Engine Removal BMW 323ci - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 01-30-2012, 06:49 PM   #1
Mman004
My Ride: 2000 E46
I would like to know if anyone knows if the tranny must come out to remove the engine. I have a 2000 323ci. Any info is appreciated. Also if there is anyone near Lake City, Gainesville area that don't mind taking a ride out to Live Oak to help out let me know.
Mman004 is offline   Reply With Quote
Old 01-31-2012, 03:07 AM   #2
RKiepper
My Ride: 1999 E46 328I x2
It is not required to remove the transmission along with the engine. I've done it, and found out it's more difficult to pull just the engine then pull them both and then disconnect them.
Pulling just the engine : 2 shock mount bolts & 8ish transmission and starter bolts, various linkages, hoses, wires.
You have to find a way to get to the rear-top of the engine, like dropping the front subframe out and lowering the engine- involves pulling the entire front suspension. Once disconnected, the transmission needs to be supported so it doesn't tear uP the mounts. Disconnect the ECM harness from it's box, keep it on the engine... It's easier then figuring out where plugs go.
Option 2: Engine & Transmission - 2 bolts for engine mounts, 4 bolts for transmission mount bracket, various linkages, hoses, wires. Once everything is disconnected, the assembly is loose and can be lifted out. It's easier to disconnect them where there is alot more room to work.
RKiepper is offline   Reply With Quote
Old 02-01-2012, 05:16 PM   #3
Mman004
My Ride: 2000 E46
Thanks for that insight....you are a lifesaver
