Thread Tools Search this Thread Rating: Thread Rating: 8 votes, 4.75 average. Display Modes
Old 04-06-2013, 12:52 AM   #401
WALKD U
My Ride: Just Fast!
Originally Posted by lab rat View Post
It's not easy to pull the stealth look with centrifugal SC.
I'm thinking about painting the CF trim on the BMW performance intake and the modified PS fluid tank.
You got that right! Weather been kinda iffy lately but starting to get better starting this weekend. I sold my ST Coilovers and Picked up some TCKline 500F/500R D/A Coilovers, VMR v705 18x9.5 et33 wheels, ATI OverSize Damper is here and some other parts. I will be starting on it soon!!! I am so Hopefully, be running in a week or so
-Trip
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
NA Bolt-ons
207whp/216wtq SAE Corrected
1996 BLU/BLK M3
NA Bolt-ons
235whp/225wtq SAE Corrected
1988 SETA 325I
NA Bolt-ons
165whp/160wtq SAE Corrected
Old 04-08-2013, 03:10 PM   #402
WALKD U
My Ride: Just Fast!
*Update*
Received the TC Kline D/A Coilover System with 500F/500R Springs. As you can see they are pretty weathered. So I called and talked to Phil. He said its ok to use brake cleaner to clean up the shocks and see does it loosen the adj screw on the shocks.
Well I broke them down and PB blasted them I will leave them like this for a few days until I scotch brite them with a finishing pad (Very Very Fine) to hopefully bring back some of the finish.
At this time, I decided to rebuild the Ground Control M3 Street Camber Plates that came with the kit.
I order new polys from GC for $21 bux shipped. I have also decided I will not be using these but use the Vorshlag Camber Plates that I have for the Non-m
-Trip
2005 AW/IR M3
MaximumPSI Stage4
NA Bolt-ons
1996 BLU/BLK M3
NA Bolt-ons
1988 SETA 325I
NA Bolt-ons
Old 04-08-2013, 03:14 PM   #403
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Niiiice!
Old 04-08-2013, 03:22 PM   #404
Viral@ActiveAutowerke
Past Site Sponsor
My Ride: E46 M3
Originally Posted by TrippinBimmer View Post
*Update*
-Trip
Talk about "Spring" Cleaning
Viral@ActiveAutowerke is offline   Reply With Quote
Old 04-08-2013, 03:41 PM   #405
JohnBlaze
My Ride: Black Sunshine
are you sending those back to TC Kline to get them revalved?
Oh, BMW_Knight said his rear axle width did not change when he swapped in the M3 rear axle. Curious where you saw it change by doing that?
05 ZHP w/Epic tuned s54, Euro headers&Sect.1, Dinan 3.91 and a lot of other things built by Road Race Technologies
JohnBlaze is offline   Reply With Quote
Old 04-08-2013, 03:50 PM   #406
WALKD U
My Ride: Just Fast!
If I can get the Adj Screws at the bottom of each shocks to move. I will not send them in. As they don't leak and work fine. I am changing up the spring combo tho. Thinking about 450/700 setup as I do have a system (audio) in the back. Also, I will need to get the hardware for the Rear Adj for the Springs.
When swapping the M3 rear in there is a change but its very minimal. When I break mine down I will measure and fine out where its wider/longer at.
-Trip
2005 AW/IR M3
MaximumPSI Stage4
NA Bolt-ons
1996 BLU/BLK M3
NA Bolt-ons
1988 SETA 325I
NA Bolt-ons
Old 04-08-2013, 05:00 PM   #407
xaviman
My Ride: Supercharged
Screen shot 2014-01-25 at 12.36.33 PM by xaviman, on Flickr
Instagram: xaviman
xaviman is offline   Reply With Quote
Old 04-10-2013, 02:44 PM   #408
WALKD U
My Ride: Just Fast!
Well my hard work paid off! All adjustment screws work well. All it needed was some PB Blaster, Brake Cleaner and some Anti-Seize.
All Cleaned up
Anti-Seize Applied
Rear Shocks put back together
Front Shocks for the Most Part
-Trip
2005 AW/IR M3
MaximumPSI Stage4
NA Bolt-ons
1996 BLU/BLK M3
NA Bolt-ons
1988 SETA 325I
NA Bolt-ons
Old 04-10-2013, 02:45 PM   #409
2000_328CI
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
Bada$$$$$
| 435 HP 328Ci | RRT Racing | Designer Wraps | Active Autowerke | Vorsteiner | STATUS Racing |
Timeless Motor Group
Old 04-11-2013, 08:17 AM   #410
tim330i
E46Fanatics Owner
tim330i's Avatar
My Ride: 03 Ti Silver M3
Not the place for this, find the buyer/seller feedback forum. Posts removed, keep this on topic.
Tim
tim330i is offline   Reply With Quote
Old 04-11-2013, 09:05 AM   #411
UdubBadger
My Ride: 04 M3 / 08 M3
Excited to see her in person buddy. Don't forget to book your hotel room soon!
2008 E90 ///M3
StormTrooper/Black
DCT
Gone but not forgotten 2004 E46 ///M3 - AA Supercharged
Imola/Imola
3 pedals
UdubBadger is offline   Reply With Quote
Old 04-18-2013, 04:31 PM   #412
WALKD U
My Ride: Just Fast!
Decided to slap in the 42lbs injectors to fix my minor lean issues. Until I can throw in my Bosch Motorsports 60lbs injectors and get the car tune for it
Where did my rear axle go?
Order a HPF Rear Sub-Frame Kit. Can't wait to get this and get them installed. Thanks KIRK! Also, there is a few other parts I am waiting on as well. Sux not being a millionaire or this car be done long time ago...
Slowly working on it brotha! I will book my room soon.
-Trip
2005 AW/IR M3
MaximumPSI Stage4
NA Bolt-ons
1996 BLU/BLK M3
NA Bolt-ons
1988 SETA 325I
NA Bolt-ons
Old 04-19-2013, 05:52 AM   #413
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
How many dolly jacks do you have?
Old 04-21-2013, 08:59 PM   #414
WALKD U
My Ride: Just Fast!
*update*
Entire Rear End has been removed and waiting on HPF SubFrame Kit to arrive.
Oversize Damper and Underdrive Waterpump Pulley...
Testing Belt Fitment to see they will clear with no issues...
I do have an issue with the Damper hitting the Pulley on the A/C Tensioner and Limited Tensioning movement. I will have to figure out away for it to clear and get the right size belt for fitment...
Adam,
Not enough lolz
-Trip
2005 AW/IR M3
MaximumPSI Stage4
NA Bolt-ons
1996 BLU/BLK M3
NA Bolt-ons
1988 SETA 325I
NA Bolt-ons
Old 04-21-2013, 09:08 PM   #415
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
there is something wrong with your transmission
/_________\
O==[][]==O
Old 04-21-2013, 09:24 PM   #416
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
I had the same problem...
Old 04-21-2013, 10:09 PM   #417
xixixi
Banned User
My Ride: 01 330x-xi
15months, no dyno? Never seen the car run? What gives? 10 Injector set ups? I haven't followed this thread much in the last 6 months? Confused...
Old 04-21-2013, 10:16 PM   #418
xixixi
Banned User
My Ride: 01 330x-xi
Originally Posted by Viral@ActiveAutowerke View Post
It's pretty simple Underdrive Pulley's work great in Naturally Aspirated Vehicles since you are slowing down the speed of other components just enough to have them function properly and help speed up the crank which helps to produce the additional power. When you Forced Induction more specifically towards a Supercharger Setup where it's a belt driven system you will amplify that effect. We design our products to be functional that way you can still enjoy to luxury of having air condition and OEM cooling system.
Now putting a smaller pulley kit on a Supercharger will help Generate some power.
NVM i found out why your car doesn't run, take those under drive pulleys off...
Old 04-21-2013, 10:48 PM   #419
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
I wouldn't call them under-drive pulleys when you factor in the size of the crank pulley. It's a 6.8" OD custom ATI piece, where the OEM crank pulley is 5.5". In fact, I don't think I've ever seen a bigger crank pulley on an M54...even Jorge Saca's custom SC setup in El Salvador was smaller. (Let me see if I can dig up a picture of that)
Old 04-21-2013, 10:57 PM   #420
xixixi
Banned User
My Ride: 01 330x-xi
Come on Adam, the water pump pulley doesn't matter either way. (unless it's a fitment issue) I was just poking some fun at Viral. We all know why this car isn't running, it's not the transmission, or under drive pulleys. The real info that should be shared here. Buy a stand alone, source the hardware. A monkey can wire up a MS, cheap. Just saying..
