Old 11-25-2016, 09:39 PM   #1
cwarel
My Ride: 330ci coupe
Turbo project for a budget
So I finally got tired of NA and i want some chooh chooh noises coming from under the bonnet , so i decided to go turbo because it hella lot cheap then buy those 5k kits superchargers , I dont want to go the way of a bolt right up , I like making stuff.
So I decided to go ebay for NOW with a stock engine internals for now also.
So far Ive gathered few things
440ci Injectors off 2000 volvo v40 1,9L turbo Ive got 8 of the injectors and since they all came from junkyard , im buy 2 sets of O-rings and filters for injectors , and before that I will clean them by applying 12 volts to the injector to open it up and blow some brake cleaner or something like that through it.
I bought Innovate LC-2 AFR 52mm gauge full kit
And I went for the most easiest turbo install as far as i think http://www.ebay.com/itm/151810657663...%3AMEBIDX%3AIT
This turbo has internal wastegate , its has a T3 flange , and a V band for the downpipe because i sort of hate flanges)) Before I put it in the car I will take it apart and check it for quality and maybe modify it.
The O-ring for injectors
http://www.ebay.com/itm/272119137420...%3AMEBIDX%3AIT
And the manifold is a 65 dollar manifold that i bought off ebay that is usually goes for 100 , its a stainless steel one , but I should of taken the cast iron because that would take a beating a lot better , oh well u will learn on my mistakes )))
About the tune is Ive got a ms43 so I will try tune it myself to at least start the car ( but i dont think i need a tune because ive got Audi RS4 Maf in the car hopefully that will help)
So far ive spend 400 bucks , I have intecoolers but i dont have piping so thats gonna be another 100 bucks , and the down pipe i will try to make it myself but im a crappy welder and better leave to somebody else at least first 3 ft of the downpipe , the rest i could hande myself maybe.
The car will be a sleeper , and I will be raising boost on it untill engine blows because ive got 2 more that i gotta get rid off ))) anyways , but i think headgasket will go first and from that point I will built the engine properly ))
So I think this project will cost me max 1000 bucks and ill have some sort of boosted car
What power output i wanna go?> damn idk as far as I could bump the boost go up on that ebay turbo , but i dont think it will make over 350 hp , but we shall see
https://s18.postimg.org/992wl8tvt/s_l1600.jpg the picture of the manifold , and I will do bottom mount
cwarel is offline   Reply With Quote
Old 11-26-2016, 12:16 AM   #2
xi46
My Ride: 2002 330xi ZPP/SP/CW
Subscribed. Interested to see how a budget turbo setup can be done because $4500-$8000 for a FI kit is a lot to spend on a car worth the same amount. Good luck!
xi46 is offline   Reply With Quote
Old 11-26-2016, 05:34 PM   #3
cwarel
Injectors Im gonna use
Siemens Deka 6900371 number I have 8 of them they came off 2000 Volvo v40 turbo
I bought filters and new oil rings for them and i will also clean them
Old 11-27-2016, 04:18 PM   #4
iowna330xi
My Ride: is not yet fast.
Bottom mount turbo right? Don't forget to get a new engine mount so you can actually pipe the intake side of the turbo. Search eBay for e36 turbo engine mounts. Around ~$140
Oh and how are you gonna do the oil feed and drain? That's what I'm trying to figure out now.
iowna330xi is offline   Reply With Quote
Old 11-27-2016, 04:36 PM   #5
cwarel
I will make my own, oil feed comes from Oil filter housing , and drain will either go in oil pan , or the front of the engine cover , cuz oil pan is mad work to take out.
Old 11-27-2016, 04:43 PM   #6
Commanderwiggin
My Ride: 1000rwhp Turbo M3
Old 11-28-2016, 12:56 AM   #7
daniel_f.
My Ride: 330iC
Oil pan is to low You will be left having the oil return line blocked by to much oil. Tap the engine block slightly above the oil pan gasket. Routing the oil return into the front cover is pretty much no option when doing bottom-mount.
I´m currently at baby vacancy!
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 11-28-2016, 03:06 AM   #8
sda2
My Ride: BMW E46 330i Touring
Interesting, how you advise this, Daniel. Many turbo drains go to the oil pan, or even the oil drain plug. (1.8t from VW goes there by default) And a local tuner advises this as well.
I think, as long as your drain is big enough, so at least dash 10 or 12, you will be fine with tapping into the pan.
Gravity wise it shouldn't be a problem, as the oil level inside the pan and the return line is the same.
sda2 is offline   Reply With Quote
Old 11-28-2016, 03:19 AM   #9
daniel_f.
My Ride: 330iC
Well, is there circulation in the oil return if the oil level in the return line is steady?
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 11-28-2016, 03:25 AM   #10
sda2
Afaik its called "kommunizierende Röhren" in German (http://de.wikipedia.org/wiki/Kommuni...de_R%C3%B6hren)
If the level in the drain rises, so does the level in the oil pan.
Old 11-28-2016, 09:56 AM   #11
cwarel
I have an engine in the backyard ill take measurements on it once Turbo arrives its in CA right now , once it gets to me ill bolt up the manifold with a turbo and see what i can do.
Old 11-28-2016, 10:08 AM   #12
cwarel
Should i do a blow through with the RS4 maf or nah?
Old 11-28-2016, 10:37 AM   #13
jd improved
My Ride: charged 330i smg
I don't know how it behaves on a blow through setup. But it is working very well on a draw though setup with a closed loop bypass valve. Also the crankcase ventilation hose shuld be connectet between MAF and Turbo.
jd improved is offline   Reply With Quote
Old 11-28-2016, 11:36 AM   #14
cwarel
I was gonna delete ccv completely , but ill see whats best , its just matter of time when i get the parts to arrive , because i daily the car and I wanna go turbo swap in 1 day and hopefully engines in the backyard will help me with that)_
Old 11-28-2016, 10:43 PM   #15
CarbonZHP
Because Race...Convertible?
CarbonZHP's Avatar
My Ride: used to be an auto
Big dreams there
Modification Thread
Original Car: Silver Grey on Grey, A/T (1 of 186)
As it sits: Silver Grey on Black, M/T (1 of 51)
Instagram: @CarbonZHP
CarbonZHP is offline   Reply With Quote
Old 11-29-2016, 12:10 AM   #16
SK330ci
My Ride: 02 330ci w/ 3 Pedals
Originally Posted by CarbonZHP View Post
Big dreams there
lol Agreed
The 1 day turbo swap because "you daily the car" is about the funniest thing i've read in a long time. Good luck with that.
Mods: Header, CAI, Shark, Koni Sport Struts, Rob43 9 Way Shocks, Big Sway Bar, Special Lowering Springs, 3.38 Diff, PFC Z-Pads, 75 Shot Of N20
E46 M3's are just tasty snacks i eat for lunch.
SK330ci is offline   Reply With Quote
Old 11-29-2016, 05:30 PM   #17
xi46
Yeah that's pretty funny. I really hoped this was for real but anyone who thinks they can turbo their E46 in one day (from scratch, without doing it before) hasn't done enough research.
Old 11-29-2016, 05:33 PM   #18
cwarel
Ive done that before on my friends honda its not just me alone doing the work so dont worry and i was kidding about 1 day swap but 1 week should be plenty if i get everything i need at the same time some pcs havent been shipped even
Old 11-29-2016, 05:57 PM   #19
xi46
Ive done that before on my friends honda...
That's great but you're not slapping a turbo on a Honda. This project is going to be almost totally different and more challenging. I'm sticking around though because I really want you to succeed! What's your plan for tuning?
Old 11-29-2016, 05:58 PM   #20
Commanderwiggin
