Thread Tools Search this Thread Rating: Thread Rating: 8 votes, 4.75 average. Display Modes
Old 08-01-2012, 11:46 AM   #261
TrippinBimmer
My Ride: Just Fast!
Here is some Injector Tech. Our fuel system run at 3.5 bars.
AA Delphi 37lbs Injectors (D3165BA) - Ordered 1 Replacement Per Zak Recommendation.
High Impedance Injector 15.9 ohms
37lbs @ 3 Bar (Advertised Specs)
40lbs @ 3.5 Bar
Dynamic Flow (mg/pulse): 8.42
Spray Pattern: Split 20*
Bosch 35lbs Injectors (0280155737) - Ordered but not going to use.
High Impedance Injector 12.2 ohms
35lbs @ 3 Bar (Advertised Specs) but really 34lbs
37lbs @ 3.5 Bar
Dynamic Flow (mg/pulse): 4.83
Spray Pattern: 4-hole disc
Bosch 36lbs Injectors (0280155868)
High Imdepence Injector 12 ohms
36lbs @ 3 Bar (Advertised Spec) but really 33lbs
37lbs @ 3.5 Bar
Bosch 42lbs Injectors (0280155968) - Ordered
High Impedance Injector 12 ohms
42lbs @ 3 Bar (Advertised Specs)
46lbs @ 3.5 Bar
Dynamic Flow (mg/pulse): 18.6
Delphi 42lbs Injectors (01D030x) - Thinking about getting these and selling the Bosch 42lbs Injectors
46lbs @ 3.5 Bar
Dynamic Flow (mg/pulse): 9.96
Spray Pattern: Tri-Cone
-Anthony
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
Stock
NAwhp/NAwtq SAE Corrected
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
Old 08-01-2012, 08:56 PM   #262
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
Other important specs that are hard to find:
Injector Dynamic Response Curve
Injector spray cone pattern (Spray pattern: It usually has 1 or 2 "cones")
Injector spray cone angle (Angle or width of spray cone)
Injector spray cone bend angle (Angle of spray cone when compared to the injector body centerline)
Average droplet size measured in microns (Changes with fuel pressure, so it's usually a 2D chart)
Against popular perception, fuel injectors when installed in modern fuel systems don't deliver linear amounts of fuel. Even when they are held wide open, (100% IDC) there is deviation in flow, droplet size, and cone shape from millisecond to millisecond. Better fuel injectors show less deviation from ms to ms.
Old 08-01-2012, 09:08 PM   #263
TrippinBimmer
My Ride: Just Fast!
I will add what I can to the Tech Post Most of this stuff would have to be done with special equipment that i don't have...
-Anthony
2005 AW/IR M3
MaximumPSI Stage4
Stock
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
Old 08-02-2012, 04:25 AM   #264
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
-Anthony
I don't know of many people that have access to equipment that will provide that info. I just mentioned it from a technical perspective, not a "must have" perspective.
Old 08-02-2012, 05:55 PM   #265
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
This app sucks.
Old 08-02-2012, 06:54 PM   #266
aggieE46
Keep it clean
aggieE46's Avatar
Enjoy. I'm going to miss her:
Old 08-02-2012, 10:36 PM   #267
TrippinBimmer
My Ride: Just Fast!
Brady,
Don't worry. I will put it to good use Also, installed my new injector today and man it REV SO MUCH FASTER and Sounds LIKE A BEAST! Video soon...
-Anthony
2005 AW/IR M3
MaximumPSI Stage4
Stock
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
Old 08-03-2012, 03:11 PM   #268
aggieE46
Keep it clean
aggieE46's Avatar
Anthony,
I hate you for taking my parts.
Love,
Brady
Old 08-03-2012, 11:15 PM   #269
TrippinBimmer
My Ride: Just Fast!
^ It need some paint Brady to match the S/C
-Trip
2005 AW/IR M3
MaximumPSI Stage4
Stock
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
Old 08-04-2012, 12:48 AM   #270
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
-Trip
Or you could get it coated with Turbo X....but it seams a waste to ditch the swaintec coating and spend $500 on another coating that will do pretty much the same thing.
Old 08-04-2012, 01:14 AM   #271
wrecklessfool
My Ride: is paid off
Nice build thread. I wish I had done one to document all the stuff I did from February through April. Spent something north of $12K so as you can imagine it would have been an EPIC thread.
wrecklessfool is offline   Reply With Quote
Old 08-04-2012, 08:49 AM   #272
aggieE46
Keep it clean
aggieE46's Avatar
Yeah, that's a lot of extra cash
Swain said it was fine to paint them with some high temp.
Old 08-04-2012, 11:18 AM   #273
aggieE46
Keep it clean
aggieE46's Avatar
Oh, by the way, still nothing from AA on transferring to you the tune that they owe me. I PM'd Viral but haven't gotten a response.
Old 08-06-2012, 01:22 PM   #274
Viral@ActiveAutowerke
Past Site Sponsor
My Ride: E46 M3
Hey Brady,
I did get your PM a while ago, just never got a response from Karl in regards to the transferring of the tune. But I don't see why it cannot be done.
Viral@ActiveAutowerke is offline   Reply With Quote
Old 08-06-2012, 01:42 PM   #275
aggieE46
Keep it clean
aggieE46's Avatar
Groovy, thanks Viral! I'm sure you guys will make good on it.
Old 08-06-2012, 09:24 PM   #276
TrippinBimmer
My Ride: Just Fast!
Disassemble the intake to seal up the BOV and swap intake boot.
Fully Assembled for the Most part.
I also made a Metal Bracket for my Oil Catch Can today. Hopefully, paint it tomorrow and bolt it in.
Originally Posted by Viral@ActiveAutowerke View Post
Hey Brady,
Viral,
This is AWESOME! I am planning to come down During ThanksGiving Week. Planning on taking my little sister to Disney World. Would like to knock 2 birds with one stone
-Anthony
2005 AW/IR M3
MaximumPSI Stage4
Stock
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
Old 08-06-2012, 10:10 PM   #277
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
Viral,
-Anthony
I drove it once already. Orlando is still FAR away from Active. Closer than Texas but still.
Although almost all is well...I still may join you. While Mayco did a pretty good job I would like to see if I can get things spot on. I do have this mystery crank, turnover, and die issue from time to time but my engine is still in one piece and that makes me happy.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 08-06-2012, 11:24 PM   #278
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
Nice Barbie Jeep.
Old 08-07-2012, 08:42 AM   #279
Past Site Sponsor
My Ride: E46 M3
Viral,
-Anthony
Sweet can't wait to finally to famous TrippinBimmer aka Anthony in Person
Come on you know the drive from Texas to Miami was almost as great as your European Delivery . Glad to hear that your car is still in one piece buddy. When are you gonna come down for another road trip
Old 08-07-2012, 11:54 AM   #280
bigjae1976
bigjae1976's Avatar
Not sure exactly when...someday.
Anthony,
If you stay in Miami...I think Viral says any hotel with Miami in it is high class and recommended.
