Old 02-18-2012, 12:42 PM   #1
hcardona111793
My Ride: 2004 325i
Speaker Rattles, Bass Sucks - HELP! *Already Searched*
hello,
so my speaker system in my 2004 325i is starting to give up on me, the bass sucks, it rattles and sounds horrible. im pretty sure its just the bass, because if i turn the bass off, all the way down, the music sounds alright.
so my question is, what speakers would i have to replace for the bass, and is there a fix for these or would i have to buy new ones. Please let me know, i need to listen to my music with bass.
thanks everyones!
hcardona111793 is offline   Reply With Quote
Old 02-18-2012, 12:50 PM   #2
BeMyWhip
My Ride: 01 BMW 330ci
Check the connection and if theres anything loose first, my door door that sometimes, but after i did the window regulator it went away cause i tightened up the connection.
Always Mod!!!
Founder: 330Ci The 3 litre coupe
BeMyWhip is offline   Reply With Quote
Old 02-18-2012, 12:58 PM   #3
hcardona111793
My Ride: 2004 325i
il check that, it seems as if they blew out though?
Old 02-18-2012, 02:07 PM   #4
Recon2005
My Ride: VF-E 328Ci & 325 E90
Just shove T shirts into the parcel deck above the subwoofer. Rattles will go away.
Vortech // Magnaflow // Hotchkis // H&R
Originally Posted by Forcefed M3 View Post
Could not agree more. I enjoyed my vf kit to the day I took it off. VF best s/c out there. Period
Recon2005 is offline   Reply With Quote
Old 02-18-2012, 02:17 PM   #5
lcoleman
My Ride: '79 Massey Ferguson
It can be the parcel deck vibrating as mentioned, or blown midbass drivers in the door right beneath the handle. Put your hand on those speakers while music is playing and see if the sound changes. They aren't a standard size, so you have to use BSW ones or OE as far as I know.
Old 02-18-2012, 02:22 PM   #6
trj
My Ride: 325Ci
3 tennis balls in the rear shelf would take care of the rattling from the subs from rear.
However, if the door speakers are blown(like mine ) then only option is to replace them.
Old 02-18-2012, 02:40 PM   #7
TR4G-
My Ride: '01 325xi, '90 325iC
One of my rear deck speakers was blown and was buzzing like a fly? (not sure what buzzes liek that lol) So I just unplugged it since i sit in the front lol. Also my drivers side tweets AND mids are starting to buzz. I think I am going to wait it out till its financially sound to either purchase BSW stage 1 (or 2 if theyre out by then) speakers or even just get some dope rainbows or something of that nature. As for bass.... tons of options..
TR4G- is offline   Reply With Quote
Old 02-18-2012, 02:55 PM   #8
boostedisbetter
boostedisbetter's Avatar
My Ride: 2008 S2000, 2009 CBR
You OBVIOUSLY didn't search... This morning I searched for the SAME PROBLEM, used the "tennis ball mod" among the 3 different option I found....
links are allllll over the place.. and BTW the tennis ball trick worked like a CHARM. NOOO rattling !
http://www.e46zone.com/forum/index.php?showtopic=36
GasKing has a Grand National. Ask him and he'll post a picture of it!
boostedisbetter is offline   Reply With Quote
Old 02-18-2012, 03:09 PM   #9
The_Don
My Ride: 2001, 325Ci
http://forum.e46fanatics.com/showthr...ht=Tennis+ball
- UUC Stg. 1 LTW Flywheel - UUC SSK + DSSR - UUC TM +TME - UUC Rear Adjustable Control Arms - UUC Swaybarbarians - AST Sportline II -
- RE Underdrive Pullys - RE FCABs - BMW Performance Control Arms - Shark Injector - EMP High Flow Water Pump - TMS Adjustable Endlinks - K&N CAI -
- M3 Motor Mounts -
For Sale
The_Don is offline   Reply With Quote
Old 02-18-2012, 06:00 PM   #10
violent_bimmer
My Ride: 2001 325i
Send a message via AIM to violent_bimmer
grab some BSW speakers and call it a day. try the midbass in the doors
soon to be at 500 hp
violent_bimmer is offline   Reply With Quote
Old 02-18-2012, 06:04 PM   #11
TekNoire7
My Ride: 328i
If you don't have the money right now do what I did, I disabled both rear deck speakers. You remove the grill, unscrew the bolts, then disconnect the connectors under the speaker. My bass actually sounds pretty good right now, and it was a very simple thing to do.
TekNoire7 is offline   Reply With Quote
Old 02-18-2012, 06:12 PM   #12
SATX_E46
My Ride: 2003 325i
They sell bsw's at best buy?? Or is there any fairly good plug and play speakers out on the market we (I have somewhat the same issue) purchase for the doors and rear??
SATX_E46 is offline   Reply With Quote
Old 02-18-2012, 06:21 PM   #13
lcoleman
http://www.bavariansoundwerks.com/ca.../261/0/Catalog
Make sure you're sitting down when you see prices. Check Audio forum for other alternatives, but aFAIK there are none.
Old 02-18-2012, 08:25 PM   #14
cvx5832
My Ride: 325Ci, 325Cic, C300
That "blown" speaker sound can be misleading. If you're willing to take things apart, do that first. I had a right front speaker and rear subwoofers (HK system) that I swear were gone. Front speaker turned out to be a loose mount (speaker goes on mount, mount goes on door), and the rear sub woofers' entire carrier (the plastic box that carries the HK woofer assembly) was loose on all screws by more than a full turn for some. I also put some additional insulation in there while I had the rear deck apart for painting.
It feels good to crank it up now, and all it cost me was a few hours of my time, aka free.
cvx5832 is offline   Reply With Quote
Old 02-19-2012, 07:42 PM   #15
hcardona111793
My Ride: 2004 325i
Thanks so much for the information guys. im deciding in taking my door and back ones off first to see if its just loose wiring or screws, but how should this be done? i searched and found that i have to take the wholleee door panel off.? is there anything easier like just popping the speaker grill off and going from there?
also, about how much would a BSW speaker system cost me?
Old 02-19-2012, 08:32 PM   #16
lcoleman
Door panel has to come off. You can find BSW prices if you read the thread.
Old 02-20-2012, 11:07 PM   #17
Sweetness
My Ride: '01 325i
Rear shelf speakers, and tweeters. They go first. Rear shelf is about $30 for each speaker from ecstuning.com
They keep moving stuff around on their website...just look hard, it's there
2001 325i ZCW, ZPP
Titansilber Metallic, Black Interior
The 160,000 mile, clean daily driver
Sweetness is offline   Reply With Quote
