the import assembly line data function and point to the data folder of the chassis you are using.
Now, copy the files from sp-daten-e46/sgdat to the EC-APPS/NFS/sgdat folder. Copy files from the ECU folder to the ECU folder in Ediabas.
Do not copy and paste anything to the data folder
Old 02-19-2012, 12:00 PM   #217
jeagolf
Sorry for misleading this is what I am doing not pasting anything into the data folder I am sorry.
This has me wondering however...
I have been importing the "WHOLE" data section. Not just the chassis I have been working on.
So in winkfp I select import then I go to sp-daten-e46\e46\data
and I import the whole data folder. Should I just be importing the MDS451 folder?
Old 02-19-2012, 12:32 PM   #218
TerraPhantm
My Ride: M3 & ZHP
No, you should be importing the whole data folder. When I said "for your chassis" I was referring to E46 as opposed to E39
What zb number are you actually trying to use?
Old 02-19-2012, 12:37 PM   #219
TitaniumCranium
/// Limitless
TitaniumCranium's Avatar
My Ride: 2002 BMW 330Ci
This is caused by Device Manager assigning COM1 to a specific USB port. Plug in the USB head; open Device Manager; locate Ports (COM & LPT) in the list; open up the COM port associated with the USB head. If it's not COM1 you can change it through the properties. IFH Server has a hardware assignment to COM1.
/// MODS
Old 02-19-2012, 01:49 PM   #220
Guest021715
Account closed.
Its not because of that, even when I assigned COM1 it wouldn't work. The right side USB port had to be used, regardless of settings.
I understand its not the case for every laptop, but that's what it took to get working.
