BMW USB OBD Diagnostic thread - Page 27 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 51 votes, 4.90 average. Display Modes
Old 01-14-2013, 11:35 AM   #521
lrz14
My Ride: 2001 BMW 325ci
Originally Posted by stevenherr83 View Post
Hey I see your in pa and got a question for you..I ordered mine from the same person/store on eBay and it was supposed to arrive between Dec 31-Jan 9th but still hasn't arrived..so my question to you is do you remember how long it took to get yours? I'm getting a little worried(just a little as it is coming from Romania LOL)
Sent from my LG-P999 using Bimmer App
Well I bought mine the 12 of Dec and it didn't get here till Jan 6 and I thought for a while that I wasnt going to receive it but eventually emailed the seller and let him know what was going on so maybe you should do the same. By the way the BMW standard tools is prob out of date so your going to have to down load the newer version just google BMW standard tools 2.5 as ac_2007 has been recommending, and its the torrent file.
lrz14 is offline   Reply With Quote
Old 01-14-2013, 11:45 AM   #522
lrz14
So do I "enable" UIF writings or follow what it says in the quote to "disable" UIF writings?
Old 01-14-2013, 11:56 AM   #523
Guest021715
Account closed.
That's up to you.
If you enable them, the ECU will say you have the software version you will flash.
If you disable them, the ECU will say you have your original software version.
You only have a limited number of UIF writes, so use them wisely.
I disabled mine.
Old 01-14-2013, 01:38 PM   #524
shwagon
My Ride: 325it 5-speed
Im sill confused on which program number I should use...
I have 04/2001 325i (wagon) with headers/deleted SAP and a 5-speed transmission.
Any one got a suggestion on which one to use?
I'm leaning toward 12 14 7 564 764 or 12 14 7 564 454.
If there is something else I should use please let me know.
Originally Posted by Reedo302 View Post
What an unending cavalcade of rampant virgin Mom's-basement-dwelling douchebaggery... Wow.
My Gun Builds: AR-15, GSG-522-SD, Saiga 308
shwagon is offline   Reply With Quote
Old 01-14-2013, 01:48 PM   #525
lrz14
Originally Posted by ac_2007 View Post
That's up to you.
I disabled mine.
Ok sounds good so i was reading a little more about winkfp and i found this link,http://forums.bimmerforums.com/forum....php?t=1572349, do i need to do this before the flash as well? Also the OP is post #48 says to clear adaptations for gearbox, where is that option in INPA or is it needed?
Old 01-14-2013, 03:35 PM   #526
lrz14
Does any one know which option i should click? Default or the other?
Old 01-14-2013, 05:58 PM   #527
lrz14
Figured it out, works great and best of all no more check engine light!! Thanks for all the help!!
Old 01-14-2013, 06:38 PM   #528
shwagon
Im having trouble getting DIS to read control modules in the car. The seller set everything up for me and it looks like the head is reading using DiagHead but once i select e46 (in DIS) it will not auto connect and if I manually select my car and try to run a read on the DME it gives me an error 200.13. Ive double checked the USB com settings and everything seems correct. I have also checked with a OBD II scanner and it connects no problem. I noticed that there is an LED on the USB cable but it doesn't blink...
Any help would be great.
Old 01-14-2013, 06:48 PM   #529
themoveforward
My Ride: e46 330xi
I've been trying to get my K+DCAN cable to with with Progman, INPA, and NCS, but it won't recognize it. Found out I had to bridge pins 7+8, but the car still won't recognize the cable. Any suggestions?
http://imgur.com/jf00T_nr_
themoveforward is offline   Reply With Quote
Old 01-15-2013, 01:52 PM   #530
mystic.bertie
My Ride: 320d 2002 saloon
guys - i cannot get DIS to work when the cable is connected to my car, i can get inpa to work fine so my cable and port settings are fine.
i have spent ages searching the internet and you tube but i have not found the answer.
I start diaghead and then vmplayer, diaghead connects automatically. I run the registry fix on my cd too. I dont know what else to do.
i get this error below
mystic.bertie is offline   Reply With Quote
Old 01-16-2013, 05:13 PM   #531
stevenherr83
My Ride: 2001 bmw 330i
Yeah I got it on the 8th just didn't realize it until today LOL..and I updated the bmw standard tools and it messed everything up..I couldn't connect to the car anymore kept saying there was no connection to the diagnostic head..checked all the settings and they were the same..so I'm going to reinstall everything and try again..but I did have one error when I initially tried to code the car..I got the "it is necessary to use edic/icom for the connected vehicle for programming/coding control units. For this purpose, you must close the progman session and select one of the requested interfaces "..
I followed sellers instructions on clicking vm/snapshot/press here to start sss 3 times faster-configured icom..but still didn't work..
stevenherr83 is offline   Reply With Quote
Old 01-16-2013, 05:33 PM   #532
TRIPLE_O
My Ride: E46 Coupe
You are using an ICOM?
________________________________________
BMW Coding, PM Me For Details
3 Series Owners Manuals
http://www.bmwsections.com/docs/3series/
For Sale (Exterior Lights)
_________________________________________
Originally Posted by gonzaga707 View Post
My boyfriend left on vacation and left me his 95 328i for me to use while he is gone. He had 2 keys, I lost both of them this week...
..sincerely Jenny
TRIPLE_O is offline   Reply With Quote
Old 01-16-2013, 08:06 PM   #533
Weste46
My Ride: 2001 330ci
..I have PaSoft, sorry to bring it up in this thread.. but could I use the USB connection that came with my PaSoft for this software? Can you even download this software online, or just order in a disc? Thanks!
Sent from my DROID RAZR MAXX
Corbeau FX1 Pro & CR1, Ultimo front coils, Rob43 9-click rear shocks, Swift 10k rear springs, Meyle FCA's, AKG 95a FCA, 75d rear subframe, Powerflex 95a RTA, 95a RCA, ECS 88a diff., ECS SS brake lines, LTW FW, M3 engine mounts, UUC 5sp black mounts, BMW Performance SSK, open-loop EU2 tune, CAI, headers, x-pipe, minus ~180lbs.
Weste46 is offline   Reply With Quote
Old 01-16-2013, 08:18 PM   #534
stevenherr83
I using the cable that I bought from the eBay ad in the first post..so I have no clue LOL..just followed the fix for any errors that would pop up that the seller included on the discs that came with it..I'm at a loss as I can't even get it to connect to my car now!
Old 01-16-2013, 08:21 PM   #535
stevenherr83
This is the error message I originally got:
And this is the only thing that was different from the settings in the video but not sure if its the problem and if so how to change it?
Old 01-22-2013, 01:51 AM   #536
E46Snowball
My Ride: 330i
Sorry for not reading through this whole thread, but is there any set backs to flashing the eu2 catless tune before installing the headers? I just got the cable along with my headers not too long ago, but will not have the money to install the headers for a little while. In the mean time was hoping to run this eu2 tune.
2003 330i
Imola Red
Zhp Package
6 speed
E46Snowball is offline   Reply With Quote
Old 01-22-2013, 10:19 AM   #537
Wickedly
My Ride: 2016 BSM ///M2
Can someone confirm that if you have a car from march 2003 or newer then the EU tunes are not possible? Asides from an aftermarket tune
Wickedly is offline   Reply With Quote
Old 02-06-2013, 03:02 PM   #538
Weste46
My Ride: 2001 330ci
Why do you need a battery charger hooked up while flashing? I only have a 1amp charger.
Old 02-08-2013, 09:17 PM   #539
tinman831
My Ride: M3
Attachment 486415
Attachment 486416
Did you find a solution to this?
tinman831 is offline   Reply With Quote
Old 02-08-2013, 09:22 PM   #540
GolfingDuck
My Ride: 540 & 330Ci M Sport
Because if your battery dies during the flash you could be in trouble.
GolfingDuck is offline   Reply With Quote
