Progress thread: my auto to 6 speed transmission swap (w/pics) - Page 5 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 62 votes, 4.94 average. Display Modes
Old 03-22-2012, 12:00 PM   #81
Nervous
My Ride: 01 330CI 6MT ZSP EU3
It was discussed a million times, search. IMO - auto tranny replacement is MUCH cheaper (if a used one is used as a replacement) or comparable (if new/reman is used). Now, please don't hijack my topic, open a new one if you want.
Nervous is offline   Reply With Quote
Old 03-22-2012, 12:09 PM   #82
325i'02
My Ride: 2002 325i
My bad for asking a question here. I am really sorry and apologize for disturbing the force from graviting around your precious topic. And i very much appreciate your answer. Thank you again and i am sorry.
M - One letter, one dream!
325i'02 is offline   Reply With Quote
Old 03-22-2012, 01:01 PM   #83
Nervous
Sorry if this sounded insulting, I just don't want another holy war - manual vs auto - here and I bet finally it would be there....
Old 03-22-2012, 01:06 PM   #84
325i'02
My Ride: 2002 325i
No offense taken. Your cost chart answered my question. Thanks.
Old 03-22-2012, 10:04 PM   #85
Nervous
A tiny update: tried to install the flywheel again and figured out that bolts for it are torx ones and my biggest torx socket (T50) is too small for them. It is either T55 or T60. Tomorrow will stop by HF to pickup a new socket set where both T55 and T60 are included....
Old 03-22-2012, 10:23 PM   #86
Nervous
BTW, I have an idea how to wire the reverse light switch. I still have a harness from automatic transmission (I haven't cut it yet). As far as I understand it goes into that wire-box. All what I need to do is to cut the connector off (tranny side), choose two wires, and find two corresponding wires inside that wire-box. This is it! Objections?
Old 03-22-2012, 10:38 PM   #87
jbeurotech
Regional Sponsor
My Ride: 2000 E46 with 254K
Should be a T60
Seth Thorson
Service Manager/BMW Tech
JB Eurotech Service "Your Reasonable Dealer Alternative"
General Questions can be sent to appointment@jbeurotech.com
1. Do not argue with an idiot. He will drag you down to his level and beat you with experience.
2. Light travels faster than sound. This is why some people appear bright until you hear them speak.
jbeurotech is offline   Reply With Quote
Old 03-22-2012, 10:50 PM   #88
genuity
My Ride: 2001 330iS
Go get yourself these connectors for an genuine fit to the reverse switch (23147524811); original research by yours truly
http://forums.bimmerforums.com/forum...postcount=2129
then wire it like the master electrician TitaniumCranium
http://forum.e46fanatics.com/showpos...2&postcount=24
genuity is offline   Reply With Quote
Old 03-22-2012, 11:51 PM   #89
Nervous
Yep, I already have the Bosch EV1 connector, thanks!
So, you think it is not plausible to reuse the tranny wiring? It is long enough to reach the backup switch on MT, it is already routed where I need it... It seems much easier than routing new wires, no?
Old 03-23-2012, 12:00 AM   #90
genuity
My Ride: 2001 330iS
It is not plausible to reuse the tranny wiring. It is simply not long enough since the switch is on the right side of the tranny as opposed to left with the slush. You will also want some slack but not too much that the exhaust will burn it, so you may as well use your own wiring. I really hate that it the switch is on the right side.
Old 03-23-2012, 12:22 AM   #91
Nervous
Actually, the length is not a big deal, it can be easily extended, if necessary. The biggest problem is tracing wires, finding which one to use in the wire-box. Will see.
Old 03-23-2012, 12:33 AM   #92
TerraPhantm
My Ride: M3 & ZHP
Aren't there wires from the tranny harness that already go to the reverse relay? So instead of picking two random wires, why not just pick the ones that are already connected. Should be pretty easy to figure out which wires you need by referencing the WDS, no? I would just go by the pin number specified, and then just verify its the right one by giving it 12 volts.
Or does the transmission do something funky like send a reverse signal to some other module over the CAN, which then sends a signal to the reverse relay?
Old 03-23-2012, 01:43 PM   #93
Nervous
I am having hard time to go through WDS on http://www.bmw-planet.com/diagrams/ Here is the diagram for the backup lights:
The signal comes from TCU...
Old 03-23-2012, 09:18 PM   #94
Nervous
Hmm. I am more and more disappointed in Bentley. Flywheel installation is also not covered at all there (along with RMS). I need torque specs for flywheel bolts and assume the bolts are M12 and 10.9 grade, so the torque must be 115 Nm (85 ft lbs)? TIS is also not very clear since I couldn't find torques specifically for M54, but seems to me they recommend 120 Nm (89 ft lbs). Is this correct?
Old 03-23-2012, 11:06 PM   #95
TerraPhantm
My Ride: M3 & ZHP
Strange way of wiring a relay, but I guess it works: Seems the TCU grounds pin 4 which then grounds the relay so that it can turn on. Power comes from the DME fuse box, and the "switch" is just another constant +12v from whatever X10016 is.
Here's a table of the TCU pinouts
http://wds.spaghetticoder.org/en/zinfo/E46_PA7000G.htm
Old 03-24-2012, 12:15 AM   #96
Nervous
I still have yet to find the pinout of 2 tranny-side connectors (for 5hp zf tranny, ms43)...
Old 03-24-2012, 12:32 AM   #97
TerraPhantm
My Ride: M3 & ZHP
What do you mean by "2 tranny-side connectors"? The table I linked to corresponds to the 5hp tranny I'm combo with the MS43 according to the WDS
Old 03-24-2012, 12:42 AM   #98
Nervous
The table you provided is the pinout of connectors at TCU side, right? I am talking about two big round connectors which were inserted into a tranny: I need their pinout as well to find which wire is which.
Old 03-24-2012, 01:10 AM   #99
Nervous
Aha, I found their names - X8532 and X8505: http://wds.spaghetticoder.org/en/zinfo/E46_EX8532A.htm
The diagram: http://wds.spaghetticoder.org/en/svg...4308.svg?m=e46
Old 03-24-2012, 10:47 PM   #100
Nervous
Update: finally, I've installed a flywheel! I had to fabricate a flywheel locker tool (torque for bolts is 90 ft lbs = 120 Nm):
Installing clutch:
I found out that the aligning tool is too loose in the pilot bearing. I measured the diameter of the tool and the real tranny axle. The diameter of the tool was 14.9 mm and the diameter of the real tranny axle was 15.3 mm (sorry, I still can't use to those inches and I used to millimeters rather than fractions of inches). Thus, I just used one layer of vinyl electric tape over the align tool and the caliper said the diameter of it became 15.2 mm - a perfect fit for a pilot bearing:
Unf, at this point my wife stepped into my garage and told me about leaking kitchen faucet, so I had to switch to fixing it....
