MasterC17 - 2002 M3 SMG Street Legal Track Car Project - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 02-08-2012, 08:48 PM   #21
Hit_Apex
My Ride: 2006 M3 ZCP
Did you completely remove the fat Nav/Stereo harness that runs from front to back? I have mine pulled up fully intact from the rear to the driver floor area. From there I'm trying to figure out next steps, whether to remove the dash or whether it can be worked out without cutting.
2006 SG ZCP M3 6MT TCKline/Ground Control-SS Stepped-Crackpipe-Borla-4.10
2008 AW E90 335i 6MT Quaife-3.46-PSS10-Code3IC-RissDP-BBSCH-245/275 RE01R-JB3 2.0B
Hit_Apex is offline   Reply With Quote
Old 02-09-2012, 06:38 PM   #22
MasterC17
My Ride: hates A/C & Sunroofs
Currently I have not messed with the harness much. I do believe it is POSSIBLE to remove it without taking apart the dash/front carpet. Right now I am trying to find a way to retrofit it back to the standard radio. I will let you know what I end up doing.
MasterC17 is offline   Reply With Quote
Old 02-09-2012, 06:39 PM   #23
MasterC17
Installed the Carbon Fiber Sunroof Insert today. Install was a sinch! Just used the 6 factory bolts and bolt holes and had it installed in under 10 minutes. No more terrible wind noise! Just need to RTV it later.
EDIT: Also found a guy to build the roll bar for me. So should have that done within a month. First event is March 18-20 at VIR, but I may end up missing that one, we'll see.
Old 02-11-2012, 12:19 PM   #24
MasterC17
Got that stupid drain plug out and replaced with a new one! Obviously did an oil change at the same time
Old 02-11-2012, 04:57 PM   #25
MasterC17
I just realized how easy it is to remove the dash; you know what that means, bye-bye front carpets, bye-bye evaporator, bye-bye navigation harness, hello radio harness!
Old 02-12-2012, 04:30 PM   #26
MasterC17
Started taking the dash out, except the stupid round airbag got me again. I always have trouble getting that thing out for some reason. Oh well. I promise pictures tomorrow, and hopefully the dash will be gone.
Old 02-13-2012, 07:43 PM   #27
MasterC17
I know, I know, terrible pictures, I apologize.
Carbon Fiber Sunroof Delete:
Dash:
Other Stuff That Will Be Replaced:
At the end of the day I got the dash out of the car. Then I realized what an undertaking I am about to go through. I didn't think getting the carpet out would be this difficult, oh well.
P.S. I think this project is turning into the BARELY LEGAL Track Car Project
Old 02-14-2012, 07:56 PM   #28
MasterC17
Before:
After:
Taking the heater box out tomorrow. Then remove the evaporator, carpet, sound deadening, etc.
Old 02-15-2012, 04:54 PM   #29
serdar255
My Ride: '01 325ci / '90 325i
Where did you buy the carbon fiber insert?
For coding, custom shift knobs, and vinyl stickers: PM me
serdar255 is offline   Reply With Quote
Old 02-15-2012, 05:17 PM   #30
sweet jones
My Ride: CLK, S54 E46 Touring
Lovin' this thread. Looking forward to the future updates. Nice sn btw. I work in SA on the C17 program.
Sent from my SPH-D700 using Bimmer App
E46 Touring
S54/6 speed, air suspension, Burning Black Work Brombachers, etc etc etc
sweet jones is offline   Reply With Quote
Old 02-15-2012, 07:52 PM   #31
MasterC17
http://www.ebay.com/itm/Carbon-fiber...#ht_500wt_1156
I bought it from Chad on eBay. The fitment is nearly spot on and it only weighs 4lbs! Easy alternative to a full CF Roof, albeit you don't save quite as much weight. Roof w/ Sunroof is ~55lbs. Roof w/o Sunroof is ~20lbs and CF roof is ~7lbs if I recall correctly.
Thank you
Old 02-15-2012, 07:58 PM   #32
MasterC17
So, today the front carpet came out. I was going to pull the heater core to do it, but the hoses would NOT budge. Facing the fact that even if I did get the hoses off, there was no way in hell I was getting them back on, I decided to pursue pulling the front carpet without taking the heater core out. I'm glad to report I was successful. Now, yes, the evaporator will still be in the car, but for the measly 5lbs it weighs I figure I'm better off not touching it. Of course, this whole endeavor is probably only going to save me about 25lbs, so to be honest, it is NOT worth it. Oh well, I learned a lot and had fun. Now the question is can I put it all back together correctly? Also, I can now switch over the Nav harness to a Radio harness without cutting or anything and I will be starting to remove all the sound deadening tar in the car (here we go heat gun!). So long as everything goes back together correctly it was worth it.
Old 02-16-2012, 02:40 PM   #33
serdar255
Thanks and sweet build i can't seem to fix my damn sunroof and im considering this but id get it painted body color. Thanks again
Old 02-16-2012, 05:40 PM   #34
MasterC17
It's really not too bad to do and the DIY on M3Forum can help you out. Just take off the A, B, and C pillar covers, detatch all the stuff from the headliner, drop it down, 12? bolts holding the sunroof in, drop it out, install the CF sunroof delete (6 bolts) and reinstall headliner.
Old 02-17-2012, 07:55 PM   #35
MasterC17
Square Apex ARC-8's 18x9.5 ET35
Wiring harness won't be in until Monday
Old 02-18-2012, 09:14 PM   #36
MasterC17
Put the dash bar back in the car today. Made sure I knew what all the wiring went to and got organized. Getting some dry ice for the sound deadening soon.
Old 02-18-2012, 10:58 PM   #37
vaio76109
My Ride: Race Cars
In my experience a heat gun works better than dry ice, and xylene/xylol works well for removing the residue.
vaio76109 is offline   Reply With Quote
Old 02-19-2012, 06:10 AM   #38
MasterC17
Interesting, I talked to a couple people and they both used dry ice with better results. I have access to both, so we'll see which works the best. Thanks
Old 02-19-2012, 05:03 PM   #39
MasterC17
Put more stuff back together and threw in the dashboard for whatever reason. Getting the steering column back together I had to get the brake light switch out of the way and ended up breaking one of the tabs on the little plastic piece. Come to find out you can't buy the plastic piece seperately so now I have to spend $35 for the whole sensor. Woohoo. I assume most people just drill out the rounded bolt on the left side and replace it with the same style bolt that is on the right side so you can dismount the steering column easier which is what I'm going to do at this point so I don't have to break more things. I'm also thinking of ditching the adjustable steering column and adjusting it to where I want and bolting it in like that. If I want to change it just need a 13mm and 10mm. Getting the radio wiring harness in tomorrow so I can swap that in and put the dash the rest of the way together. Then I just get the sound deadening out and it's ready for the roll bar! Anyway, a picture.
Old 02-19-2012, 05:44 PM   #40
CJW2OO4
CJW2OO4's Avatar
My Ride: 2007 MCoupe
Send a message via AIM to CJW2OO4
Will you help me swap a s54 into my z4 coupe?
http://i.imgur.com/zHSdA.jpg
BECAUSE STANCE CRAP
CJW2OO4 is offline   Reply With Quote
