Thread Tools Search this Thread Rating: Thread Rating: 15 votes, 5.00 average. Display Modes
Old 02-05-2013, 07:46 AM   #61
signalwest
My Ride: 2001 330i Sedan TS2
lab rat, I have the ESS tune (TS2 for the 83mm pulley). I thought about a custom tune when I went to the smaller pulley, but a friend (with many years of SC / tuning experience) said stick with the ESS tune and let the meth compensate for the smaller pulley. I have put about 5000 miles on this setup so far and the only thing I am worried about at this time is my 5-speed tranny taking a dump. About 15,000 miles ago I was changing the transmission fluid and a flat L-shaped piece of metal came out (barely fit through the drain hole, but I got it out). I thought...uh oh...time to search for a used tranny. So 15,000 miles later with a UCC short shift kit installed since....it is still pulling hard. But with this setup and extra boost the tranny is my biggest worry right now. The great thing though is there are many 5-speeds for the 330i on ebay.de here in Germany with an average cost of around 350 Euro with about 60k miles on them (and most with a year warranty). I will absolutely post any negative news concerning my setup on this forum on my TS2 modded setup. But so far besides the tranny, I have only two other negatives on this SC setup. One is dealing with the AEM system and it is minor right now. I think it might be due to some bad wiring connections, but the system maybe once a week will very quickly trigger without hitting the boost level (mine is set to start at 5psi). It is a burst only in milliseconds and does cause a surge in the car so I know it is spraying. Again, I just need to check my wiring to make sure I am not at fault before blaming the system. My "failsafe" is having an on/off switch and turning the system on only after the engine has warmed up so I don't accidently "dump" the mix on a cold SC......and eroding my cores as stated above as a concern. Oh and the other negative about this setup is putting too many miles on the car because I never want to stop driving it, especially on the autobahn. It is sooooo fun. 165mph comes quick.
signalwest is offline   Reply With Quote
Old 02-05-2013, 08:15 AM   #62
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
have you done the cams? Have you done any additional head work?
/_________\
O==[][]==O
Old 02-08-2013, 10:04 AM   #63
signalwest
No Cams and no additional headwork. Just headers, exhaust and 50/50 spray. I also put an aluminum sump in the drug bin for the intercooler to hold more liquid (also makes it easier to add liquid and eliminates any air in the lines). Also no ping. Runs smooth. I will keep this thread updated on how this setup is going. At this time my car is in the garage with a cover on it as the weather is the pits here in Germany. I can't wait till next month to give it some sunlight again. It has been there since the beginning of Dec.
Old 02-08-2013, 11:06 AM   #64
lab rat
My Ride: '02 330iT
I would love to see some pics of your additional coolant tank and hose routing.
Because sleeper
Old 02-09-2013, 10:24 PM   #65
330i ZHP
330i ZHP's Avatar
would like to see pics of your setup as well
/_________\
O==[][]==O
Old 02-10-2013, 08:20 AM   #66
Minnoe07
My Ride: 2004 BMW 330Ci
Also.
2004 330Ci 6 Speed; UUC Sway Bars; Powerflex RTAB's and FCAB's; KW V2 Coilovers; 3.38 OS Giken LSD
Z4 Finned Diff Cover; Headers; M-Tech II Rear Bumper and CF Diffusor; CF Trunk; CSL Front Bumper
M3 CF Hood; DICE I-Pod Kit; JTD Rear Shock Mounts; UUC Front Strut Bar; O2 Simulators
ESS TS2 Twin Screw Supercharger
Minnoe07 is offline   Reply With Quote
Old 02-23-2013, 02:50 PM   #67
signalwest
Sorry for the delay. This is an early picture which does not show the modified aluminum intake body with the AEM meth kit, but does show the "drug bin" intercooler tank. If anyone wants the guys name who made it let me know. He is online and specializes in building custom intercoolers. I've got the dimensions if needed. You could probably build one with a little more capacity, but this one works great for me. Notice in this picture it was hitting the hood barely and I put a pad in between a corner and the hood when closed. I since moved it down slightly so it clears fine. Just had to bend the tabs slightly down. It is a solid piece of work he did and the hookup was easy. The car is covered in the garage since snow is all over the place here, but I plan to take it out mid/late March. I can get some better pics with some covers off if you would like to see all the plumbing etc. I ordered the connections from him also. It was a very reasonable price (I need to look that up also if interested).
Old 02-23-2013, 03:13 PM   #68
330i ZHP
330i ZHP's Avatar
I would like very much to see under the cabin air intake and how the hoses are routed off the laminova cooler - how tight are the bends?
/_________\
O==[][]==O
Old 02-23-2013, 05:23 PM   #69
signalwest
I'll have it out in a month and take a picture of the whole setup. The bends are not tight. I wish the setup would have come like this with an extra tank because it is much easier to check fluid level and fill/change when needed. Of course ESS would have made it prettier, but it works like a champ....and doesn't look too bad either.
Old 02-23-2013, 08:47 PM   #70
lab rat
My Ride: '02 330iT
can't see the pic
Because sleeper
Old 02-24-2013, 08:48 AM   #71
signalwest
I can see it and not logged in. Can anyone see it?
Old 02-24-2013, 11:07 AM   #72
lab rat
My Ride: '02 330iT
Now it works for me. Looks awesome!
Because sleeper
Old 02-24-2013, 01:27 PM   #73
Dirtboy
Grüne Hölle Junkie
Dirtboy's Avatar
My Ride: ESS TS2+ 330Ci
Send a message via Yahoo to Dirtboy
Looks good. I'm in for more pics too.
Might look better in black.
Dirtboy is offline   Reply With Quote
Old 04-01-2013, 12:57 PM   #74
signalwest
Intercooler Tank with hose routing
So I pulled the car out Saturday and cruised up the Autobahn. Ran into a Porsche Panamera S which couldn't keep up, then a Ferrari F430 Spider (sounds awesome) which pulled away from me, but not like he thought he would and a new 991 Carrera 4S 911 (400hp) which he inched away from me until I hit the 165mph limiter. We started around 90mph and he gained about three car lengths on me up to 165mph then pulled away. All were on a four lane straight Autobahn. It was fun. Anyway, here is the pictures of my intercooler tank and hose routing. Notice that I turned the nozzle the opposite direction coming out of the lam. It was pretty easy. Checking, changing and filling up the tank is so much easier now.
http://photos.e46fanatics.com/data/5...331_153841.jpg
http://photos.e46fanatics.com/data/5...331_153914.jpg
http://photos.e46fanatics.com/data/5...331_153848.jpg
http://photos.e46fanatics.com/data/5...331_153905.jpg
Old 04-03-2013, 11:19 PM   #75
lab rat
My Ride: '02 330iT
that's pretty sweet!
Because sleeper
Old 04-03-2013, 11:30 PM   #76
330i ZHP
330i ZHP's Avatar
that looks like a great concept
something new to do
/_________\
O==[][]==O
Old 04-03-2013, 11:39 PM   #77
330i ZHP
330i ZHP's Avatar
damnit
I am on Summit now looking at tanks
Without me having to go down to the garage - anyone know the space measurements in the drug bin area?
/_________\
O==[][]==O
Old 04-04-2013, 05:32 AM   #78
signalwest
Tank
This is what I sent to Donny at http://dadscustomintercoolertank.com. I did change the height to 7 inches instead of 6.5. Keep it at 6.5..if you use my dimensions since the edge barely hit my hood and I had to force it down a half inch (just bent the tabs down a little). I am sure you could get a bigger tank out of it if you tried that is not shaped like a box since the wheel well comes up from the front. This has worked for me though. At the time Donny charge 155 bucks for the tank and another 20 or so for fittings plus shipping. He had a couple of other options you can ask about. All I did was find a card board box that fit the bin and based the dimensions off of that. I did not have him drill the tabs so I could "fine tune" the holes that I drilled myself. This is how the kit should have come. If you do it you will see why it just makes sense.
http://photos.e46fanatics.com/showfull.php?photo=97424
http://photos.e46fanatics.com/showfull.php?photo=97423
http://photos.e46fanatics.com/showfull.php?photo=97425
Old 12-15-2013, 11:41 AM   #79
330i ZHP
330i ZHP's Avatar
I have finally ordered my tank and will be installing it once it comes in. thank you for the idea and I hope it solves the air in the line hassle
/_________\
O==[][]==O
Old 12-15-2013, 02:10 PM   #80
signalwest
It does. Let us know.
