Old 01-30-2012, 09:15 PM   #1
zanga254
My Ride: 2002 325xi ZPP
Question Weird big block sound from my 325
Hey guys, hope you all are enjoying your e46's.
I was driving around doing some errands today and traveled less than 5 miles until the "problem". When I started my car leaving a parking lot, I wasn't greeted by the normal hum of the I6 but a completely different noise. I would liken the sound I heard to a big block muscle car, but at the same noise level as usual. The sound only lasted for 10 seconds and then the engine returned to it's normal grunt. Those 10 seconds I was watching the revs (as I always do during a start) and it went from ~1000 to ~800 by the time it stopped, so nothing out of the ordinary.
I'm not too concerned as it hasn't come back since, but it's a stock engine without any aftermarket parts. Any idea what the sound was or why it occurred?
Originally Posted by djlinux64 View Post
I am content with cruising at only 130 mph.
zanga254 is offline   Reply With Quote
Old 01-30-2012, 10:55 PM   #2
BestOfE46
My Ride: 323,325xi, M3
Secondary air valve opening
BestOfE46 is offline   Reply With Quote
Old 01-30-2012, 11:02 PM   #3
jfoj
My Ride: 330CiC, M5, X5, E93
Not so cold around here today, however, suggest you check the link in my signature for cold start misfire, lean codes, rough idle.
I have a lot of ideas of typical problems. You might have been in limp mode, however, this usually includes a CEL/MIL as well?
Old 01-30-2012, 11:50 PM   #4
zanga254
Something to be concerned about?
No CEL's for me, or any warning lights. I doubt it was a cold start since I was driving it fine before I parked. Not sure if rough idle only applies exclusively to situations where the actual car shakes as well, but no shaking happened in my case. I will check your thread though.
325i, 325xi, noise
