Old 01-25-2012, 01:34 PM   #1
BimmerDoc
My Ride: E46 AWD, ///M Coupe
Send a message via AIM to BimmerDoc
How do I change turn signal bulbs e46 sedan
This is for face lifted sedan, the pre facelift was easy. I'm just not seeing the correct stuff on this car I guess
BimmerDoc is offline   Reply With Quote
Old 01-25-2012, 05:47 PM   #2
russisghey
Banned User
My Ride: a jeep
The front corners have a screw on top that you loosen and they pull out then you disconnect the bulb holder from the light
russisghey is offline   Reply With Quote
Old 01-28-2012, 06:08 PM   #3
BimmerDoc
I still don't get it? Also do you know what bulb I use in a face lifted sedan amber corners OEM
Old 01-28-2012, 09:36 PM   #4
My325XI
My Ride: 03 325XI Sprt Prem
Open the hood, there is a hole in the top of the fender where you will put in the screwdriver to loosen the screw, then the corner light will pull out with some wiggling. Process is the same as the pre-facelift... Just the pre-facelift has a push down clip in the fender and the post-facelift have a screw in the fender.
2003 325XI 5-speed ZSP ZPP
My325XI is offline   Reply With Quote
Old 01-28-2012, 11:26 PM   #5
BimProject
My Ride: '02 325i
There's a link on YouTube or refer to this.
http://www.my330i.com/mod2.php
BimProject is offline   Reply With Quote
