One xenon projector dimmer than the other! HELP! - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 01-28-2012, 09:34 PM   #1
ttrinh9
My Ride: BMW e46 330i
So i just noticed that my passenger side xenon project head light is dimmer than the other side. I have been searching the forum and came upon to discover that the bulb could be the culprit. Is there anything else that could be causing this? And inputs will be appreciated! thanks!
ttrinh9 is offline   Reply With Quote
Old 01-28-2012, 09:45 PM   #2
tag90
My Ride: 330ci
What year is your car? It could be a burned zkw bowl. Do your projector lenses have a horizontal line going across them or are they completely clear?
Photobucket
"You got a tree in your paint"
tag90 is offline   Reply With Quote
Old 01-28-2012, 10:24 PM   #3
flashmeow
Banned User
My Ride: E30-E46-E90-E90M-F30
there could be two possibilities. 1) your headlight is going bad. you need to get it replace. HID goes dim when they are dying. Usually, you also have to replace the HID in pair (for color matching)
the other possibiilty is the zkw bowl being burnt.
good luck and i hope this helps!
Old 01-28-2012, 10:31 PM   #4
ttrinh9
its a 2002 330i, and yes i do have the line across the projector.
Old 01-28-2012, 10:41 PM   #5
tag90
My Ride: 330ci
Then it is probably just a bulb getting old. Maybe at some point one was replaced and not the other. The line across the projector means they are bosh projectors and you don't have to worry about the bowls being burnt. Replace the bulbs in pairs. Try theretrofitsource.com for bulbs. I recommend the Philips 4300k oem bulbs.
Photobucket
Old 01-28-2012, 10:47 PM   #6
ttrinh9
thanks so much!
Old 01-28-2012, 10:51 PM   #7
flashmeow
Banned User
if your HID bulb is indeed going bad then I recommend getting the Philips 5K. You still get the bluish tint without sacrificing on the brightness. 5K-6K is a safe bet but 4.0-5.0K has the best light output (lumens).
Old 01-29-2012, 12:47 AM   #8
ttrinh9
Now I just drove my car and found out the passenger side headlight is completely not on.. It wouldn't be a ballast issue would it?
Old 01-29-2012, 12:59 AM   #9
carcus
My Ride: 2006 BMW M5
Replace both bulbs from a sponsor. I think a pair of D2S 6000K will fix you right up. Been there done that. DO NOT GO TO BMW FOR BULB REPLACEMENT.
2006 M5 E60, "Lord Vader" Last real NA M series
German Car Fanatic. Colorado ///M Flight member, BMW CCA member.
carcus is offline   Reply With Quote
bulb, bulbs, head, light, xenon
