Thread Tools Search this Thread Rating: Thread Rating: 83 votes, 5.00 average. Display Modes
Old 01-25-2012, 01:49 AM   #1
jjrichar
Modded ///Member
My Ride: 330 CiC, 330i
Project: M54 engine
Links to parts of the project
Disection of an Idle Control Valve
http://forum.e46fanatics.com/showthread.php?t=1043323
Versatile Torque Wrench
http://forum.e46fanatics.com/showthr...7#post14300427
Crankshaft
http://forum.e46fanatics.com/showthr...6#post14278286
Pistons and Conrods
http://forum.e46fanatics.com/showthr...9#post14278249
Hydraulic LIfters
http://forum.e46fanatics.com/showthr...7#post14251457
Rear Crankshaft Oil and Seal
http://forum.e46fanatics.com/showthr...3#post14238223
Timing Chain Cover
http://forum.e46fanatics.com/showthr...1#post14238211
Vibration Damper, Front Crankshaft Oil Seal
http://forum.e46fanatics.com/showthr...4#post14238204
Oil Pan and Pump
http://forum.e46fanatics.com/showthr...5#post14238195
Valves
http://forum.e46fanatics.com/showthr...0#post14235440
Coolant Pump and Thermostat
http://forum.e46fanatics.com/showthr...6#post14230966
Head
http://forum.e46fanatics.com/showthr...8#post14230928
Timing Tools 1
http://forum.e46fanatics.com/showthr...3#post14115793
Timing Tools 2
http://forum.e46fanatics.com/showthr...2#post14115822
Camshafts
http://forum.e46fanatics.com/showthr...0#post14098020
Engine Timing
http://forum.e46fanatics.com/showthr...2#post14097982
Vanos
http://forum.e46fanatics.com/showthr...1#post14082281
Idle Control Valve (ICV)
http://forum.e46fanatics.com/showthread.php?t=901978
Throttle
http://forum.e46fanatics.com/showthread.php?t=901968
Intake Manifold
http://forum.e46fanatics.com/showthread.php?t=901967
Knock Sensors
http://forum.e46fanatics.com/showthread.php?t=901979
Oil Separator
http://forum.e46fanatics.com/showthread.php?t=901972
Valve Cover
http://forum.e46fanatics.com/showthread.php?t=901980
Oil Filter Housing
http://forum.e46fanatics.com/showthread.php?t=900804
Fuel Injection Rail
http://forum.e46fanatics.com/showthr...4#post14036694
Power Steering Pump
http://forum.e46fanatics.com/showthread.php?t=899351
Starter Motor
http://forum.e46fanatics.com/showthread.php?t=899366
Hi all, I'm about to start a project.
I'm currently living overseas, and the plan is to stay here for the next couple of years. My beloved 330 convertible is in storage back home, and I'm going a bit crazy not getting my hands dirty.
I have read my Bentley manual for both my car and my wife's over and over just to keep myself busy, but I just need to get my hands on something.
So I've bought myself something to play with.
I stumbled across an old M54 engine (2.5L). My plan is to pull it to bits. It came with a few accessories, which I plan to pull to pieces as well.
In the past when I did any work to my car, I'd take a bunch of photos and write all over them in photoshop so if I ever had to do it again, I would have some instructions.
I'm planning to do the same thing with this engine.
So what do I want to do?
1.Find out how it all works.
2.Pull it apart and put it back together numerous times so that I can find out which way I think is the best way to do it.
3.See if I can come up with some alternatives to the numerous BMW tools that are required to do the job.
My intentions are not to steal anyone else's glory by taking their ideas as mine. Obviously there is a mountain of information on this site and others that is fantastic.
A lot of it I have read and have no idea where to find it again. So I just want to create bunch of photos and notes for later.
If people are interested I'm going to put it all up here.
This is going to take some time so don't expect the crankshaft out in a month. I'm expecting it to take at least a year, if not more. When I finish a particular job, I'll post it up.
Below are a couple of initial photos I took of it with components marked. This may be of some help to some who are just starting to work on their E46.
What is obvious to me is that working on an engine that is on an engine stand is much easier than one that is in a car's engine bay. That being said, some of what I might write as being the way to do it may be bollocks because of the issues when the engine is installed. Feedback will be appreciated. Also, I'm sure I'll be asking for some help along the way. Thanks in advance.
Finally, just for clarity, I'm not going to talk driver/passenger side. I'm an Australian, and I drive from the right hand seat, so things would get confusing very quickly. Also right/left depends on where you are looking from. I'll just speak about the intake side, and exhaust side.
Name:	Engine front 1.jpg
ID:	433816   Click image for larger version
Name:	Engine exhaust side 1.jpg
ID:	433817   Click image for larger version
Name:	Engine inlet side 1.jpg
ID:	433818   Click image for larger version
jjrichar is offline   Reply With Quote
Old 01-25-2012, 04:30 PM   #2
G-Hots
My Ride: ///M3 & 328ci
Send a message via AIM to G-Hots Send a message via MSN to G-Hots
Great idea. Keep them pictures coming
G-Hots is offline   Reply With Quote
Old 01-25-2012, 11:15 PM   #3
ddaniel1
CWO4 (Ret)
ddaniel1's Avatar
My Ride: 328i, M3, 525iT
These are awesome, read all three, keep them coming....
ddaniel1 is offline   Reply With Quote
Old 01-25-2012, 11:19 PM   #4
flashmeow
Banned User
My Ride: E30-E46-E90-E90M-F30
Wow great pictures and very informative. I will reference your pix for my project
sent from HTC EVO
Old 02-15-2012, 01:57 AM   #5
moranor
My Ride: 323i
awesome stuff
moranor is offline   Reply With Quote
Old 03-29-2012, 08:08 AM   #6
Gus330vrum
My Ride: 330ci
Keep coming! coolant drain plug on the block. :0 did not now!
More info..info..read..^_^
Photos!!!!
Great write up OP! GJ...
Gus330vrum is offline   Reply With Quote
Old 03-29-2012, 09:27 AM   #7
lakedude90
My Ride: 03' 325i
possible sticky? tons of info and its great to have it all in one place
lakedude90 is offline   Reply With Quote
Old 03-29-2012, 09:57 AM   #8
ddaniel1
CWO4 (Ret)
ddaniel1's Avatar
Seconded, great idea.
Old 03-29-2012, 11:37 AM   #9
My Ride: Lexus
good stuff. ive been wanting to do this too.
Old 03-29-2012, 10:00 PM   #10
latitude39
My Ride: 2002 325xi (163k)
Outstanding annotated photos and descriptive text. After reading a few of the articles, I now know 10x more about by 325 than I did yesterday.
What a wonderful collection of work! Thank you. I'll continue reading with great interest.
Sticky, yes!
latitude39 is offline   Reply With Quote
Old 04-09-2012, 01:06 PM   #11
LeMansteve
My Ride: '04 330i 6mt ZSP ZPP
Dude, you are the man. If only I had a garage, engine stand, and worthy engine, I would be doing the exact same thing.
Old 06-23-2012, 05:47 PM   #12
e30mike
My Ride: 325i
Great thread, thanks for all the hard work!
e30mike is offline   Reply With Quote
Old 08-16-2012, 03:59 PM   #13
POLECAT
My Ride: 2001 330ci M-T
excellent friend thanks for all.
BMW For Life
POLECAT is offline   Reply With Quote
Old 09-26-2012, 03:25 AM   #14
mpower009
My Ride: Tial Of Dragon
Thank you, thank you for all your hard works putting these DIY thread for us. I plan to do oil separator and oil filter housing gasket replacement, your DIY really give me confident to tackle these jobs or other jobs. Godbless!
LET'S ROLL
mpower009 is offline   Reply With Quote
Old 10-10-2012, 09:39 PM   #15
tehcbass
My Ride: bmw e46 323i
awsome thread man, good shet
Long Nights and Sandy Beaches
tehcbass is offline   Reply With Quote
Old 02-22-2013, 07:04 AM   #16
madunix
My Ride: Silver 01' BMW 325ci
thank you
madunix is offline   Reply With Quote
Old 03-04-2013, 12:44 PM   #17
vlcmstnsct
My Ride: 2002 E46 330i
Brilliant...
Sent from my SCH-I535 using Bimmer App
Regards,
Aaron
2002 330i 5spd
VIR Oktoberfast 2013
vlcmstnsct is offline   Reply With Quote
Old 08-30-2013, 06:29 PM   #18
JuniorT
My Ride: 01 325i & 06 330 ZHP
Had down time all day at work today and read all of these.
Bookmarked. Thank you good sir for your time!
JuniorT is offline   Reply With Quote
Old 09-03-2013, 02:32 PM   #19
///BM3R
My Ride: 330ci...///M3 soon
Dude nice thread....It will help me learn more about my 330CI
///BM3R
///BM3R is offline   Reply With Quote
Old 04-02-2015, 02:52 PM   #20
DEADF15H
My Ride: 2001 325i Auto
Bump for great thread
Sent from my SAMSUNG-SGH-I317 using Tapatalk
DEADF15H is offline   Reply With Quote
