Thread Tools Search this Thread Rating: Thread Rating: 39 votes, 5.00 average. Display Modes
Old 01-31-2012, 12:59 PM   #1
jjrichar
Modded ///Member
My Ride: 330 CiC, 330i
Project M54 Engine: Fuel Injection Rail
Fuel Injection Rail
Links to other parts of the project
http://forum.e46fanatics.com/showthread.php?t=899347
Removal of the fuel injection rail is required need to change an injector, or if you want to remove the intake manifold.
Before I start, I looked at the methods described in the Bentley manual, and other DIYs that have been posted in different places. I used them all, and found most quite difficult. I tried a whole bunch of things over and over and eventually came up with this method. The problem with the fuel rail is there are a number of things layered here, and if attempted in the wrong order, or in the wrong way, it is easy to break things. You will notice that the oil separator pipe at the top of the intake manifold in the photos is covered in tape. This is because it was broken when I attempted to do it as per another DIY.
The way I will show you I think is much easier, and much less likely to break something.
Also, most methods talk about releasing the fuel pressure from the fuel rail before you start. If you are actually going to remove the injectors from the rail then this is obviously required. If you plan to just remove the intake manifold, then I would not release the pressure.
If you want to remove the pressure and fuel from the rail, this is the way I would do it.
1. Remove the fuel pump fuse.
2. Start the car and wait until is starts to run rough. Then turn it off.
3. Disconnect the battery.
4. Put a rag over the shraeder valve on the front of the rail, and then press down on the pin to release the remaining pressure in the rail. (the shraeder valve is the name given to the valve that you use to pump up your tyres. The one on the fuel rail is exactly the same.)
5. Connect a hand bicycle pump to the shraeder valve at the front of the rail and give a good number of pumps to try and remove as much of the fuel out of the rail as possible.
Finally, I have no idea what the funny plastic thing that sits on top of the intake manifold that receives the air from the oil separator. I have called it the "oil separator part of the intake manifold" or OSIM.
The methods I have seen published elsewhere did not have you disconnect the OSIM, they said to just disconnect the oil separator pipe from the two connectors below it. This is difficult. There's no space to get your fingers in, and you need to use some long nose pliers. The connectors are really stuck on, and when the eventually release (with you pulling as hard as you can) things break easily. This is why I think it is better to lift off the OSIM, with the pipe coming with it and out of the way.
Once the oil separator pipe is out of the way, you can remove the injector harness. The first photo here has the injector removed so you can see easily what you need to do. Use a small pick tool to get under the clips and remove them. This is the biggest pain of the whole job. Make sure you have a magnetic pickup tool touching the clip as you try and remove them, they can spring all over the place.
Once all clips have been removed from each injector connector, you can easily pull off the harness. Intake cam sensor and intake air temp sensor connectors will also need to be disconnected. Place the whole harness out of the way.
Now remove the small bolts that hold on the rail.
And gently pry up the fuel rail. Don't just pull it up by hand. You will need to use a lot of force, and when it gives, it will happen very quickly. Easy to break something expensive. If you do it as shown it is dead easy.
When all the injectors are out, you can lift and rotate the whole rail with injectors still attached as shown.
There is a flexible fuel hose at the back of the engine that connects to the fuel rail. This hose is held in place by a clip at the back of the intake manifold. Release this by getting your hand down the back under the manifold and unclip it.
If you want to remove the fuel rail completely now is the time to do it. You will need to have removed the fuel pressure from the fuel rail as described at the top. Then you can disconnect the flexible hose from the fuel rail. The photos show the hose still attached at the clip, but this would be much easier to do when the hose is removed from the clip.
If you do need to remove an injector, this is how you do it. Again, you will need to have removed the fuel pressure from the rail to do this.
There you have it.
Reassembly is the opposite, but is much simpler. Tips I have are:
1. Connect the injectors to the rail before putting the injectors in the intake manifold.
2. Push in the injectors and rail by hand into the intake manifold before putting in screws. Don't try and screw them down to seat them. It won't work. To help get the injectors into place, I smeared the smallest amount of engine oil around the O Ring that goes into the intake manifold, and they slid in easily.
3. Have the injector harness clips placed back into their correct position before attaching the harness. The harness connectors will slide on and clip in easily.
3. Same procedure for the OSIM as for seating the injectors.
I couldn't find any torque figures for reinstallation on either BMW TIM or the Bentley manual. Just make sure they are well attached but not over tightened.
Name:	Fuel rail 2.jpg
ID:	434849   Click image for larger version
Name:	Fuel rail 3.jpg
ID:	434850   Click image for larger version
Name:	Fuel rail 4.jpg
ID:	434851   Click image for larger version
Name:	Fuel rail 5.jpg
Name:	Fuel rail 6.jpg
ID:	434853   Click image for larger version
Name:	Fuel rail 7.jpg
ID:	434854   Click image for larger version
Name:	Fuel rail 8.jpg
ID:	434855   Click image for larger version
Name:	Fuel rail 9.jpg
Name:	Fuel rail 10.jpg
ID:	434857   Click image for larger version
Name:	Fuel rail 11.jpg
ID:	434858   Click image for larger version
Name:	Fuel rail 12.jpg
ID:	434859   Click image for larger version
Name:	Fuel rail 13.jpg
Name:	Fuel rail 14.jpg
ID:	434861   Click image for larger version
Name:	Fuel rail 15.jpg
ID:	434862   Click image for larger version
Name:	Fuel rail 16.jpg
ID:	434863   Click image for larger version
Name:	Fuel rail 17.jpg
Name:	Fuel rail 18.jpg
ID:	434865   Click image for larger version
Name:	Fuel rail 19.jpg
jjrichar is offline   Reply With Quote
Old 01-31-2012, 01:53 PM   #2
BMW_SSG
BMW_SSG's Avatar
My Ride: '02 325i|'11 GT500
Send a message via Yahoo to BMW_SSG
Nice DIY! I had to replace mine a few years ago when I made an error while drilling it for my Nitros system... It gets pretty tight on the back end and I am blessed with these two banana bunches for hands too. They were sore for a week afterwards.
I didn't have such a well laid out DIY either. Bravo!
BMW_SSG is offline   Reply With Quote
Old 01-31-2012, 02:12 PM   #3
SeanC
My Ride: 330i
Not too many DIY guides on here with this much detail. Nicely done!
Black Sapphire MetallicNatural BrownSilver Cube e46 330i ZHP/6MT - Sold
HellrotDove Grey e36///M3 - RIP
Black Sapphire MetallicNevada BrownDark Bamboo e70 X5 xDrive4.8
Alpine WhiteCoral RedAluminum f30 328i Sportline/6MT
Imola RedBlackBlack Aluminum e46 330i ZHP/6MT
SeanC is offline   Reply With Quote
Old 01-31-2012, 02:21 PM   #4
Custom3
My Ride: HellRot 330CI
thanks for taking the time to show so much detail. Im sure this will come in handy to many people and help save them lots of money.
Old 04-29-2012, 06:59 AM   #5
phamine
My Ride: 01 Orient Blue 330i
Send a message via AIM to phamine Send a message via Yahoo to phamine
Also very nice - TY
phamine is offline   Reply With Quote
Old 05-19-2012, 05:35 PM   #6
carl0s
My Ride: E46 330i, E60 545i
This is an nice detailed write up, but you are making a mountain out of a molehill.
I've had my fuel rail off a few times now.
There is no need to remove the air distributor.
The clips for the injector harness are easily done like this:
Get some long nosed pliers and push one side of the first clip down the side of its housing (it'll move there and stay there easily), and, while applying slight upwards pressure on the harness with your hands, push the other side of the clip out a bit. That plug will then be free. Keep the lifting pressure in place so that it doesn't clip back down, and move on to the next injector plug. When you get to the end, the whole assembly will lift free easily.
Carl
carl0s is offline   Reply With Quote
Old 08-19-2012, 09:54 PM   #7
gn120760
My Ride: 325XI
Fuel Injection Rail
Nice writeup!! I was able to replace all 6 injectors today with this in a hour!!
Looked alot more complicated than it really was. Helps to have an extra set of hands with a magnetic pick up tool just in case.
I didn't disconnect the fuel line and had just enough room to put new injectors into 5 and 6.
Best writeup on this!!
gn120760 is offline   Reply With Quote
Old 02-22-2013, 08:20 PM   #8
bmw_n00b13
My Ride: '99 528iA (E39)
FYI, the part is called the "distribution piece" or as carl0s said "air distributor". I'm guessing it feeds the vacuum system, and has some equalizing effect too.
Nice write-ups; making for a pleasant Friday evening in cold as f*ck Canada right now. Thank you.
bmw_n00b13 is offline   Reply With Quote
Old 06-30-2013, 07:07 PM   #9
jjrichar
Modded ///Member
Update: I removed the intake manifold on my car this weekend to replace the oil separator. All the stuff I have above worked well, but the only thing was that it's not possible to rotate the rail up and out of the way like I have in the photo above. The bulkhead behind it gets in the way. The only way to get it out of the way was to get my hand around the back and disconnect the clip and the hose connection. Then it can be manoeuvered out. Also, the most difficult part was, as described above, getting the clips off the injector harness.
Old 02-01-2014, 02:56 AM   #10
blakxr
My Ride: 2001 325i
Wish me luck, I'm about to take my injectors out to clean.
blakxr is offline   Reply With Quote
Old 05-05-2014, 09:53 AM   #11
Stinger9
My Ride: '04 330Ci
Originally Posted by blakxr View Post
Wish me luck,
How'd it work out for you?
Old 05-05-2014, 09:55 AM   #12
Stinger9
My Ride: '04 330Ci
VERY IMPORTANT addendum! Make sure you add this info to the excellent DIY to make things much clearer for the perfect project.
Old 05-27-2014, 04:22 PM   #13
Fernando34
My Ride: 2000 BMW 328ci
dude you just saved me i was fighting with that fuel line
Fernando34 is offline   Reply With Quote
Old 03-24-2015, 07:45 AM   #14
Obioban
My Ride: 05 M3, 01 M5, M3iT
Send a message via AIM to Obioban
Anyone know the part number on this metal clip? One sprang off into oblivion, and I can't find it for the life of me on realoem...
-Ian
Current Cars: 2005 IR/IR M3, 2001 LMB/blk M5, Wife's 6mt NA RWD e91, 04 M3 wagon
Past cars: 04 M3, 96 M3, S50B32 e36 M3 CM race car
"People do not see good design." -- Claus Luthe, BMW chief designer e30-e39
Obioban is offline   Reply With Quote
Old 06-02-2015, 12:35 PM   #15
smoothops
My Ride: 328i
Can use a little help with the wire that comes out of the harness
I just took my e46 328i intake manifold out last night to replace the starter and upon reassembly, a connector that is attached to the smaller wire at the rear end of the fuel rail harness has gone orphan. I can't find where to connect it for the life of me. It is shown clearly in the picture of this write up that shows how to pry up the OSIM, picture #4. if anyone knows where this goes, please, put me out of this misery.
smoothops is offline   Reply With Quote
Old 01-05-2017, 09:51 AM   #16
djglover
My Ride: 325xit
Question on injector harness
Forum,
Great thread and pics. If this question has been answered I apologize and please direct me elsewhere.
I am in the middle of an M54 intake/CCV/everything-on-the-driver-side teardown.
Is it possible the open up the injector harness "box", loosen up the cables, and gain access to the intake manifold mounting bolts? The objective would be to remove the entire intake with injector harness and fuel rail intact.
djglover is offline   Reply With Quote
Old 03-05-2017, 08:41 PM   #17
DEADF15H
My Ride: 2001 325i Auto
Repeat
Sent from my fireproof Samsung Note 4
DEADF15H is offline   Reply With Quote
Old 03-05-2017, 09:06 PM   #18
DEADF15H
I lost 2, my Magnet would not fit down there.
I ordered two extra clips that hold the injectors, just in case, that I didn't need.
Guess I have to find some in a junk yard.
Old 03-05-2017, 10:28 PM   #19
willysalazar1
My Ride: 2003 330ci
Great write up !! Clips are easy to lose so get some before doing this .
Enviado desde mi iPhone utilizando E46Fanatics
willysalazar1 is offline   Reply With Quote
Old 03-06-2017, 12:12 PM   #20
DEADF15H
Agreed, but after 1.5 hours on realoem.com and a call to the dealer. Nobody seems to know the part number for the electrical connector clips.
