Old 01-28-2012, 11:24 AM   #1
Tim13E46
My Ride: 2003 M3
I need some knowledge
Can I get some opinions/advice on performance software? I was settled on getting the conforti shark injector for an 05 325i and then ran accross AA performance software where its possible to get twice as much hp as the shark.. any suggestions?
Sent from my SGH-T989 using Bimmer App
Tim13E46 is offline   Reply With Quote
Old 01-28-2012, 12:54 PM   #2
darksideracer69
My Ride: 01 325ci
twice the hp
oe tuning all the way
IMAG02051
Old 01-28-2012, 12:55 PM   #3
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Twice as much is almost always better !
I've found in cases like this, the SEARCH button is always your best friend.
I'll give you a rolling start, go to page 25 & start reading.
http://forum.e46fanatics.com/showthread.php?t=736943
Welcome to E46Fanatics,
Good luck.
SUMMIT POINT WV 1:24:229 SCCA
Old 01-28-2012, 02:20 PM   #4
Tim13E46
My Ride: 2003 M3
Lol yeah, the shark injector is advertising a 7 hp gain and AA is advertising 15.. And im readin! Thanks!!
Old 01-30-2012, 05:59 PM   #5
bryan@bimmerworld
My Ride: E36, E46
Tim,
Would help to have a bit more information, like mods and your end goal.
bryan@bimmerworld is offline   Reply With Quote
Old 01-30-2012, 06:05 PM   #6
Tim13E46
My Ride: 2003 M3
So far all I have is a catback exhaust and dinan cai, I plan on doing headers and cams before a tune and right before bimmerfest I want it s/c. But as for now I just dont want the headers and such throwing codes because of my cats
Old 01-30-2012, 06:10 PM   #7
bryan@bimmerworld
My Ride: E36, E46
So yes, you will want a tune, especially for cams. A tune with cams, headers, intake, and exhaust will help get the most out of your mods. Which cams will you be running? Schrick? Sunbelt?
Old 01-30-2012, 06:14 PM   #8
Tim13E46
My Ride: 2003 M3
I honestly cant make up my mind on that lol, which would u do for an m56??
Old 01-30-2012, 06:22 PM   #9
bryan@bimmerworld
My Ride: E36, E46
Without checking into exact specs for your car, which I can do tomorrow when I get back to the shop.... easy answer, of the two, Schrick is cheaper and a good cam, Sunbelt makes more power. Schrick, or something, similar would be good for you though for a street driven car. In some cases, with cams (keep in mind) you might need more work, like MAF, injectors, etc, just depends on which way you lean.
If I were doing it in my E36 or E46, I would be putting cams in if I were tracking the car, so Sunbelt.
Welcome to PM me if you'd like.
Old 01-30-2012, 06:35 PM   #10
Tim13E46
My Ride: 2003 M3
The only problem is I cant find either one for a 325i smh, but yeah the more power the better, I should probably get bigger fuel injectors anyway. And thanks for all your help, the cams have had me confused lately
