ESS Twin Screw - Page 3 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 15 votes, 5.00 average. Display Modes
Old 02-10-2012, 09:25 PM   #41
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
Now that I think about it, I think my w/a injection kit was a big reason why my car runs so well in the heat. I did 2 HPDE weekends in 105 degree temps. Other cars were going into limp mode and mine was still charging along. My temp gauge actually stayed below the halfway mark most of the time and only climbed slightly above the middle during a long session. The only thing that overheated was the driver.
I've seen on other forums that ESS is very against meth injection. Right or wrong? Not sure. I will not depend on meth as a power adder because what do you do when it runs out? To me, that's not something I could consider to be reliable.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 02-11-2012, 02:34 AM   #42
Dirtboy
Grüne Hölle Junkie
Dirtboy's Avatar
My Ride: ESS TS2+ 330Ci
Send a message via Yahoo to Dirtboy
That's what I was thinking. I would really want to use to help prevent heat soak. Kind of like an extra intercooler. Where I'm going I'm going to need all the cooling I can get. You can run the injection kit without DME tuning correct?
Dirtboy is offline   Reply With Quote
Old 02-11-2012, 02:39 AM   #43
bigjae1976
bigjae1976's Avatar
yes
Sponsored Links
Advertisement
Old 02-11-2012, 02:54 AM   #44
Dirtboy
Grüne Hölle Junkie
Dirtboy's Avatar
Sweet.
Another dent to my wallet... lol
Old 02-11-2012, 05:11 AM   #45
signalwest
My Ride: 2001 330i Sedan TS2
I am not going to tune for mine. My thinking is first as a cooling agent against heat soak, but I am still considering a smaller pulley in the near future with a tune from ESS. Again that tune would be without cams and unsupported by ESS, but AJ says they do have it....but again..he said if my car blows up...don't call him
signalwest is offline   Reply With Quote
Old 05-19-2012, 04:32 PM   #46
signalwest
Finally got the methanol injection completed (just need to tidy up some wiring). I was sent the wrong AEM controller (diesel) and didn't figure it out until after we cut wires off the controller to make it shorter (easier to manage). But AEM said no problem and exchanged for the right one at no extra charge. I replaced the silicone tubing between the MAF and throttle body with an aluminum reducer pipe. We just had to put a slit in the middle and weld it up for that funky bend. This gave me the capability to spray about 4 or 5 inches away from the throttle body to give more time for ionization. We started with the smaller nozzle which seemed to drop the IATs a little bit, but could not feel much of a difference (and no bogging). Again I am not going to tune for the 50/50 mix. We then went to the middle nozzle which supports up to 350hp. At lower end I seem to notice it is slightly quicker. At higher speeds and punching it there is not much of a difference. I did notice that before spraying my boost gauge shows around 8psi at WOT. But now it is around 9. The middle nozzle does not ever bog down the car..at all. We will try the largest nozzle next (350 to 600hp). Attached is a picture of the aluminum piece finished, but we had not tapped the washer tank yet so no hose coming out of the AEM nozzle (I put a plug in it). Once I find which nozzle is best I will then find the best start and max boost pressure when spraying. Right now it starts at 4psi and max at 8psi. I did run with a MkI GT3 (997) (and not on the track, but on the Autobahn..he would smoke me on the corners) and we were about neck and neck...he slowed and pulled to the right and gave me a thumbs up. I was running almost neck and neck with a friend's 2011 DCT M3 Sedan before spraying (I have a video, but it is very choppy). We will give it another try once I get the right nozzle and setting and will capture another video for comparison if anyone is interested.
Old 05-19-2012, 04:40 PM   #47
signalwest
Oh..I did get up behind a new Audi RS6 MTM Avant (with the quad pipes) and he left me in the dust. 730HP!!! http://www.mtm-online.de/en/Audi/RS6...=m1rs6580730qx
Old 05-20-2012, 12:06 AM   #48
MSportBMW
My Ride: E46 325, EVO8 MR
Car looks like it really hauls a$$!
MSportBMW is offline   Reply With Quote
Old 06-19-2012, 05:58 AM   #49
signalwest
Verdict
Running the ESS TS2 with headers, Magnaflow Exhaust and BMW performance intake and prefabbing the above setup for the AEM Methanol spray, I can firmly say that the car runs like a champ. I am using a 50/50 mix (1 gallon of -20 Blue Windshield Washer mixed with 3 bottles of HEET). I am using AEM's largest nozzle with no bogging down possibly due to better atomization because of the location I am spraying from (directly after MAF). There is no pinging running hard on the Autobahn at around 80F outside. My next venture is having a 80-81mm pulley made (I am running the 83mm) to squeeze some more boost/horses out of the car. Here is a recent run against the latest model (make 2 facelift) 997/911 Carrera S. Drive safe.
Old 12-09-2012, 12:10 PM   #50
Dirtboy
Grüne Hölle Junkie
Dirtboy's Avatar
Nice install!
I have yet to put mine in. I went with the Snow Performance MPG-MAX kit. Haven't had time to put it in cuz I've been spending my time getting the e30 to run right... lol
Old 01-10-2013, 03:13 AM   #51
signalwest
Happy New Year! Is your e30 Euro Spec and you got to ship it back to the States? My last mod was a few months before winter (car is in the garage now and I am driving the Golf to work). I had a friend who is a professional machinist prefab a small pully for me. So I went from 83mm to almost 81mm. I went up against an e90 M3 sedan with DCT/comp pkg that I was almost even with in the past and he could not keep up on the A bahn from a 100km/h start He is now currently looking at one of the ESS SC for his e90. You need to get that kit in before you start running in that heat! Let us know how the install and results go.
Old 01-26-2013, 09:48 PM   #52
Dirtboy
Grüne Hölle Junkie
Dirtboy's Avatar
Originally Posted by signalwest View Post
... Is your e30 Euro Spec and you got to ship it back to the States?
Yeah my e30 was euro spec. It was 2 years short of being DOT exempt so I had to get it converted to US spec. But I saved all the euro parts and put them back on once I got the car back. lol
I STILL haven't installed my meth kit. Just been busy with the e30 and the new house. I'll get in in there someday. Maybe before Bimmerfest in May.
Old 01-27-2013, 12:10 AM   #53
WALKD U
My Ride: Just Fast!
Going to ruin those Lamnova Cores...
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
NA Bolt-ons
207whp/216wtq SAE Corrected
1996 BLU/BLK M3
NA Bolt-ons
235whp/225wtq SAE Corrected
1988 SETA 325I
NA Bolt-ons
165whp/160wtq SAE Corrected
Old 01-29-2013, 12:34 AM   #54
Dirtboy
Grüne Hölle Junkie
Dirtboy's Avatar
Please explain....
Old 01-29-2013, 01:12 AM   #55
daniel_f.
My Ride: 330iC
i guess, due to cavitation there should be erosion and therefore occuring a damage?!
Old 01-29-2013, 09:19 AM   #56
JohnBlaze
My Ride: Black Sunshine
also interested to know if the meth will damage the SC
05 ZHP w/Epic tuned s54, Euro headers&Sect.1, Dinan 3.91 and a lot of other things built by Road Race Technologies
JohnBlaze is offline   Reply With Quote
Old 01-30-2013, 09:49 PM   #57
Dirtboy
Grüne Hölle Junkie
Dirtboy's Avatar
don't think a 50/50 mix will do any harm, as long as it's not getting "dumped" into the airflow...
I just got off the phone with Lysholm and they said they are familiar with ESS Tuning's TS kit that uses their SC and they said the rotors are actually still made in Sweden and they are indeed hard anodized and spraying 50/50 meth is good to go. They also said that spraying after the rotors would be best which means I would have to tap into the SC compressor, but they also said before or at the throttle body would still yield decent results....and still safe. Looks like this project will be a go.
Old 01-30-2013, 10:24 PM   #58
WALKD U
My Ride: Just Fast!
The Rotors are fine. What I am talking about is the after cooler that is built into the TS it will corroded over time...
2005 AW/IR M3
MaximumPSI Stage4
NA Bolt-ons
1996 BLU/BLK M3
NA Bolt-ons
1988 SETA 325I
NA Bolt-ons
Old 02-02-2013, 01:45 AM   #59
lab rat
My Ride: '02 330iT
I'm a bit worried about that too. Don't really want a piece of aluminium cooling fin to fly into my intake
But ... I don't think it's gonna stop me from installing similar meth kit.
I got a spare motor
OP - do you have custom tune or ESS?
Because sleeper
Old 02-04-2013, 12:03 PM   #60
WALKD U
My Ride: Just Fast!
I got a spare motor
Hehe
2005 AW/IR M3
MaximumPSI Stage4
NA Bolt-ons
1996 BLU/BLK M3
NA Bolt-ons
1988 SETA 325I
NA Bolt-ons
