///M3 Forum
Old 02-01-2012, 05:26 PM   #1
joeysm3
My Ride: ///M3 02
how to bleed smg m3
is there diy guide on how to bleed it i searched everywhere no one seems to have a legit answer
joeysm3 is offline   Reply With Quote
Old 02-01-2012, 05:29 PM   #2
E46_330i_Stud
My Ride: 2004 330ci ZHP 6MT
How to bleed what? Coolant? Brake fluid??
1995 325i 5mt ArcticGrey/Dove - SOLD
2004 330ci ZHP 6MT SilberGrau/Black - SOLD
2001 330i M-Sport 5MT StaulGrau/Grey - SOLD
1992 Accord LX Sedan 275k miles all original - DAILY
2002 Chevy Suburban LT Autoride - TOY HAULER
2005 GMC Sierra 2500HD SLT - RACE TRUCK!
E46_330i_Stud is offline   Reply With Quote
Old 02-01-2012, 06:31 PM   #3
joeysm3
My Ride: ///M3 02
smg hydraulic fluid
Old 02-01-2012, 06:38 PM   #4
Bemwe_03i
My Ride: 2003.5 E46 M3 smg IR
drive it til it bleeds
Bemwe_03i is offline   Reply With Quote
Old 02-01-2012, 06:43 PM   #5
joeysm3
My Ride: ///M3 02
Mature answers please.
Old 02-02-2012, 01:07 AM   #6
fat-marshmellow
My Ride: ///M3 SMG
I believe you can do it the autoenginuity tool...go Google "m3 smg autoenginuity" it should be the m3forum link
Sent from my SGH-T959V using Bimmer App
ex: 2002 TIAG 325xi (sold), 2007 suzuki gsxr (sold)
current: 2002 carbon black ///M SMG
halogen headlights? want hid projectors? on a budget? maybe i can help! go here!!
http://forum.e46fanatics.com/showthread.php?t=840919
fat-marshmellow is offline   Reply With Quote
Old 02-02-2012, 08:56 AM   #7
dcf
My Ride: 02 e46 M3 SMG - LSB
AE tool does NOT have the "bleed" function. I know, I tried after I swapped out my gearbox, and no luck getting it to work right. AE will allow you to select each gear with the car motionless, but to do a true bleed, you need the GT1.
Bleeding SMG does not involve opening any bleed screws or anything like that (a la brakes). It is not a "mechanical" DIY. It is a series of functions in the computer where certain valves are opened while the pump runs and stops. It allows the air in the system to work its way back up to the Res. It takes a while for that program in the GT1 to run, but does the job right. You basically need the GT1 computer to do it correctly, there is no other way that I know of to get it done.
dcf is offline   Reply With Quote
Old 02-02-2012, 10:36 AM   #8
mooninite
My Ride: M3, X5
From talking to my shop, it is recommended to not replace the hydraulic fluid.
tldr: Don't mess with your SMG fluid.
mooninite is offline   Reply With Quote
Old 02-02-2012, 10:39 AM   #9
dcf
Very good point. I guess the question for the OP is: why do you need to bleed it out?
Unless you are changing out the gearbox or SMG pump setup, there is no need to open up that Hyd. system.
Old 02-02-2012, 11:54 AM   #10
joeysm3
My Ride: ///M3 02
because it is leaking. i filled it to max before and now its missing again... so i think its leaking i filled it up again it was sound of like air (gurgles) when i was filling it to max.
Old 02-02-2012, 12:15 PM   #11
dcf
Are you checking it with the car on or off? Are you sure it is leaking? The difference n the Res. between when the pump has the system charged and when it is unpresurized is very large. Noises in the Res. is not a sign of air in the system, that is how the Res. works
If there is a leak, your concern should not be bleeding, but finding the leak. When there is a leak, generally, it is involving the slave cylinder for the clutch.
Old 02-02-2012, 12:32 PM   #12
joeysm3
My Ride: ///M3 02
the car was off stone cold and i can see the oil on the wires under where u put the fluid. so how do i know if its the slave cylinder because u add fluid another week or 2 its missing.... any suggestion?
Old 02-02-2012, 03:31 PM   #13
JamaicanBlueE46M3
My Ride: E46 M3
It uses Pentosin CHF11S oil, u can use the INPA or GT1 to bleed it. If u have to be adding then it must have a leak somewhere, clean up the area properly and watch and see if it reappears. I would think that if the slave cylinder leaking then maybe it would start to have gear selection issues.
JamaicanBlueE46M3 is offline   Reply With Quote
Old 02-02-2012, 06:28 PM   #14
Mallee
My Ride: 2002 E46 M3
+1
When I had an smg pump failure an independent bmw mechanic told me he could replace the pump but I'd need to go to a dealer to get the system bled..
Mallee is offline   Reply With Quote
Old 02-02-2012, 07:15 PM   #15
joeysm3
My Ride: ///M3 02
but now it is everytime i press the gas pedal it pops back to N im sure it has something to do with the oil missing because it passed the pump test that my mechanic did about a month ago or so..
Old 02-07-2012, 01:11 PM   #16
sonnydm3
My Ride: 2004 m3
i do repair alot of e46,s u need gt1 software to bleed system ,,
sonnydm3 is offline   Reply With Quote
Old 02-07-2012, 04:48 PM   #17
grkm3
My Ride: Money Pit
Send a message via AIM to grkm3
I used INPA to bleed my system. Make sure you have a high current battery charger connected to your car while the process is running.
SOLD
03 Steel Gray M3 - Imola Red Interior - SMGII - Premium - HK Sound
Mods: VFE SC Stage 2, SS Ceramic Coated Stepped Headers, S-Pipe, X-Pipe, TMS Subframe Reinforcement, KWV2 Coilovers, TMS Camber Plates, Powerflex RTAB's, Rogue RSM's, ZCP F/R brakes
Coming Soon: Open to suggestions
grkm3 is offline   Reply With Quote
Old 02-07-2012, 07:47 PM   #18
turbotoy2791
My Ride: 04 m3
You may have air in the line to the pump from the reservoir. If you do you will have to take the line loose and fill it with fluid and tap it with a screwdriver to get the air out then fill it again. Once you have the line full snap it back in the resevoir. My line had air in it a while back. I kept driving the car and it finally locked the tranny in two gears. Had to take the tranny apart to get it out of gears. Also it maybe this line leaking.
turbotoy2791 is offline   Reply With Quote
Old 02-07-2012, 07:53 PM   #19
turbotoy2791
My Ride: 04 m3
Take the cap off the reservoir and push the hood button to make the pump run. You should be able to see the fluid get sucked into the accumulator. If the fluid does not get sucked down you have air in the reservoir line. Do the above.
Old 02-07-2012, 08:03 PM   #20
joeysm3
My Ride: ///M3 02
yea i think its leaking because i refilled the reservoir and it worked 2 days later i was missing fluid... i have to find out where is it leaking from. if its missing oil it wont let me drive it goes back to N when i press the gas pedal. im guessing its the clutch slave cylinder..
