Thread Tools Search this Thread Rating: Thread Rating: 5 votes, 4.00 average. Display Modes
Old 10-01-2012, 03:23 PM   #481
Wickedly
My Ride: BMW 2003 325i
Hello guys,
Trying to upgrade to EU2. and setting up my WinKFP, after I put the last 7 digits, it brings up to the screen below. Do I pick default or the ECU = 19....
Also I bought the CD from first post (romanian seller) however it came with winKFP 5.0 and I read in this thread that we need at least 5.1.6 so I download an updated version online that comes with WinKFP 5.1.6 but it came within BMW Standard tools and it upgraded all those programs that I already had from the CD I bought. Could you let me know if this is ok or what I did pretty much ****ed me up and now I should delete everything and re-start everything back from the CD even though is an older version of WinKFP. Also I my battery charger should be here on wednesday so just trying to be ready for the day to jump in and do this.
Thanks in advance.
Originally Posted by ac_2007 View Post
EU2 is flashed and running on my DME!
Lets get one thing cleared up. There is a lot of fluff on the CD that comes with the Ebay package if all you're looking to do is flash the DME. You only need two programs, the communication interface, and the E46 "daten":
-EDIABAS
-WinKFP 5.1.6 (no earlier version than this)
-INPA 5+
Wickedly is offline   Reply With Quote
Old 10-01-2012, 03:27 PM   #482
Wickedly
Also, for the people that have headers and no cats, would you first upgrade to EU2 and then install headers or viceversa? I'm kinda stuck on that because I won't install headers till this weekend.
Old 10-01-2012, 04:06 PM   #483
Wickedly
Steven, I'm trying to reinstall everything. I've had no problems so far, and the car connects fine.
Only thing is, when I open up INPA there are no models listed. I only have F1 for Information, F2 for Script.
Do you have any idea how I import the models list? I read it somewhere, but can't find the link right now.
looks like after upgrading from online, now mine is the same, only shows information and script. Any clue how to fix it?
Old 10-29-2012, 01:16 AM   #484
egyclick
My Ride: e46
hello, mount Inpa.5.0.2.ISO with Daemon tools and go to the mounted drive in My computer, navigate to Referenz\Install\Instprog.exe
after you do that the models will appear in Inpa menu, if you bought it on ebay from catastefy http://www.ebay.com/sch/catastefy/m....p2047675.l2562
you should have some videos that show these steps
regards!
egyclick is offline   Reply With Quote
Old 10-30-2012, 11:32 PM   #485
chris98891
My Ride: '01 325i
Send a message via AIM to chris98891
Anybody done any work with Windows 8? I've got INPA running fine on Win7 64bit with a Belkin F5U409, but I'd really like to switch to 8.
-Chris
chris98891 is offline   Reply With Quote
Old 10-31-2012, 02:06 AM   #486
egyclick
My Ride: e46
it will work just like on win7
Old 10-31-2012, 07:45 AM   #487
albarran9
My Ride: E46, E53, E90
Originally Posted by Pete_repete View Post
Also I cannot install NCSexper, it says The version of this file is not compatible with the version of Windows you're using. Check your computers system information to see whether you need x86 ( 32 bit) or x64 (64 bit) version of the program. and the contact the software publisher." I am going to contact the seller to see if he can just install everything for me remotely.
I had that problem with the PA Software. The reason was that it was written for Win XP which was in 32bit and not 64. Once I reinstalled Win 7 in 32 it worked just fine. Some programs have to be run in "compatibility mode", or in 32bit if they are older programs that were written for 32 bit and cannot work on 64.
albarran9 is offline   Reply With Quote
Old 11-03-2012, 09:56 PM   #488
flashmeow
Banned User
My Ride: E30-E46-E90-E90M-F30
guys,
I need your help. My husband and I just finished our 330i engine swap into our 323i (MS42). See my thread if you are curious.
We successfully programmed the car DME to the 328 software as of 5 mins ago.
We were told that the 328 (USA) current version is 7526757 and the latest 323 (USA) current version is 7526754. Based on our research this info seems to be accurate. However, when we updated our software we read our current DME version and it was different from the latest 323 (USA version). the version that we wrote/flash over was 7526765. Therefore, this lead me to believed that there is a newer 328 (MS42 USA) flash out there.
can anyone confirm or deny?
thanks
this lead us
Old 11-12-2012, 04:52 PM   #489
vlcmstnsct
My Ride: 02/2002 330i c/p/s
I just want to say thanks to everyone who has contributed valuable information in this thread and has made it possible for myself and others to reflash our DMEs. I was able to re-flash my 330i with the EU2 tune successfully last night...THANKS! BTW I was using my Asus laptop running Windows 7 64 bit.
vlcmstnsct is offline   Reply With Quote
Old 11-12-2012, 04:55 PM   #490
vlcmstnsct
Hello guys,
Thanks in advance.
I had to do the same thing as you and I successfully re-flashed my 2002 330i last night. I only had a 6 amp charger...it worked fine and it didn't take 20 minutes either. Many have re-flashed without a charger. I used to custom tune my WRX and re-flashed that damn thing 100+ times and never once used a charger. If your worried about your voltage use a fast computer and go for a long drive beforehand.
Old 11-23-2012, 11:17 PM   #491
shwagon
shwagon's Avatar
My Ride: 325it 5-speed
The only thing im a little confused about is the part number for the ECU using the link on the first page..
http://bmwfans.info/parts/catalog/E4...me_programmed/
Am I going to be using the first part number listed? It make no reference to EU2 and the only ones that do are for SMG tranys
*Edit*
Its not letting me post the link... After I select my production using Europe, the first part number that comes up has a empty description box.
Originally Posted by Reedo302 View Post
What an unending cavalcade of rampant virgin Mom's-basement-dwelling douchebaggery... Wow.
My Gun Builds: AR-15, GSG-522-SD, Saiga 308
shwagon is offline   Reply With Quote
Old 11-30-2012, 04:51 PM   #492
chris98891
My Ride: '01 325i
I got INPA and everything to install fine, but I'm having a helluva time with the F5U409. I have the win7 64bit driver that i used to get it working before, but Win8 just sees it as an unknown device. I even waited to plug it in until after installing the driver.
anybody have any ideas?
-Chris
Old 12-01-2012, 01:23 AM   #493
egyclick
My Ride: e46
try a different approach, on the FTDI website there is a .exe setup that will install drivers automatically: www.ftdichip.com/Drivers/CDM/CDM20824_Setup.exe
and theier statement regardinf Win8:
Support for Windows 8
There is no official release of Windows 8, but FTDI have validated that our drivers will function correctly with the Developer Preview and the Consumer Preview of Windows 8.
regards!
Old 12-02-2012, 12:14 PM   #494
chris98891
My Ride: '01 325i
Thanks for the response! I still can't get it to work though....I've tried uninstalling all drivers, running ccleaner, then running the program, and just about every combination in between
-Chris
Old 12-13-2012, 12:15 AM   #495
xcar360
Past Site Sponsor
My Ride: BMW 318i
BMW OPPS Diagnostic Tool $823.00 & free shipping at Xcar360
http://www.xcar360.com/bmw-opps-opps...diagnosis.html
xcar360 is offline   Reply With Quote
Old 12-13-2012, 12:29 PM   #496
SteadyMobbin
My Ride: ImolaZHP 6spd M/T
After reading through 10 pages I am very confused. But still would like to give this a shot. I will be getting ebay headers in a few weeks. The cable from ebay in post one is all I need? Along with the programs suggested. I am looking to eliminate the cel from no cats that is all.
SteadyMobbin is offline   Reply With Quote
Old 12-13-2012, 01:21 PM   #497
Stiggles
Stiggles's Avatar
My Ride: Was built Fri 13th
Yes, buy the cable/software package from the Romanian eBay seller, catestefy.
Then follow the DIY I posted within the first few pages. Any software errors you encounter, keep reading my posts.
Its not too difficult once you understand which program does what.
Stiggles is offline   Reply With Quote
Old 12-13-2012, 11:31 PM   #498
SteadyMobbin
Alright my bad I missed that post. Thanks!
Old 12-14-2012, 07:26 PM   #499
Mflara20
My Ride: 2002 330xi
Mflara20 is offline   Reply With Quote
Old 12-15-2012, 09:06 AM   #500
Mflara20
My Ride: 2002 330xi
Hey I need some help installing installing WinKFP so I can do EU2 euro flash on my 02 330xi. Everything went well until this error shows up (pic in the bottom,) but the DIY says I have to "load it up" but I can't find what his talking about anywhere on my computer. I try to type that file (SGIDC.AS2) name on notepad but it says "file not found." What I'm missing? Where or how can I load that file in notepad? I have WinFKB version that came with the software and I need to update it or download 5.1.6 version, does anyone know how to do this?
Here's the website I found this
http://forums.bimmerforums.com/forum....php?t=1590483
ID:	482151   Click image for larger version
ID:	482152   Click image for larger version
