Sponsored by BAVSOUND
Old 02-03-2012, 01:41 PM   #1
foobar_666uk
My Ride: 320D M Sport
How do you make a bootable SD for Dynavin Android updates?
I've lost the SD card for my DVN-E9X and need to upgrade Android.
How do I create a new bootable SD card from Windows?
foobar_666uk is offline   Reply With Quote
Old 02-03-2012, 05:28 PM   #2
Darkoz
My Ride: E46 325Ci
There is already dedicated Dynavin Android thread, post you question there but before you do try searching and reading first.
Darkoz is offline   Reply With Quote
Old 02-03-2012, 06:02 PM   #3
foobar_666uk
Yes I saw that thread thanks, but at over 100 pages long I have not got the time to read every post.
I did a search, but came up with no answers, hence my post.
Old 02-03-2012, 06:09 PM   #4
Darkoz
My Ride: E46 325Ci
You don't have to read every post, just post your question in the dedictaed thread, it's there for a reason.
Old 02-03-2012, 06:44 PM   #5
opey
My Ride: 04 M3 coupe
format it to fat32 and put the files on the card
IR/IR 6 speed
opey is offline   Reply With Quote
Old 02-03-2012, 11:51 PM   #6
mistapony
My Ride: volvo v70r
What I've read is that it needs to be fat16 and an active bootable partition
mistapony is offline   Reply With Quote
Old 02-04-2012, 01:46 AM   #7
Darkoz
My Ride: E46 325Ci
Try in then and let us know how you go, that way you would've learnt something and maybe help someone else out along the way.
Old 02-04-2012, 07:08 AM   #8
foobar_666uk
I've tried using the following;
Formatted as FAT16 / 64K allocation using Windows 7
Formatted as FAT32 / 64K allocation using Windows 7
Formatted as FAT16 / 64K allocation using EASEUS Partition Manager Home Edition
Formatted as FAT32 / 64K allocation using EASEUS Partition Manager Home Edition
Formatted with 2 partitions, FAT16/64 & EXT2/64 using EASEUS Partition Manager Home Edition
Formatted with 2 partitions, FAT32/64 & EXT2/64 using EASEUS Partition Manager Home Edition
All formatting using EASEUS used 63 Sectors per track, 255 Head & 482 Cylinders.
Yet none of the above has worked for me?
I have a 4GB SanDisk SDHC Card and I am using Windows 7
Am I right in my understanding that to boot from the SD card, you simply insert the SD card into the "Navi" slot and reboot the Headunit?
I am not having any luck at all !!!!
Old 02-04-2012, 11:55 AM   #9
listermint
My Ride: E46 M3 '02
Use a different card, i havent had much use with that exact card.
I dont think it responds well to SDHC cards. try a standard micro card maybe 2gb without high capacity.
listermint is offline   Reply With Quote
Old 02-04-2012, 12:02 PM   #10
jeffb325@NavigationSolutions
J&T Distributing
My Ride: BMW
also you may want to be sure that sd card slot is actually reading the card, with android running, take out the card and and put it back in, make sure it recognizes it (it will say so in the status bar)
jeffb325@NavigationSolutions is offline   Reply With Quote
Old 02-04-2012, 12:16 PM   #11
foobar_666uk
Yeah it recognises it in Android.
Hmm I'll have to buy another SD card
Old 02-04-2012, 03:09 PM   #12
foobar_666uk
I've just gone out and bought a "SanDisk SD Card - 2GB"
Used EaseUS to format it as Fat16, 64K, Active Primary partition.
Loaded the files from the Dynavin website onto it, put the card into the "Navi" slot on the Headunit and rebooted it.
Again, nothing happened. It just booted up as normal - Android see's the card OK, on first boot up it said at the top bar "Preparing SD card..." and in the Settings-->Storage it sees the SD card fine.
I am waiting for someone to send me across a format utility that Dynavin sent him, so hopefully that will help - but none of the above has worked for me so far.
Old 02-05-2012, 05:56 AM   #13
foobar_666uk
Finally got it working with the help of this utility from Dynavin
Follow these step by step instructions
You will find that the text is not chinese unless you are using the chinese language, instead it is special characters, so it is a bit of a guessing game that the correct text is showing, but I managed it OK - on that basis anyone else should be OK too
Also it is worth noting, that it appears this Utility does NOT work with an inbuilt card reader on your Laptop/PC. For some reason I had to use an external USB SD Card reader.
When using the USboot utility, if it does not show a USB symbol next to it, you are not using an external USB adapter
When you are using a USB reader you get the following, with USB symbols next to the drives - this then worked for me
You can download the USBoot Utility here
Old 09-12-2012, 08:42 PM   #14
BigDRick323
My Ride: 2000 323i
Ran across this but see that it is not updated, I am trying to get mine to work. When I insert the card it doesn't make a difference, the android side is still a blank screen.
Old 01-23-2013, 07:39 PM   #15
nrj
My Ride: E46 M3
Any update on this issue? All those links are dead, foobar.
I cannot for the life of me get my Dynavin to boot from any SD cards, including the one that came with the unit for reflashing.
nrj is offline   Reply With Quote
Old 01-23-2013, 08:15 PM   #16
BigDRick323
My Ride: 2000 323i
I wish I could get mine to do anything on android side, would pay someone to come and set it up!
Old 01-24-2013, 02:16 PM   #17
J&T Distributing
My Ride: BMW
rick, I know you have tried everything, at this point I think its likely your sd card slot is bad......how come you have not contacted your dealer about this?
Old 01-24-2013, 02:50 PM   #18
BigDRick323
My Ride: 2000 323i
Thanks Jeff, I contacted them and they advised me to mail it back to China for repair. I'm hoping it's me being an idiot and not a repair situation, I'd like to get another perspective dealing with this who might see something I am missing or ignoring...Not real excited about sending the unit back to China. Maybe an electronics pro locally can even repair it here so I dont have to ship it out.
Old 06-26-2013, 05:11 AM   #19
UniQue84
My Ride: E46 330i
Hey would be nice to see your images again. dont know that to do in usboot utility :/
UniQue84 is offline   Reply With Quote
