Old 01-23-2012, 05:26 PM   #1
ModBargains III
ModBargains III's Avatar
My Ride: E46
ModBargains.com l ST V1 Coilovers | Your Inexpensive Solution to Coilovers!
ModBargains.com is proud to present to the E46fanatics community the ST V1 Coilovers. Looking for that perfect balance between comfort and performance, styling, and handling without sacrificing ride quality and comfort? Your search is over, from the company that brought you the KW V1, V2, and V3, we have the perfect ST Coilover to suit your needs. Coilovers are the BEST suspension solution for aftermarket applications, simply because all of the parts are designed to compliment and function perfectly with each other. As opposed to playing the guessing game of buying springs and shocks separate.
Questions? Need Help? Give me a call here at 714-582-330 x 8002 or ask for Jurrian
ST Variant 1:
When it comes to choosing the perfect coilover, don't be cheap, do it right the first time; choose ST height adjustable Variant 1 Coilover Kits. Fully threaded shock bodies will enable you to customize your ride height for that aggressive stance that you've always wanted, without sacrificing safety, functionality, or driving performance. Each application is expertly engineered, designed, and test under road and of course track conditions in Europe to guarantee it meets and exceeds the Highest Quality Standards of the German TÜV.
Galvanized Steel:
Coming from the makers of KW suspension systems the only main difference between the ST Variant 1 and KW Variant 1 is the steel they use. While KW uses Stainless Steel for their shock housing, ST uses Galvanized Steel. However, this does not mean a drop in quality, durability, or appearance. Although coilovers that use galvanized steel are more prone to corrosion due to environmental influences (i.e. mixture of salt water); those in the lower states: California, Texas, Florida, Nevada, etc. don't have to worry about corrosion. Those in the mid to upper States that snow still don't have much to worry about as long as they do not drive in heavy snow conditions upon where salt is used on roads. to further ensure those with doubt about Galvanized Steel, ST has corrosion resistant zinc plating on all of their threaded strut housings for further protection.
About Coilovers:
A coilover suspension basically gives you a matched lowering spring and shock absorber combination with the added benefit of adjustable ride height and spring rates through a movable spring perch or perches. Coilovers are to your car's advantage by reducing unsprung mass, increasing suspension travel, and allowing the car to be corner balanced.
ST Variant 1 Advantages:
Matched damper and springs rates
Corrosion resistant zinc plated threaded strut housing
All around height adjustability
Integrated elastromeric bump stop
Self centering dust boot for insured durability
Applications:
3series (E46) 2WD Sedan, Coupe, Convertible, Touring
M3 (E46) Coupe + Convertible
Sean S. | Sean@ModBargains.com |(714) 582-3330 ext 8009
We Specialize In: BMW Brakes | BMW Suspension | BMW Parts | BMW Exhaust Experts |
BMW Wheels In Stock | BMW Intake Experts
Hours
Check out our Blog for updates & discounts!
ModBargains III is offline   Reply With Quote
Old 01-29-2012, 06:21 AM   #2
bimmer4me01
My Ride: '95 E36 M3 Track Car
How much for a set for a 04 330i zhp sedan shipped to 94608?
bimmer4me01 is offline   Reply With Quote
Old 01-30-2012, 11:35 AM   #3
ModBargains III
My Ride: E46
PM coming!
Hours
Old 01-31-2012, 09:27 AM   #4
Deebo16
My Ride: nothing yet
Same as above shipped to 33328?
Deebo16 is offline   Reply With Quote
Old 01-31-2012, 11:42 AM   #5
ModBargains III
My Ride: E46
Hey,
Sure thing! PM coming!
Hours
Old 02-10-2012, 12:49 AM   #6
Obayhan
My Ride: E46 M3 Convertible
e46 m3 vert Price for 19128 with shipping ?
Obayhan is offline   Reply With Quote
Old 02-10-2012, 11:45 AM   #7
ModBargains III
My Ride: E46
PM coming!
Hours
Old 02-12-2012, 11:17 PM   #8
cbmw325
My Ride: 330ci
price for 330ci shipped to 78236 and one E9X M3 Style Wheel 19x8.5... 35 offset
cbmw325 is offline   Reply With Quote
Old 02-12-2012, 11:54 PM   #9
JordanBMW
My Ride: 320i 2002 steel blue
Send a message via MSN to JordanBMW
Price shipped to canada V7L 1Y1.
Maybe a price to avoid duties or how much duties are roughly?
JordanBMW is offline   Reply With Quote
Old 02-13-2012, 12:03 AM   #10
Russianwill
My Ride: '05 BMW 330ci
Price shipped to 30013 2002 330ci
Russianwill is offline   Reply With Quote
Old 02-13-2012, 12:05 AM   #11
Junior2345
My Ride: 330ci
Price for a 2001 330ci shipped to 08873?
Sent from my PC36100 using Bimmer App
Junior2345 is offline   Reply With Quote
Old 02-13-2012, 05:29 AM   #12
e46freak609
My Ride: 325 ci
how much for 2004 325ci coupe shipped to 08201?
e46freak609 is offline   Reply With Quote
Old 02-16-2012, 12:09 PM   #13
ModBargains III
My Ride: E46
PM coming!
Hours
Old 02-25-2012, 12:43 PM   #14
bigstyle
My Ride: '01 325ci
pricing for 2001 325 shipped to 27858. what are the spring rates?
bigstyle is offline   Reply With Quote
Old 02-26-2012, 12:13 AM   #15
rpg2279
My Ride: 2004 M3
coilovers
How much for a 2004 M3?
rpg2279 is offline   Reply With Quote
Old 02-26-2012, 11:00 AM   #16
COBYATCH
My Ride: 03 325i
price shipped for an 03 325i sedan to 95132? thanks!
COBYATCH is offline   Reply With Quote
Old 02-26-2012, 06:23 PM   #17
Imola.ZHP
My Ride: Imola ZHP
Two questions...
1) About how many miles could one expect to get out of these? I drive a lot!
2) Shipped quote to 38103 (Memphis, TN) please!
Thanks!
-- '03 330i ZHP
-- Marcus
Imola.ZHP is offline   Reply With Quote
Old 02-27-2012, 11:49 AM   #18
ModBargains III
My Ride: E46
Spring rates are progressive
Originally Posted by Imola.ZHP View Post
Two questions...
Thanks!
Depends on how you drive it, but these ST's are made by KW so you know they'll last a very long time, they're built to last.
PM coming for all of you!
Hours
