Thread Tools Search this Thread Rating: Thread Rating: 51 votes, 4.90 average. Display Modes
Old 01-23-2012, 04:19 PM   #61
Guest021715
Account closed.
Originally Posted by forzam View Post
AC what year is your E46? I have an 2004 that runs MS45. So I guess I can't flash to the EU version.
I have a 2001. The tune I flashed was only used from 2003-2005 according to bmwfans.info. If you have MS45, just look through the tunes in the last month of 2005.
Originally Posted by stevenluczynski View Post
Could you pm me or post where you got the latest BMW standard tools
Honestly, I don't even remember. I've been up since yesterday figuring everything out. A quick google search points to a torrent on TPB.
I just sent FastHackem a few links that may help you, since the ftp server seems to be down (maybe that's where I got BMW Standard Tools from?). Tell him to forward you the message.
Old 01-23-2012, 04:29 PM   #62
FastHackem
My Ride: E60 M5
Done.
The Mind Is A Terrible Thing.
2006 M5
2005 Impreza WRX
2002 330i
1983 944
FastHackem is offline   Reply With Quote
Old 01-23-2012, 07:32 PM   #63
mystert
My Ride: 2003 330Ci
Well its been a couple days and a full tank of gas running the EU3 tune on my 9/2002 330ci. Im not really noticing much of a difference now. I think some of the initial differences that are felt come from the resetting of the adaptation values. Now that they have re-adapted to my driving style its like the same car it was before i tuned it.
If you have headers and use the EU2 tune, this is a great fix for the CEL issue or if you have a SMG M3 and can load the CSL transmission software (including launch control) but for the EU3, not really sure its worth the bang for the buck, other than the top speed limit change and the fact u can tell your friends your running EU spec software.
One thing to note, if you look on the BMWFans.info site, you can see the latest MS43 software for EU3 tune is also the same number for the EU4 tune, at least when you use 9/2002 330ci European Coupe.
MysterT Huntington Beach, CA
mystert is offline   Reply With Quote
Old 01-23-2012, 10:01 PM   #64
stevenluczynski
My Ride: Is Steel Blue
how did you guys get past this when updating the Daten files?
stevenluczynski is offline   Reply With Quote
Old 01-24-2012, 02:32 AM   #65
Guest021715
Account closed.
[IMG]http:/ 1199.photobucket.com/albums/aa466/stevenluczynskie46/error.jpg[/IMG]
Make sure you're running WinKFP version 5.1.6. Also open up NPV.DAT in Notepad and delete line 2.
I did not have this problem the second time around when installing from BMW Standard Tools 2.5.1.0
Old 01-24-2012, 06:43 PM   #66
stevenluczynski
so I still cannot get past these errors
Could you Pm me where and witch exact software and guides you used?
Ive tried installing the tools from several different sources and still get this error
Old 01-24-2012, 07:02 PM   #67
Guest021715
Account closed.
The FTP server where I got it from is down.
Google BMW Standard Tools 2.5.1.0, a link comes up from TPB. The file is only about 25mb. I don't want to get in trouble for posting torrents.
Once you have the daten files:
1) Copy files from "SP-Daten-E46\Ecu" to "C:\Ediabas\ECU"
2) Copy files from "SP-Daten-E46\Sgdat" to "C:\EC-APPS\NFS\SGDAT"
3) Follow the instructions here to import daten files into WinKFP (5.1.6)
Honestly, if it doesn't work after this just delete it all from your C drive and start fresh with the newer version of BMW Standard Tools.
Old 01-24-2012, 07:07 PM   #68
stevenluczynski
Thanks for the help, I really appreciate it!
Old 01-24-2012, 10:11 PM   #69
stevenluczynski
Alright i got it working! Ill be testing it out tomorrow!
Old 01-25-2012, 11:45 AM   #70
Guest021715
Account closed.
Good to hear buddy, now make sure your batt voltage is steady around 14v before you start flashing.
Old 01-25-2012, 02:04 PM   #71
spencers
My Ride: 2006 330i
It's not worth the price of free?
You'd notice a greater difference with 93 octane.
spencers is offline   Reply With Quote
Old 01-25-2012, 06:42 PM   #72
stevenluczynski
Another day another error, I have everything set up but Winkfp is not establishing a connection with my Dme error(2020)
Old 01-28-2012, 05:02 PM   #73
jeagolf
My Ride: 04 330Ci Vert
I can't get my digi head.exe to work on my MacBook pro. (booted up in xp pro mode only!) everything else works fine but can't start the digihead.exe? Any ideas??
jeagolf is offline   Reply With Quote
Old 01-28-2012, 05:12 PM   #74
forzam
My Ride: 04 325Ci
Do you mean diaghead.exe? If so try installing Microsoft .NET 2.0 framework.
forzam is offline   Reply With Quote
Old 01-28-2012, 05:16 PM   #75
jeagolf
Yeah sorry darn auto correct!! I do a lot of work with digi and pro tools so my phone has learned digi.
Thanks for reading what I meant to say! I'll try it tonight when I get home.
Old 01-28-2012, 05:53 PM   #76
jmejia4
My Ride: 330i
Got my DIS and SSS working, if anyone in Albuquerque area needs assistance pm me
jmejia4 is offline   Reply With Quote
Old 01-28-2012, 08:27 PM   #77
jeagolf
That fixed it thanks!!!
Old 01-28-2012, 09:38 PM   #78
stevenluczynski
I still cant get the thing to work
I've tried so many times i lost track how many times I've cleared and re-installed Winkfp
I still get an error saying it cannot contact the ecu, I believe it has something to do with the Daten files
Old 01-29-2012, 12:04 AM   #79
forzam
My Ride: 04 325Ci
Can you connect to the ECU using INPA?
Old 01-29-2012, 01:26 AM   #80
Guest021715
Account closed.
This.
If your Ignition and Battery icons are black in INPA, the device is connecting properly. At least then you can narrow down the problem.
Also, my laptop HDD just went out
So I purchased a new one, partitioned it, and installed XP just for all my programming software.
I'll be redoing this whole install over the weekend, as well as PA Soft.
