Thread Tools Search this Thread Rating: Thread Rating: 51 votes, 4.90 average. Display Modes
Old 01-29-2012, 09:28 AM   #81
stevenluczynski
My Ride: Is Steel Blue
Originally Posted by ac_2007 View Post
This.
If your Ignition and Battery icons are black in INPA, the device is connecting properly. At least then you can narrow down the problem.
Also, my laptop HDD just went out
So I purchased a new one, partitioned it, and installed XP just for all my programming software.
I'll be redoing this whole install over the weekend, as well as PA Soft.
Yup, INPA is connecting without a problem, SO the next thing would be the files in WInkfp, I followed the guide you posted but it seems like to me that I'm still doing something wrong in importing the Daten files. When redoing the whole install could you post the steps and maybe take some screen shots?
stevenluczynski is offline   Reply With Quote
Old 01-29-2012, 09:32 AM   #82
stevenluczynski
I will try this again today and write down everything i do, maybe you guys can spot what i'm doing wrong
Old 02-01-2012, 12:16 PM   #83
jeagolf
My Ride: 04 330Ci Vert
Originally Posted by stevenluczynski View Post
how did you guys get past this when updating the Daten files?
Well after several days of messing about I am still at the starting spot! I get the exact same errors on both laptops.
Also I have several modules in my car that just do NOT want to respond to ANYTHING! I can use DIS, INPA, CARSOFT, PROGMAN, WInkfp, either one of my laptops and they will NOT communicate with the software. The DME being the one that pertains to this thread.
I then thought I would simply reflash with PROGMAN due to my WInkfp not booting up anymore, and I could not even reflash the US origonal DME back to my unit.
So I tried to do something basic and simple like program key settings. It would fail bringing up all the options that go with my car.
I have also tried to program with Ignition off, position 1, and position 2, with a batt charger on the batt.
I have also uninstalled all the software and reenstalled it. As I mentioned it appears that it is only partially working as some fields will auto populate and others will not, or it will straight up fail.
Yesterday was the most I was able to mess with it putting about 5 hours into testing and trouble shooting.
jeagolf is offline   Reply With Quote
Old 02-01-2012, 12:24 PM   #84
stevenluczynski
I got past those errors when I downloaded BMW tools form another source, than I got stuck with winkfp not being able to communicate with my dme
Old 02-01-2012, 12:29 PM   #85
stevenluczynski
What key position are you supposed to turn to when programming?
Old 02-01-2012, 02:58 PM   #86
Guest021715
Account closed.
I did it in key position 2. With all accessories turned off to save battery.
Didn't get a chance to reinstall everything this past weekend or I would've posted steps.
I'll just be following the instructions I've already posted in this thread.
One more thing, when running everything off Win7, every program was run in XP SP3 compatibility mode and as Admin.
Old 02-01-2012, 07:28 PM   #87
jeagolf
Downloaded tools from another source same issue. However my inpa is a newer version or something cause I don't even have an e46 option! So......
Old 02-01-2012, 08:07 PM   #88
POLECAT
My Ride: 2001 330ci M-T
+1
BMW For Life
POLECAT is offline   Reply With Quote
Old 02-01-2012, 08:10 PM   #89
Jmhockey1920
My Ride: 2002 325i
Btw stevenluczynski...what % is your windows :o
Jmhockey1920 is offline   Reply With Quote
Old 02-01-2012, 08:17 PM   #90
jeagolf
I reenstalled my dis and progman, I then did a replacement for my dme and it seems to have reflashed it. I'll try in a min to reflash with the euro dme. Anyone know how long it takes to update the tranny software? Im going on 20 min looking at this screen.
Old 02-01-2012, 08:38 PM   #91
stevenluczynski
I don't understand what the % windows is,
I'm running windows xp with a windows minimal theme to increase performance
Old 02-01-2012, 08:44 PM   #92
POLECAT
what can i do that ?
http://www.ebay.com/itm/BMW-USB-OBD-...ht_2855wt_1396
i will install a headers 2 weeks later. when i install it, eml will light on. can i delete eml light ?
BMW For Life
Old 02-01-2012, 08:48 PM   #93
Guest021715
Account closed.
Press Shift + F9
Old 02-01-2012, 08:50 PM   #94
jeagolf
Are we missing something simple? I remember reading someplace that for dis you need the straight USB obd cable but to program you need to switch pin 7&8. I wonder if this is my issue as well as others who have the Romania eBay cable?
Old 02-01-2012, 08:52 PM   #95
Jmhockey1920
My Ride: 2002 325i
Sorry. I meant what % of tint do you have on your car? Is that 15% or 5%? Sorry again
Old 02-01-2012, 08:52 PM   #96
stevenluczynski
well AC_007 was able to reprogram his with the cable so I don't think so, I believe its a software Issue
Old 02-01-2012, 09:03 PM   #97
jeagolf
Ok I guess it's delete, reenstal tomorrow.
I'll try this.... And see what happens.
Old 02-01-2012, 09:04 PM   #98
jeagolf
Oh key position is 2
Old 02-02-2012, 01:27 AM   #99
POLECAT
anyone help ?
BMW For Life
Old 02-02-2012, 09:20 AM   #100
jeagolf
anyone help ?
I don't think so there are 3 options to do what you want. Check the fist post. http://forum.e46fanatics.com/showthread.php?t=571990
