The Showroom
Old 07-29-2012, 12:51 AM   #61
98bimmer
My Ride: E90 330i, E36 328i
Looks great, m tech 2 neeeeeeext!!
98bimmer is offline   Reply With Quote
Old 07-30-2012, 01:13 AM   #62
Mr_325
My Ride: 2007 X5 3.0Si
i would love the m tech 2 kit but ordering the kit, install and paint match will be so expensive
i still wanna do eBay headers, chip and tune
Mr_325 is offline   Reply With Quote
Old 07-30-2012, 02:19 AM   #63
98bimmer
Just do the m tech 2 front
Old 07-30-2012, 02:58 AM   #64
xcar360
Past Site Sponsor
My Ride: BMW 318i
very nice, the car has been well maintained
xcar360 is offline   Reply With Quote
Old 07-30-2012, 03:00 AM   #65
Mr_325
forgot, oil change due tomorrow but nice and simple
Old 08-02-2012, 12:50 AM   #66
Mr_325
got my new rear tire on today,, $350
so ive got 235/35/19 on front and 245/35/19 on the rear's,, Hankook's all around,, not really a fan tho,, too much road noise
might try Nitto's next time unless i can find a good deal on Michelin's
Old 08-02-2012, 12:54 AM   #67
Mr_325
gonna book for my coolant flush and have the service maintenance appearing too @ 139, XXX km's or else would have brought to a non stealer
Old 08-18-2012, 01:27 PM   #68
Mr_325
my license plate LED's showed up the other day from LEDAutomotive.. very nice and clean but had a hell of a time getting them in, they were too big. not sure if they sent the wrong ones or not
Circa August 2012
Old 08-18-2012, 07:23 PM   #69
Mr_325
*forgot to add my new Kenwood 2din died on me 2 days ago, stuck in a reboot loop so it's getting shipped back to Kenwood and replaced*
this will be my new stereo until my 2din gets fixed
2 speakers from costco hooked up to my iPhone haha jealous
Old 08-30-2012, 04:04 PM   #70
Mr_325
well i believe the companies received my 2din now so hopefully they can install the update fix or send me a new unit
next up i believe i've got a coolant flush due
anyone know when VCG's need replacing? did them early in the yr i believe but did not know to replace VANOS.
i think VANOS need to be replaced but don't wanna replace VCG's already if not needed
i do wanna go with the Beisan kit
Old 09-11-2012, 04:05 PM   #71
Mr_325
received my replacement 2din..
tried installing it but couldn't figure out how the installer ran the wires to get it to fit snug
it's temporarily installed so i at least have music
noticed however i forgot to plug the cigarette lighter power back in and have issues with the music playing to all speakers (2din setting somewhere)
will have installer properly re-install for me this week
Old 09-17-2012, 06:31 PM   #72
Mr_325
deck is back in and installed properly
gotta do coolant flush real soon here then debating doing oem speaker replacement and an 8" sub or else m-tech II front.. just thinking speaker replacement will be cheaper then m-tech II front because i'll need all the additional brackets and stuff, then match up the paint to the car.. seems pricey
Old 10-20-2012, 03:20 PM   #73
Mr_325
just ordered up myself some beisansystems vanos since i've got a vcg leak and didn't do them last time
Double Vanos Seals Repair Kit (6-cyl)
Item # BS001, $60
For BMW engines M52TU, M54, M56
when parts show up having Vanos replaced and VCG's done again
Old 11-09-2012, 05:17 PM   #74
Mr_325
after 2 weeks my Beisan VANOS seals arrived
called a reputable Indie shop to get my VCG's done again and the VANOS seals
hoping to get in next Friday
Old 11-20-2012, 02:21 AM   #75
Mr_325
Cars booked for Friday morning
Quoted 5hrs @ $98/hr for vcgs and vanos seals
Seems right
.. this fell through as the frigging mechanic cancelled me while i was more then half done my 2 hr drive to him, said he didn't have enough time to do the job.
i even booked 2 weeks in advance
will be bringing back to my local guy instead
Old 12-20-2012, 01:23 AM   #76
Mr_325
got the stock speakers replaced with Polk Audio's all around including tweeters
i can actually turn up my volume past 20 and have excellent sound
speakers were professionally installed so i don't have pic's of them as they are already in and covered
my driver speaker cover is broken, anyone know if you can buy just the cover? i think it's part of the door
i also have the Polk Audio's running off a separate amp instead of the 2din
amp is a JVC, not sure of watts or any of that stuff.
just told him what i wanted to do and told him to pick the best of the best for $1k installed.
this guy is a local car buddy and has done all my audio work
will take a pic of the amp tomorrow
Amp is currently installed in the trunk to the back of the seat until i can get a custom sub box made to mount it too
Old 12-22-2012, 01:44 AM   #77
Mr_325
JVC Amp that all my aftermarket speakers are hooked too, mounted on left side of the trunk
sub wire is pre ran already too and tucked behind the trunk lining on far left
hoping to have this all mounted to a sub box in February
*EDIT*
found out speakers are Polk Audio MM6501 6.5" components
if shelf speakers aren't too difficult to expose i may snap a pic of them and post up
Old 12-22-2012, 02:18 AM   #78
NightRaider93
My Ride: 2007 Z4 Coupe
Great progress!
-Spencer
NightRaider93 is offline   Reply With Quote
Old 12-22-2012, 02:06 PM   #79
Mr_325
Originally Posted by NightRaider93 View Post
Great progress!
thanks
Old 12-22-2012, 02:12 PM   #80
Mr_325
after the speaker install i forgot to mention my taillights kept showing a bulb out and they are EE LED tails
i called the installer to see if he had to tap into any wires and he said no, only thing he did in the trunk was take the panels off to run wires
so i took the panels off (wasn't needed )
ended up being the ground wire was loose in the harness
the EE wires are so thing/crappy and the contacts in the harness they plug into are so short so they come loose easy
i ended up taking the 2 black grounds and one brown cable on the other side and joined them together outside the harness
everything is good but we've got a ton of snow so i haven't been able to drive
hopefully no other wires are loose in the harness
if so i'm going to delete the harness and re-attach all wires without it
