Go Back   E46Fanatics > Tuning & Tech > Forced Induction Forum Sponsored by Active Autowerke
Thread Tools Search this Thread Rating: Thread Rating: 4 votes, 4.50 average. Display Modes
Old 04-25-2012, 02:37 PM   #181
BMW_Knight
My Ride: STG2 ZHP,E70 X5(DD)
Send a message via ICQ to BMW_Knight Send a message via AIM to BMW_Knight
I agree with Zak on this.
Thanks to: www.getbmwparts.com www.aatuning.com www.toyotires.com
Eurowerkz Mid-Atlantic Regional Director
Join the Eurowerkz Facebook Fan Site : Click Here
Need your car coded with Euro Options? (Remote Windows up, Corner delete, DRL off, etc.) PM Me
BMW_Knight is offline   Reply With Quote
Old 04-25-2012, 05:37 PM   #182
Rob43
My Ride: 2003 BMW 331Ci, 5spd
Originally Posted by Zak@ActiveAutowerke View Post
.......You may shoot some flames on WOT shifts.
Trip, I will fly to your location to video "FLAMES" coming out the back of your Bimmer ! That would be........Awesome ! ! !
Rob
SUMMIT POINT WV 1:24:229 S.C.C.A.
http://www.vimeo.com/8486878 (Dyno Video)
........add a sh!tload of cowbell.
Old 04-25-2012, 06:55 PM   #183
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
I hate to say it, but that BOV is the wrong part for a "draw through" MAF setup. If the sequence was Compressor - BOV - MAF - Engine, then there's be no problem. But as Zak said, you'll now have an engine that thinks a lot more air is being pushed into it than really is the case, and this is going to cause some really rich running at part throttle and upper RPMs.
If you have cats, it will likely kill them fast as well.
Turbos don't suffer as much when configured like this, because mass flow is controlled my manifold pressure/vacuum. With a SC, mass flow is directly proportional to engine speed...which means at 5000 RPM @ light throttle the compressor will be running pushing a ton of air through the BOV.
Ever wonder why the S65 supercharger kits have 2-3 BOVs? It's because of the mass flow that needs to be bypassed at part throttle. They are also tuned completely differently than this kit.
Sorry to deliver the bad news like this....
Old 04-25-2012, 09:05 PM   #184
TrippinBimmer
My Ride: ZHP Custom Stage 3.5
Your MAF is positioned in front of the blower which is before the BOV. Once the air runs past the MAF it sends a signal telling the DME you have XX/mass of air going in to the engine. When the BOV vents to atmosphere your motor no longer has that much air going towards it and it will run rich. You may shoot some flames on WOT shifts.
Thanks for the info
Rob
I found out today after Starting it up for the First Time Surging Idle I am running -6psi Spring ATM. I am going to try to swap it out for a Tial QR BOV -3psi and go from there.
-Trip
Old 04-25-2012, 09:19 PM   #185
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: Evo, 330Ci, Xterra
My buddy back in college used to vent his Greddy type s on his gs-t. Big flames.
^No longer looks like this
Buy my::
3.46 Differential
Coolant hard line
European Head Unit
Old 04-26-2012, 09:46 AM   #186
TrippinBimmer
I emailed ATP and order a TiAl QR Valve with -3psi spring and will be returning the Q. I guess, I can give up the WHOOSH noises. ;D
-Trip
Old 04-26-2012, 10:13 AM   #187
bluejeansonfire
ninja editor
My Ride: shaken, not stirred
Send a message via AIM to bluejeansonfire
the active valve sounds pretty decent...
You need a standard push valve. The tial is going to try and close at idle, all of their models are based on the same action. A push valve will let pressure bleed, which a little is needed when the throttle body is closed.
I'm sure you already know this. AA kit makes your car sounds completely different at all times. It sounds like something insane has been done to it. You can hear the valve bypassing the whole time and you should, the tial valve might take away that hiss.
2001 330ci TT turbo
e46nonm.com | TechniqueTuning.com | Precision-Sport.com
bluejeansonfire is offline   Reply With Quote
Old 04-26-2012, 10:21 AM   #188
aggieE46
Keep it clean
aggieE46's Avatar
Is there really no way to move the MAF to after the BOV? DSM guys used to install a GM blowthrough after the BOV and very close to the throttle body.
Buy my::
3.46 Differential
Coolant hard line
European Head Unit
Old 04-26-2012, 11:46 AM   #189
TrippinBimmer
Installed the AA BOV and Crank up the Car. When I rev to 5k I can here the BOV Hissss...
Also, is that how my exhaust suppose to sound? Like I have a Cammed Engine
-Trip
Old 04-26-2012, 12:52 PM   #190
aggieE46
Keep it clean
aggieE46's Avatar
Sounds like a lot of belt noise.
Buy my::
3.46 Differential
Coolant hard line
European Head Unit
Old 04-26-2012, 01:12 PM   #191
Activ3
My Ride: gets DRIVEN.
Send a message via AIM to Activ3
No sound on my comp at work, so I can't watch the vid
On flat shifts you'll definitely spit some fire. My car used to catch the rear end on fire on high RPM lifts.
Brady, the only person running a blow-through setup on an e46 nonm is NickG. I believe he uses a Ford maf that's been calibrated appropriately.
-David www.e46nonm.com | My Videos
2000 328i - Custom Turbo tuned by AA
Activ3 is offline   Reply With Quote
Old 04-26-2012, 01:35 PM   #192
332xi
My Ride: too fast e46/330xi
I thought bov's were mainly for Turbo's... is that not correct? cause i would love to have the sound of bov! I have astratmosphere (i think thats what it's called) aluminum bypass, and it works awesome! It almost sounds like a quieter bov.... almost
332xi is offline   Reply With Quote
Old 04-26-2012, 02:46 PM   #193
aggieE46
Keep it clean
aggieE46's Avatar
I didn't know if Anthony could cut into the piping past the BOV and put the MAF in there. Just a thought.
Buy my::
3.46 Differential
Coolant hard line
European Head Unit
Old 04-26-2012, 03:14 PM   #194
joshzhp
My Ride: ZHP--Stock
Sounds fine to me...and yes your cam sounds like it has a large cam when its cold.
joshzhp is offline   Reply With Quote
Old 04-26-2012, 03:33 PM   #195
BMW_Knight
-Trip
I sounds fine, and you will still have a woosh noise. Have you driven it yet?
It should woosh like crazy on shifts. Its blowing straight back into the snail pipe.
Old 04-26-2012, 03:46 PM   #196
Activ3
You can't blow through the OEM maf. It isn't designed to handle any sort of oil, plus you'd need a different tune. When you blow through the maf, it would effectively have to measure pressurized air, where as the draw through setup does not.
Old 04-26-2012, 04:58 PM   #197
TrippinBimmer
Question for David, BMWKnight and JoshZHP. When the car is running does your mechanical tensioner moves around? Mines move alittle not sure this is acceptable...
-Trip
Old 04-26-2012, 05:07 PM   #198
aggieE46
Keep it clean
aggieE46's Avatar
Gotcha, makes sense.
Buy my::
3.46 Differential
Coolant hard line
European Head Unit
Old 04-26-2012, 11:35 PM   #199
TrippinBimmer
Talk to Zak a Few MINS ago! Answer alot of my Questions and finding out about some...
Thanks for the Help!
-Trip
Old 04-27-2012, 12:54 AM   #200
Activ3
-Trip
Mine has a little play, but not enough to cause any strange noises.
