Thread Tools Search this Thread Rating: Thread Rating: 8 votes, 4.75 average. Display Modes
Old 08-07-2012, 02:49 PM   #281
TrippinBimmer
My Ride: Just Fast!
Modded the Fender for the Air Filter. Took alot of Cutting and Grinding
Here is the Fitment
I just placed an order with SiliconeIntakes.com for 3.5" 45* Silicone Coupling. So the Air Filter will be push forward more instead of hanging in the Wheel Well.
Custom Bracket.
Mounted the Oil Catch Can
All the Fitting and Hose Mounted. (I know the Fitting is not all the way on)
Front Bumper is back on
Waiting for the 45* Silicone Coupling to move this Air Filter Closer to the Bumper and not in the Wheel Well
Originally Posted by bigjae1976 View Post
Not sure exactly when...someday.
Anthony,
If you stay in Miami...I think Viral says any hotel with Miami in it is high class and recommended.
I got a place we can crash if we need to Let's plan for Thanksgiving!
-Anthony
Alpine White M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
Last edited by TrippinBimmer; 08-07-2012 at 04:22 PM. Reason: Added more Progress. Official Done with the AA Install.
Old 08-07-2012, 03:22 PM   #282
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Woot. Progress!
Old 08-07-2012, 11:22 PM   #283
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
I know it's a little late....but you could have avoided all that cutting/grinding by re-locating the headlight ballast. I'm in the middle of this myself....and I'm very temped to cut/grind.
So the inlet to the oil catch can comes from the valve cover? Where does the outlet go to?
Looking good though!
Old 08-08-2012, 12:00 AM   #284
TrippinBimmer
My Ride: Just Fast!
PEI since mine is a MS54 the Ballast isn't removable So I have to cut/grind to get the 3.5" pipe down into that section. The issue I have right now is I lost about .75 turn on the wheel to the right. I am waiting on the 45* elbow to see i can move the MAF and Filter out of the wheel well to make it fit better.
The Inlet of the Oil Catch Can comes from the Valve Cover and the Outlet goes into AA Pipe that wrap around the charger that goes to the Air Filter.
-Anthony
Alpine White M3
MaximumPSI Stage4
Old 08-08-2012, 12:16 PM   #285
MalibuMafiaV
My Ride: E60 M5 & Stg3 AudiS4
Haven't looked at your build for a LONG time wouldn't think your still doing it. Thought it would be done by now lol.
Anyways it looks like it's coming together nicely. How much psi are you going to run in the final build?. Are you going to run water/meth at all?. What type of bypass valve are you planning on using?. And are you swapping in a manual or sticking to auto? I can't remember. To lazy to read through all of these pages.
TheMalibuMafia.com
Instagram
BMW 2006 M5 - REALLY LOUD
BMW 2007 335i - ST GT35R
Audi S4 2000 Stage 3 - Dat turbo spool - SOLD
BMW 2000 3-series - Supercharged Because race car SOLD
Maserati 2004 M128 GT - HREs/tint/straight piped SOLD
BMW 2006 M3 - stock - SOLD
MalibuMafiaV is offline   Reply With Quote
Old 08-08-2012, 05:00 PM   #286
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
Yeah, my filter is in the same location. I like the ESS design which uses the OEM filter housing. Everytime I need to clean my air filter, I have to take the headlight and front bumper off. Its a massive PIA...but I can remove everything and put it back together within an hour. Mad skilz...and, unfortunately, a lot of practice.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 08-08-2012, 05:02 PM   #287
bigjae1976
bigjae1976's Avatar
-Anthony
Text me. Not sure if I can do during thanksgiving but I might be able to plan something family related.
Old 08-09-2012, 11:31 PM   #288
TrippinBimmer
My Ride: Just Fast!
Anyways it looks like it's coming together nicely. How much psi are you going to run in the final build? 10.5 psi Are you going to run water/meth at all? AA Meth Kit What type of bypass valve are you planning on using? AA BOV And are you swapping in a manual or sticking to auto? Auto I can't remember. To lazy to read through all of these pages.
Sending a Txt
-Anthony
Alpine White M3
MaximumPSI Stage4
Old 08-13-2012, 04:03 PM   #289
deadwood83
My Ride: has an iron lung
Send a message via MSN to deadwood83
I encountered a nearly identical problem with the filter needing to cut into the fender. Cut and installed part of my old Injen intake (the 45* section 2 nearer the TB). It definitely works, but instead of needing to trim the fender, I had to trim some of the front clip. Ent result can be seen from the front here. My fitment issues were less MS45 related and more XI related since the compressor->IC tubing had to be run on the outside of the bumper shock mount extrusion.
The piping definitely causes headaches.
AA Stg2+ 325xiA? Are you stupid? Maybe a little.
I can program cars fo' freeee near Salt Lake City. PM for details.
deadwood83 is offline   Reply With Quote
Old 08-14-2012, 05:40 AM   #290
bAby norAA
My Ride: 01 BMW 330i
the MAF/Filter was a huge PITA for me as well. I eneded up relocating my balast and cutting the back of my headlight up a bit. The intake is nestled right against the back of my headlight housing.
| VF Supercharged Stage 1.5| Southbend Stage 2 Clutch | ZHP Cams | Technik Headers |
bAby norAA is offline   Reply With Quote
Old 08-14-2012, 08:12 AM   #291
bigjae1976
bigjae1976's Avatar
The air filter I have is not nearly as wide but longer.
Old 08-14-2012, 09:26 PM   #292
TrippinBimmer
My Ride: Just Fast!
I have the that as well now with a PreFilter Sock on it. I will be installing my new 45* on it later so I can turn more.
-Trip
Alpine White M3
MaximumPSI Stage4
Old 08-20-2012, 08:22 PM   #293
TrippinBimmer
My Ride: Just Fast!
After one tank of gas...
The Radium comes with 12 SS Condensers. Seems like it is not enough to slow down the Vacuum and let the oil and air separation. I will be ordering more Screens but not sure how many should I added 0.0 The Charger is seeing some oil...
Pei330ci know what the vacuum should be at in our motor (in the crank case)?
-Anthony
Alpine White M3
MaximumPSI Stage4
Old 08-20-2012, 08:27 PM   #294
wrecklessfool
My Ride: is paid off
-Anthony
If this helps, I'm reading anywhere from 18-22 at the back of the intake manifold. I think you're looking for crankcase though which may differ.
wrecklessfool is offline   Reply With Quote
Old 08-21-2012, 12:17 AM   #295
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
Anthony,
With the OEM system, -18 to -22 is correct at the manifold. It will depend on the efficiency of the cyclone separator what the actual pan vacuum will be with the OEM system connected.
With a catch can connected, you won't have any vacuum from the intake manifold to pull on the crank case. So I would assume crank case pressure would be anywhere from atmospheric on upwards.
With the SC inlet "pulling" on the pan....I don't know what you'd see. Perhaps try hooking up a gauge before the catch can to check it out?
Old 08-22-2012, 08:54 PM   #296
TrippinBimmer
My Ride: Just Fast!
Anthony,
It seems like when I hit Full BOOST. The Oil Catch Can isn't restrictive enough to let the vapor and oil separate. That it is sucking it all in.
-Anthony
Alpine White M3
MaximumPSI Stage4
Old 08-22-2012, 09:56 PM   #297
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
-Anthony
You've brought up 3 different topics:
  • Pressure in Crank Case
  • Oil/Air separator efficiency
  • Condensate recovery
Being that the point of an external catch can is to minimize crank-case pressure, I understand that to most people this is all one topic.
However, what is in the crank-case vapor changes with engine operating condition and also running RPM. At higher operating temps, moisture from combustion blow-by is absorbed by the oil. What is IN the crank case vapor is mostly oil. At lower operating temps, and usually lower operating RPMs, the crank case vapor has more latent moisture in it...which is why you have lots of "water" in your catch can.
Crank Case vapor is going to have to go through a phase change to stay in the catch can. That is, it will have to cool from gaseous form to liquid form. That is what those screens do...they form a kind of "cooling sink". Because oil vapor usually is a lot hotter, it's going to take more cooling to get it to stay in the catch can. That's why you are probably seeing some oil residue on the compressor, (SC inlet) as the vapor is being pulled through the catch can without fully cooling and condensing.
Note - What you are doing is different from most people's oil catch can setup. Most people just vent the exit side of the catch can to atmosphere, where you are pulling it back into the intake tract. (In effect, copying the OEM system, but with different hardware)
Some ideas:
  • Add more separator screens
  • Add a second catch can (In series)
  • Improve catch can cooling
  • Add a crank case evac pump and vent to atmosphere
As odd as this sounds, I've often thought of putting an oil cooler element in front of the oil catch can to help with phase change. Just thinking out loud though...
Old 08-29-2012, 04:44 PM   #298
TrippinBimmer
My Ride: Just Fast!
Micky Mouse Ears, Wideband and Boost Guage installed 0.0
Tell me what you see wrong 0.o
-Trip
Alpine White M3
MaximumPSI Stage4
Old 08-29-2012, 04:58 PM   #299
E46_330i_Stud
My Ride: 2004 330ci ZHP 6MT
Doesn't come out of vacuum?
1995 325i 5mt ArcticGrey/Dove - SOLD
2004 330ci ZHP 6MT SilberGrau/Black - SOLD
2001 330i M-Sport 5MT StaulGrau/Grey - SOLD
1992 Accord LX Sedan 275k miles all original - DAILY
2002 Chevy Suburban LT Autoride - TOY HAULER
2005 GMC Sierra 2500HD SLT - RACE TRUCK!
E46_330i_Stud is offline   Reply With Quote
Old 08-29-2012, 06:28 PM   #300
joshzhp
My Ride: ZHP--Stock
No boost is created at idle....need to go drive it and watch the gauge.
joshzhp is offline   Reply With Quote
