SES light with rough idle - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Xi Forum
Old 01-19-2012, 07:12 PM   #1
tom04330xi
My Ride: 2004 330XI
About a month ago while driving I noticed a distinct sulfur smell. It smelled as if it was coming from the heater vent and lasted for just a moment. The car seemed to be running fine otherwise. About two weeks later the SES light came on and then went off the next day. Now after another couple weeks the SES light stays on all the time. I scanned it and got the following codes.
PO313 misfire detected with low fuel
PO304 cylinder 4 misfire detected
PO171 sytem too lean bank 1
PO174 system too lean bank 2
PO303 cylinder 3 misfire detected
PO302 cylinder 2 misfire detected
I cleared the codes and it ran perfectly for about a day or so. The light came back on when I pulled out in traffic and accelerated quickly. It instantly started running rough again. The car is a 2004 330XI with 110,000 on the clock. I have a small valve cover leak that may be creating a vacuum leak, not sure. I did notice that the right exhaust pipe blows out at about twice the pressure as the left, not sure if they are seperate pipes coming back from the engine or what. I was thinking clogged CAT or vacuum leak (brakes are brand new but seem to be struggling to stop the car). Any ideas?
tom04330xi is offline   Reply With Quote
Old 01-19-2012, 09:07 PM   #2
Kubica
My Ride: 2003 325xi
Check for tears in the boots between the intake and throttle body.
Old 01-22-2012, 03:27 PM   #3
tom04330xi
My Ride: 2004 330XI
Well, it finally died. It was trying to stall at every stop light and sounded like it was running on 3 cylinders all the way home. Now when I start it, I hear a wierd spark knock noise from the top right side of the engine. I also hear a fairly loud air hissing noise. Any ideas?
Old 01-22-2012, 09:22 PM   #4
SamDoe1
My Ride: 4cyl of fury
You either have not enough fuel or too much unmetered air. Like Kubica said, check the intake boots for tears. Also check the MAF for proper function. To test that, unplug it and try to start it again. Don't run it for too long this way. Also, if there aren't tears and such clean out the intake track and replace the air filter. Check the DISA for proper operation and clean the throttle body and idle control valve.
Other things to check is the fuel pump and filter. Pop the back seat up and see if you can hear the pump running. Replace the fuel filter no matter what if you haven't already and have more than 60k on the clock. Next thing to check is the spark plugs, make sure they aren't fouled and if they are replace them. Check your spark plug boots for cracks, tears, or other abnormal defects. Replace if bad.
Last thing to get to is the injectors, make sure they are clean. If not, try to find some way to clean them or just buy new ones. Check the wiring and connections to all the injectors.
Old 01-23-2012, 05:01 PM   #5
tom04330xi
My Ride: 2004 330XI
I found a hole in what I think is the lower intake boot. It's in the big tube running from the maf sensor that's two piece. It's in the small part that y's off the lower tube right at the engine. I just hope it didn't hurt the engine driving it with so much unmetered air going in. Does anyone have a pic of the lower intake boot for comparison? Also, where's the best place to buy a new one?
Old 01-23-2012, 05:59 PM   #6
Kubica
My Ride: 2003 325xi
Type in the last 7 digits of your VIN# at realoem.com and search for part numbers. Buy them from pelicanparts.com or bmwpartssource.com.
After you replace it, clear the codes and change the oil.
Old 01-29-2012, 05:16 PM   #7
jfoj
My Ride: 330CiC, M5, X5, E93
You should read this post carefully
http://forum.e46fanatics.com/showthr...6&highlight=50
Old 03-09-2012, 02:33 PM   #8
Gus330vrum
My Ride: 330ci
tom, did you solve the issue?
Gus330vrum is offline   Reply With Quote
Old 03-09-2012, 07:46 PM   #9
tom04330xi
My Ride: 2004 330XI
Yeah, the lower intake boot was torn and the DISA valve was broken. The center rotating section was broken off at the base and thus not closing properly. Runs great now, thanks to everyone for the help.
