Thread Tools Search this Thread Rating: Thread Rating: 474 votes, 4.99 average. Display Modes
Old 10-17-2012, 12:25 PM   #41
Brobby87
My Ride: 2003 325i, 1986 535i
Also would like to know if you can code this feature using BMW scanner Version 1.4
Brobby87 is offline   Reply With Quote
Old 10-17-2012, 12:53 PM   #42
E46iT
My Ride: 2004 325i Touring
Originally Posted by ruskisky View Post
I was in a dealership today, tried giving them those part numbers and they said nothing shows up. Maybe the mistake was on the girl's end because I told her I couldn't give her a VIN, etc. I'll order online since I'm not in a rush
in canada when i go to dealership i tell them this part is from a euro spec models and they can order it for me, its a different search within their part system, perhaps you can tell them to search the eruo parts catalog.
E46iT is offline   Reply With Quote
Old 10-17-2012, 01:14 PM   #43
E46-Cabrio
My Ride: E46 330CI Cabrio
That option is also available.
E46-Cabrio is offline   Reply With Quote
Old 10-17-2012, 01:17 PM   #44
Brobby87
Much obliged my friend.
Although sometimes I swear my ZKE menu looks different compared to others ive seen used for explanations. For example not as many options to check on and off. Is this possible?
Old 10-17-2012, 02:26 PM   #45
E46iT
mine is the same as the pic posted, are you sure you are in the rights coding section??
Old 11-01-2012, 02:22 PM   #46
E46iT
My BNIB oem powerfolding bus mirrors arrived yesturday... gonna install them this weekend if the sandy allows
Old 11-12-2012, 08:44 AM   #47
E25i46
My Ride: none
I have a 04 325ci build date 06/04 with power and memory seats and mirrors. I just bought the mirror switch from ecstuning. But does this mean the auto fold function wouldn't work cause I don't have the mirror frames that fold themselves like you guys stated?
E25i46 is offline   Reply With Quote
Old 11-13-2012, 11:57 AM   #48
E25i46
My Ride: none
Is there a visual sign that the side mirrors in my car have power fold with out removing the door panels and everything?
Old 11-28-2012, 10:33 AM   #49
Joost K
My Ride: E46 320Ci M
Hello,
I have read this DIY about power folding mirrors and that has got me interested to do that on my car...
Described a couple of options about which parts are needed in different situations and now I am a bit confused.
My car came out of the factory originally with NO power/memory seats and manual folding NON memory mirrors, it is a 320Ci from 08/2001.
I do have a set of OEM M3 manual folding NON memory mirrors on the car.
I have an option on a pair of OEM M3 full-option mirrors (power fold and problaby memory) with 12 pin connectors.
I want to swap the entire internals because the mirrors I can buy are a different color.
If I do that I will have a set of full option M3 power folding memory mirrors in my cars color with 12 pin connectors.
Now...
What do I need to get the power folding function to work???
Option A: YOU WANT TO INSTALL NON-MEMORY POWER FOLD MIRRORS:
Car's production date is from 09/1999 up to 03/2003-6 PIN/2 PIN CONNECTORS
x1 Heated outside mirror, left P/N: 51168245129 $344.82
x1 Heated outside mirror, right P/N: 51168245132 $344.82
x1 Yellow Switch f mirror adjust./folding back function. P/N: 61318373732 $67.34
x1Control Unit/module outside mirror fold-in function OBSOLETE-P/N: 61358376506
or Control Unit/module outside mirror fold-in function NEW-P/N: 61359177976 $83.78
or
Option B: YOU WANT TO INSTALL MEMORY POWER FOLD MIRRORS:
Car's production date is from 09/1999 up to 03/2003 - 12 PIN CONNECTOR
x1 Heated outside mirror with memory left P/N: 51167003437 $344.82
x1 Heated outside mirror with memory right P/N: 51167003440 $344.82
x1 Purple Switch f mirror adjust./folding back function P/N: 61316901383 $67.34
-And you should already have in your car:
x2 Control units, mirror memory NEW-P/N: 61356916054 $125.69 (x2)
or Control units, mirror memory OBSOLETE-P/N 61356913364 (x2)
The confusion comes from the fact that the car originally came without power/memory mirrors and I have a set of power/memory mirrors to install.
I hope somebody can clear this up for me, it would be of great help!!!
Best regards,
Joost Kuiper
(the Netherlands, europe)
Joost K is offline   Reply With Quote
Old 11-29-2012, 09:10 AM   #50
delmarco
My Ride: 335xi Deep Sea Blue
Send a message via ICQ to delmarco Send a message via Yahoo to delmarco
Joost I sent you a PM
delmarco is offline   Reply With Quote
Old 12-15-2012, 10:41 AM   #51
bgpavlp
My Ride: BMW 320d
Hi,
My car is 320d 09/2002 touring.
I want to install non-memory power fold mirror.
I have:
-Heated outside mirror, left
-Heated outside mirror, right
-Switch mirror adjust - 61318373732
I want to ask,Is this the correct link?
thanks_nr_
bgpavlp is offline   Reply With Quote
Old 01-07-2013, 06:24 AM   #52
tnhl1989
My Ride: 02 330xi(RIP),03 ZHP
How difficult would it be to install power folding mirrors onto a zhp? I was told that the zhp mirrors have ribbons instead of a 12 pin connector.
tnhl1989 is offline   Reply With Quote
Old 01-07-2013, 08:49 AM   #53
sna77
sna77's Avatar
My Ride: BMW
That's exactly what I did in my ZHP. Full DIY here:
http://www.zhpmafia.com/forums/showt...on-programming)
sna77 is offline   Reply With Quote
Old 01-07-2013, 12:44 PM   #54
tnhl1989
Seems awesome Steve.
I guess I should've rephrase my question and stated that I was looking to do a m3 power folding mirror retrofit. Not sure how complicated and difficult that is yet. However, after all this reading and learning about it I am really looking forward to doing this retrofit. By the way I just got a ZHP in the same color.
Old 01-26-2013, 04:16 AM   #55
Tiag46
My Ride: e46
edit
*Wrecking* - Heaps of parts available.
http://forum.e46fanatics.com/showthread.php?t=1103190
Tiag46 is offline   Reply With Quote
Old 02-13-2013, 11:18 AM   #56
ryn004
My Ride: '04 316i Sport
Send a message via ICQ to ryn004
I just manage to complete the retrofit, including the fuse in position 57 in the Fusebox.
Is it factory for the folding mirrors to operate even if the key is not in the ignition?
ryn004 is offline   Reply With Quote
Old 03-27-2013, 04:23 AM   #57
janiki
My Ride: facelift diesel
Hi Delmarco, maybe you should give the clear answer. I'd like to do the memory mirrors retrofit but without memory seats. Do you think it is possible? Want I really want is to fold the mirrors via remote control. Thank for advise to all of us. Johny
janiki is offline   Reply With Quote
Old 03-27-2013, 09:32 AM   #58
delmarco
Hey Johny. Yeah you would just need to add the memory modules in the doors. But I am not sure how not having the memory seats would affect the overall system.
EDIT: But the whole idea of memory mirror is that they work with memory seats. To want one and not the other is not good and not cost effective. There is no additional advantage of having memory mirrors if you don't have memory seats.
I would just get the non-memory mirrors and the non-memory module and call it a day.
Old 03-27-2013, 03:18 PM   #59
Tiag46
My Ride: e46
Yes ryn, this is correct.
If I recall you used the OEM module behind the glovebox, did you need to do any coding to enable this function to work?
Old 04-03-2013, 01:53 PM   #60
delmarco
I have been getting some PMs lately.
Apparently some seller on eBay is selling non-memory mirrors AS memory mirrors but they are NOT memory mirrors.
So when the mirrors arrive in the mail buyers are not seeing 12 pin connectors on them.
Looking at the connectors on these pictures below:
Your mirrors will ONLY have a memory function IF there is a 12 pin connector on the end of the wire leaving the mirrors. So to replace your old (for cars between 1998 - 3/2003) memory manual fold mirrors with memory power fold mirrors you must buy power folding mirrors that have the 12 pin connectors.
Second set of questions I get are from folks with 2003/2004 thru 2006 BMW E46 coupes and sedans and M3s asking what mirrors to get or rather they bought memory mirrors only to realize there is no pin connector plugs present but rather ribbon connectors that looks like they came out a Laptop Computer DVD Rom Drive's connection.
If your BMW E46 is from 3/2003 thru 2006 then your Memory Power Fold Mirrors connectors will look like what you see below:
