Old 02-02-2012, 10:44 PM   #1
antman x7x
My Ride: 2005 330ci ZHP
Hydraulic or mechanical tensioner pulley?
How do I tell which one I have? I have really bad squealing almost all the time so I am going to replace the tenioners and pulleys for the wp and a/c
antman x7x is offline   Reply With Quote
Old 02-03-2012, 12:02 AM   #2
flashmeow
Banned User
My Ride: E30-E46-E90-E90M-F30
you just have to look at it or go browse the web to see the difference between the hydraulic or mechanical tensioner. A great website that has BMW parts pictures is ecstuning.com
It is hard to explain it so your best bet is to look up the pictures and compare it to your setup. Basically, a hydraulic has a 2-3 inch hydraulic shaft/tube (looks simiiar to your hydraulic hood latch).
there is a debate which one is better. I had a mechanical but upgraded to hydraulic. however, there are plenty of guys with hydraulic but switched to the mechanical. the good news is that both version is available.
i hope this helps. good luck
Old 02-03-2012, 12:16 AM   #3
theevilshiftkey
My Ride: 2003 330i
If your 2003 is low miles then it's probably mechanical. The only reason it would be hydraulic is if it was replaced at some time.
theevilshiftkey is offline   Reply With Quote
Old 02-03-2012, 12:17 AM   #4
NOVAbimmer
My Ride: E60M
My 2001 is hydraulic... Easiest way (only way) to find out is to look
NOVAbimmer is offline   Reply With Quote
Old 02-03-2012, 12:28 AM   #5
antman x7x
Alright I will have to look in the morning thanks guys
Old 02-03-2012, 12:37 AM   #6
Stinger9
My Ride: '04 330Ci
Not so easy to look. It's down in there.
My 2004 came with spring tensioner for A/C belt and hydraulic for the long belt tensioner. Deflection pulley is a spring.
Old 02-03-2012, 07:25 AM   #7
325i'02
My Ride: 2002 325i
02 325 here. I have them both. Hydraulic on main belt and spring tensioner on the AC belt. I doubt the squeeking is coming out of the tensioner though - a bad pulley could be doing it.
M - One letter, one dream!
325i'02 is offline   Reply With Quote
Old 02-03-2012, 08:36 AM   #8
antman x7x
So just a bad pulley since I was in there I was going to do the tensioner but if it's not needed I guess I won't.
Old 02-03-2012, 08:36 AM   #9
antman x7x
Wheres the best place to purchase pulleys from?
Old 02-03-2012, 08:39 AM   #10
325i'02
My Ride: 2002 325i
I would go OEM on them bc something that small can really mess your car up. I usually compare ecstunning and rockauto. There was a thread here recently on a guy that made a website that pulls up the information about part numbers from all the major BMW parts websites and gives you lowest prices. Look around for it.
Old 02-03-2012, 09:08 AM   #11
antman x7x
Yes defiantly going oem. I'll prob try ecs tuning is there a difference in the pulleys how there is in the tensioners?
Old 02-03-2012, 09:10 AM   #12
LeMansteve
My Ride: '04 330i 6mt ZSP ZPP
Question: does the hydraulic tensioner ever go bad? Most of the DIYs and questions revolve around replacing just the pulley.
Old 02-03-2012, 09:16 AM   #13
325i'02
My Ride: 2002 325i
http://realoem.com/bmw/showparts.do?...90&hg=11&fg=18
I suppose the AC pulley is the same as 06 ADJUSTING PULLEY but i havent been able to take it off as of yet. I need to change it though bc its going out.
Hmm, or i might jsut take the belt off - i doubt i would need the AC in the next few months.
Old 02-03-2012, 09:19 AM   #14
325i'02
My Ride: 2002 325i
I suppose it could go bad.That is when there will be squeeking from the belt not being fully extended over the pulleys. This will also %100 make the belt slip from them and you overheat.
I havent heard of a bad tensioner yet but i have also been here for not too long.
Mostly pulley examples.
Old 02-03-2012, 09:36 AM   #15
antman x7x
Alright just the pulleys then. If it still doesn't fix it then I'll get the tensioners
Old 02-03-2012, 09:44 AM   #16
SpoonerDee
My Ride: 2005 E46
Always replace pulleys in pairs. The idler and tensioner pulley should be replaced at the same time, when one is about to fail the other is usually right on its tails.
SpoonerDee is offline   Reply With Quote
Old 02-03-2012, 09:44 AM   #17
325i'02
My Ride: 2002 325i
I have never played with a bad tensioner but i believe if it is bad (hydraulic or spring loaded) and you have the belt off, you will be able to move it without any resistance from it. If you need a lot of power on that ratchet - the tensioner is working fine.
Old 02-03-2012, 10:05 AM   #18
antman x7x
That is what I'm intending to do. I'm only finding the idler pulley on esc tuning. Could someone lead me the right way to the other pulley
Old 02-03-2012, 10:10 AM   #19
325i'02
My Ride: 2002 325i
http://www.ecstuning.com/BMW-E46-325...e/Drive_Belts/
Last section is for the tensioner pulleys.
It does say for hydraulic tensioners only. However, my AC tensioner is springloaded and has the centered whole pulley - go figure
Old 02-03-2012, 11:29 AM   #20
antman x7x
Alright so I'm going to need a tensioner pulley and an idler pulley I'm confused on this. Lol. Isn't there one for the a/c also?
