Thread Tools Search this Thread Rating: Thread Rating: 51 votes, 4.90 average. Display Modes
Old 12-15-2012, 12:24 PM   #501
Nickvjr
My Ride: 2004 330Ci Conv.
Send a message via AIM to Nickvjr Send a message via Yahoo to Nickvjr
You need to change the 'folder options' for windows so you can see all the file extensions. Then find the 'SGIDC.AS2' usually in the NFS\DATA folder. With the file extension '.AS2' visible change it to a '.txt' extension so you can open the files in Notepad. Inside Notepad you can exclude the extremely long program command string (or strings but there is usually only 1 or 2) by placing a ';' in front of the string. After that is done save the file, convert the extension back to '.AS2' then try opening WINKPF again. The errors should be gone now and you should have access to the program functions. Good luck!
-Nickvjr
2004 BMW 330Ci Convertible
Nickvjr is offline   Reply With Quote
Old 12-16-2012, 12:49 AM   #502
Mflara20
My Ride: 04 330i
I try what you told me and I still cant find the folder!! I'm getting so upset
Mflara20 is offline   Reply With Quote
Old 12-16-2012, 12:51 AM   #503
Nickvjr
PM me & I will see if I can walk you through this part.
-Nickvjr
Old 12-23-2012, 03:02 PM   #504
ShonTheBest
My Ride: 2001 330i
I installed everything and tried to update. The number I got from bmwfans for EU3 is 1214 7545670. I start WinKFP, Click Comfort mode, Click Enter ZUSB and enter 7545670 but I get this error.
ShonTheBest is offline   Reply With Quote
Old 12-23-2012, 03:31 PM   #505
TerraPhantm
My Ride: M3 & ZHP
Did you import the assembly line data? It works fine for me
Old 12-23-2012, 05:28 PM   #506
ShonTheBest
My Ride: 2001 330i
I followed this thread, Downloaded the files from here
Now getting this.
Old 12-24-2012, 03:38 PM   #507
ShonTheBest
My Ride: 2001 330i
I got it to work. I didnt update the BMW tools. I will update the DME later and post results.
Old 12-25-2012, 04:03 PM   #508
ShonTheBest
My Ride: 2001 330i
Ok Fellas here is a BIG PROBLEM. I got everything to work but everytime I try to update, I get this error. I removed everything and installed everything 3 times. The car wont start, it just cranks. Please help.
It start but fails at different %. Max I saw was 28%. I disabled the firewall but still getting this.
Old 12-25-2012, 10:14 PM   #509
xcar360
Past Site Sponsor
My Ride: BMW 318i
Thanks for making this thread!
xcar360 is offline   Reply With Quote
Old 01-12-2013, 01:17 PM   #510
lrz14
My Ride: 2001 BMW 325ci
So does anyone have a download link for winkfp 5.1.6 version i have looked everywhere and can't find it. Would appreciate it thanks!
lrz14 is offline   Reply With Quote
Old 01-12-2013, 01:23 PM   #511
chris98891
My Ride: '16 X6 50i
Send a message via AIM to chris98891
Pretty sure it comes built into the installer for INPA.
-Chris
chris98891 is offline   Reply With Quote
Old 01-12-2013, 03:02 PM   #512
lrz14
Does anyone know how to run bmw special tools 2.5 on windows 7 or does it only work on windows xp?
Old 01-12-2013, 03:07 PM   #513
Guest021715
Account closed.
Works on 7, its called BMW Standard tools, and have you read the first 5 pages?
This thread keeps going in circles. These answers have been given dozens of times already.
Old 01-12-2013, 10:23 PM   #514
lrz14
Yes sir i have bought the cord from the Romanian seller than installed everything but only thing that i cant get to work is winkfp. I downloaded the bmw special tools 2.5 like you said on pg.4 but this is what i get...?
Name:	Screen shot 2.jpg
Old 01-13-2013, 12:14 AM   #515
Guest021715
Account closed.
Needs to be run in XP compatibility mode, as an administrator. Right click the .EXE file and you'll find it in properties.
Old 01-13-2013, 12:52 AM   #516
lrz14
Originally Posted by ac_2007 View Post
The FTP server where I got it from is down.
Google BMW Standard Tools 2.5.1.0, a link comes up from TPB. The file is only about 25mb. I don't want to get in trouble for posting torrents.
Once you have the daten files:
1) Copy files from "SP-Daten-E46\Ecu" to "C:\Ediabas\ECU"
2) Copy files from "SP-Daten-E46\Sgdat" to "C:\EC-APPS\NFS\SGDAT"
3) Follow the instructions here to import daten files into WinKFP (5.1.6)
Honestly, if it doesn't work after this just delete it all from your C drive and start fresh with the newer version of BMW Standard Tools.
Thx for the help bro im almost set up just wanted to know if for step 1 & 2 do I overwrite the files currently in the files or put them in with the files already in there?
Old 01-13-2013, 02:07 PM   #517
Guest021715
Account closed.
Overwrite the files. What you already have in the Daten files may be out of date or incomplete.
Worst case scenario, it overwrites the same files that are already there.
Old 01-13-2013, 05:43 PM   #518
lrz14
Ok got it working thnx, just to clarify. In one of the post you say to make sure that you "Ensure you disable UIF writing" than a couple posts later you posted that quote from TerraPhantm and he says to "Restart WinKFP. Click "configuration". Make sure "fast baudrate" is unchecked. Make sure "Programming Voltage", "Show Programming Voltage", "Test Checksum", "activate Bootsectorupdate", "UIF Write after data", "UIF Write after Program", and "UIF Write in Comfort Mode" are checked." I have a 01 325ci and i looked it up on bmwfans.info and im guessing that 12 14 7 564 762 is the right for my car am i correct?
Old 01-14-2013, 06:51 AM   #519
stevenherr83
My Ride: 2001 bmw 330i
Hey I see your in pa and got a question for you..I ordered mine from the same person/store on eBay and it was supposed to arrive between Dec 31-Jan 9th but still hasn't arrived..so my question to you is do you remember how long it took to get yours? I'm getting a little worried(just a little as it is coming from Romania LOL)
Sent from my LG-P999 using Bimmer App
stevenherr83 is offline   Reply With Quote
Old 01-14-2013, 09:58 AM   #520
Guest021715
Account closed.
We have the same year vehicles, except mine is a sedan.
I used 12 14 7 564 452 for my car and it works well. The one you posted would work too, but the one I mentioned was used up until a later year.
I wouldn't be worried about things coming FROM Romania, as opposed to you sending something there.
I also don't get the lols. You would be surprised how amazing of a country it is, and how modernized it has become.
Catestefy has a reputation to uphold. Be patient.
